Question about GE Profile CustomStyle PSC23MGSWW 36" 22.7 Cu. Ft. Side-by-Side Refrigerator w/ CustomStyle Configur...
GE Profile Arctic Side x Side Refrigerator PSC23MGNA
Freezer temp varies from -25°F to +20°F and refrigerator varies from 32°F to 45°F during a few hours. It won't hold a steady temperature on either side. It's about 3-4 years old. Thermostat sensor and temperature control panel have been replaced with no effect. Temperature settings in refrigerator seem not to be able to correct these extremes.
  • 11 more comments
  • nouser user Jun 22, 2007
    The compressor runs ok. The freezer reaches -25°F. When this happens the refrigerator side is usually around 42-45° Too warm for me.
    It seems as if the freezer side gets too cold and the refrigerator side gets too warm. This doesn't happen all the time though.
    I replaced the motherboard and this didn't fix anything either.
    I get the feeling that the refrigerator is asking for cooling and the freezer can't move the cold air into the refrigerator. Can this happen?
    Is there some fan control system that moves the cold freezer compartment air into the refrigerator compartment?
  • nouser user Jun 30, 2007
    That didn't cure the issue. Thanks for your suggestions. So far the motherboard, a temperature sensor and the thermostat control assembly have been replaced. I'm now awaiting, 4 sensors, a fan and an air diverter damper control. If this doesn't cure the problem I'll probably need to buy a new refrigerator.
    Today the temp in the freezer reached 40° and the fridge 48°. A couple hours later the freezer was at -24° and the fridge was at 42°. Now the freezer is at 10° and the refrigerator is at 32°. Some pretty wild swings, 64 degrees in the freezer and 16 degrees in the fridge in about two hours time.
  • nouser user Jul 11, 2007
    Well damn. This time I've had the air diverter damper control, the fan motor in the freezer, and another sensor replaced and still no luck. I'm beginning to believe this GE is the refrigerator from hell. There was no ice buildup in the unit.
  • nouser user Jul 17, 2007
    Well the freezer is still varying temperature from -20°F to +30°F. One thing has changed. Now the refrigerator is only just able to reach 40°F on it's coldest setting.
    I think most of the replaceable parts have been replaced. It's possible that a that was replaced was defective I have a GE tech coming out next week to give me a diagnosis. This model is a cabinet depth unit and I think they running around $2,700 MSRP. I'd hate to think I'd have to replace it.
  • nouser user Jul 31, 2007
    Fixed. The problem was with the motherboard. The first replacement motherboard was defective.
  • Anonymous Jan 08, 2008
    I have the same exact problem, but my fridge is 1yr 3months old, and I paid $3200.  I just want a refund from GE.  This is unacceptable.
  • nouser user Apr 26, 2008
    My issue was finally resolved.  A GE tech with a computer came out and re-replaced the motherboard with a different one.  He stated that the original replacement was not working properly.  I think that there was a recent modification made to these motherboards. My first replacement MB didn't correct the problem.
    The tech said that the unit was going into it's defrost cycle too often.  The tech told me that prior to running a defrost cycle these refrigerators go into a chill down mode to protect the frozen food during the defrost cycle. Hence my freezer would read -20 on the thermometer as it was getting ready to run the defrost. Later it would read +20.  I pointed out to him that the ice cream was either too hard to scoop or it was so soft you almost could pour it out so that the programming didn't work.
    He did say that the cabinet models have the highest complaint rate of all their refrigerators.  Anyway the new replacement MB seemed to moderate the frequency and severity of this performance.  After this experience I'd also never buy another GE Refrigerator.  I'd also reconsider buying any GE appliance in the future.
  • fwkdog Jul 01, 2008
    My GE Profile is 2 yrs old and I have the same problem i.e. frig and freezer temp will not regulate to mfg spec. I came home to find all my food spoiled! It seems many GEs have had this problem, I agree GE should do something, there are expensive units. I have had 2 "redesigned" MB replaced within 7 days to no avail
  • thoida Sep 22, 2008
    My fridge is also bahaving very badly....  over the last year.   The water was intermittent.    The water started working again.   The Ice maker stopped working, then started and stopped again.   The freezer would melt everything. Now it seems normal.  Now over the last two weeks, the Fridge side is 29F all the milk if freezing.    Our fridge is over 5 years old.   how much does a mother board cost - it's gotta be less than the fridge!
  • amplouffe1 Apr 26, 2009
    My fridge is having the same issue. The fridge side is freezing over due to the problem. A repair tech came out to evaluate the situation which cost $70. He said it needs a new motherboard. Since I purchased the unit 21 months ago there is no warranty onthe motherboard...$600 to buy one. He said he would install it at no extra charge, but $600!!! This is ridiculous and obviously by the complaints should be under warranty for a longer period of time, if GE is going to continue to manufacture motherboards of such poor quality.
  • Anonymous Mar 12, 2014
    the temperature control is not lit
  • Anonymous Mar 25, 2014
    my GE Profile, pfss6pkw, refrigerator control buttons are going crazy changing temps,beeping that it is changing and turbo cool going on and off what can it be the control unit or just sensor pins"
My GE Profile is 1.5 yrs old and I have the same problem. I came home to find all my food spoiled! It seems many GEs have had this problem, I agree GE should do something, there are expensive units.
Posted on Apr 25, 2008
I have a GE PSS25NGN and yesterday the refrigerator was at 95 degrees Fahrenheit! and the freezer was around zero. A chocolate bar in the refrigerator was melted, but the ice cream in the freezer was perfectly fine. The house was only at 65 degrees, so the refrigerator was generating heat from somewhere. Where the extra 30 degrees came from is beyond me. Today it's working just fine with no food in the refrigerator. I'm not sure how to proceed. I don't trust it after it ruined all the food in the refrigerator.
Posted on Mar 29, 2012
I too have the same problem with a GE Profile side by side with the Freezer on the bottom. It seems if you buy GE your destined to experience problems with your purchase. Definitely an issue they should address as I'm sure they know full well about the issues with their products.
Posted on Aug 02, 2008
I have had a GE fridge for 2 years and the same trouble with maintaining the temps. Called GE they came out and installed a motherboard no charge for the board BUT THERE WAS A $168.00 LABOR CHARGE !!!! Now it is 6 months later and the same thing is happening again, called GE they say the board is under a 5 year warranty , HOWEVER there will be a charge for labor and I am guessing it will be $168.00 @#$%^&* CROOKS!!! DONT BUY GE!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Jun 15, 2008
    President:
  • 1,462 Answers
Check that compressor is not cutting out on overheat and hence cooling stops. feel compressor when it has been running for some time and see if it over hot
Posted on Jun 18, 2007
  • douglas smith Jun 22, 2007
    yes there is a fan drive moving air into the fridge. try unplugging for 24 hrs if you can and see if it works then or remove back panel of freezer and see if excessive ice build-up. also you may have an ice blockage in return duct from fridge
My GE Profile Side by Side Refrigerator (PSC23MGNA) has ice below the bottom try in the freezer. I tried to thaw out the area on the back but I am not sure where the drain is located. Need Help on wha
drain is located in very back of bottom of freezer an a little ledge 6 inches from bottom.... ice build up normally means drain is clogged and needs hot water / turkey baster to force hot water down drain. (gently chip away ice careful not to crack plastic
Aug 28, 2014 | Refrigerators
if you were able to do the test... check the compressor unit, also the do check on the electrical relay of the ref.
Jul 01, 2008 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
Ge profile artica model PSC23SGPA Side by Side not keeping temp - lost everything in freezer and now frig is heating up. Can change temp to 0 but within a few seconds reads 24 (temp set does not hold)
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 01, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Hi, our ge profile refrigerator is having temp
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Side-by-Side Refrigerator gets to too cold
turn the temp setting up to40 then check in a couple of hrs
Nov 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE PSC23MGNA refrigerator. No display light for
Sounds like you have a bad main control board . The original pt # is WR55X10552 . The replacement board is WR55X10656 . Your original board , is on a recall list , and GE should come out and replace under an extended warranty .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
Oct 31, 2009 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
Help! My GE Profile Arctica runs 24 hours a day...sounds like a fan. It stops when either door is opened, then starts as soon as the door closes. The temps on either side are higher than what they are set...
It is normal operation for ARTICA fans to run continuosly except when the door is open. If the door remains open for 3 minutes the fans will run anyway.
The temperature will vary about 6 -8 degrees from the selected temperature. The temperature will increase during a defrost cycle.
I do not believe you have a problem.
Apr 21, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE Profile refrig side by side Model GSS 20iEMCC, not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
df
Dec 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile PSC23MGNA too cold on frig side & icing up on freezer side
Check your thermostat if it is still functioning well.
May 02, 2017 | Refrigerators
GE Profile CustomStyle PSC23MGSWW 36" 22.7 Cu. Ft. Side-by-Side Refrigerator w/ CustomStyle Configur... Logo
3,706 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
Sometime Mechanic
