Question about GE Profile WPRE6100G Top Load Washer
During wash cycle the hub nut that is located under the agitator comes loose. It has to be tightened after each wash. GE Profile Top Load Washing Machine
  • 61 Answers
Replace the hub nut and the washers under the tubbe sure to tighten really tight if it comes loose again you will need to replace the transmition
Posted on Jan 21, 2009
2 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: GE Profile WPRE6100G Top Load Washer. The hub nut loosens
You do not have a "high torque" motor (which would have required motor replacement along with these other parts).
Install a new hub washer WH2X1199, split ring WH2X1195, and hub nut WH2X1193. Inspect the hub on the inner basket for wear. If it is worn, the entire SS inner basket (WH45X10060) will also have to be replaced to prevent continued problems. If possible, tighten hub nut with torque wrench to 110 ft-lbs. I hope you did not purchase from Sears. (Sears sold machines are sold with NO FACTORY WARRANTY of any kind. For those, GE will tell you to call Sears.) If not from Sears, you may be able to get some assistance from GE customer relations if you need the inner basket. Your machine was manufactured in Nov. 06, so most likely was purchased over one year ago.
Note: If you look at the board on the top portion of the motor, you should see a LED light flashing on the right front side. It should flash about 1 second on, 1 second off (unless motor running, then .5 on, .5 off) Other flashes indicate various problems. To reset code if necessary, unplug motor for at least 15 seconds, then plug in, wait 3-5 seconds, then open and close lid 5 times within next 10 seconds.
If this does not rate a Fix-Ya for you, please don't bother rating, as I don't like to see my score drop after giving this much free advise.
Thanks.
Posted on Jan 17, 2009
Ge profile wpre6150 repairs
Remove the top cap on the agitator and re-tighten the nut.
May 07, 2015 | GE Profile WPRE6150K Top Load Washer
GE profile thumping during wash cycle
hi, laying a spirit level across the top of the washing machine while adjusting the front feet....you will need help to do this... In Rare cases the fitting to the drum can come loose...
Hope this helps...
Regards
Jan 26, 2015 | GE Profile WPRE6100G Top Load Washer
The agitator keeps detaching no matter how much water or clothing is in the washer. What can be done to keep the agitator in place?
on top of the agitator should be a cap you can pry off and you will see a nut which has probably come loose, and you just have to tighten.
Nov 08, 2010 | GE WBSE2090A Top Load Washer
GE top load Profile washer. Spin cycle not
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 11, 2010 | GE WVSR1060A Top Load Washer
I have a GE top load washing machine. During the
there are springs under the machine that attatch to the tub in 3 to 4 places if one of these springs break it will cause the tub to bang.
Dec 22, 2009 | GE WBSR3140DW Top Load Washer
Agitator problem
Check to see if any thing is under the agitator. If not then maybe the bearings going out or other part of machine . Besure the cap is tighten so agatator don't come off. Check for ware on agatator top to the tighting nut.
Jun 02, 2009 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
My ge washer wpre6100g clicks during agitation part of cycle...
sounds like the agitater drive is stripped its a plastic piece under tha agitater you just grab the agitater work your fingers under the edges and **** up on it and it snaps off then remove the 5/16 screw put a new block on and snap the agitater back on
Jan 29, 2009 | GE Profile WPRE6100G Top Load Washer
Thanks.
Jan 15, 2009 | GE Profile WPRE6100G Top Load Washer
Noise when stopping after spin cycle or open lid (after moving)
check hub nut, it is likely loose, its under the agitator. top pops off agitator and bolt hold agitator down.
Jan 04, 2009 | Whirlpool Inglis IP4400 Washer
Agitator
there should be a 7/16s bolt under the cap try tightening that up
Mar 21, 2008 | Washing Machines
GE Profile WPRE6100G Top Load Washer Logo
202 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
