Question about IBM Wheelwriter 30 Typewriter
IBM WheelWriter 30 Series II
HELP!! My display has a square with a line through it and the number 121. I cant type or do anything else. What is the does this error code mean?
  • IBM Master
  • 3,594 Answers
The 121 indicates a keyboard problem, See my tip under ww1000 also check the two flat connectors from the KB to the PC mboard.
DickyO
Posted on Jan 16, 2009
I have an IMB Wheelwriter 30 Series II. When I turned on the machine this morning it made a couple of ringing sounds and then on the display it reads a square with the number 215. Nothing else works on...
215 is a printwheel error. Remove the P/W, look for dirt or debris in that area, if you have a compressed air source blow out the P/W area. If these fail the P/W led sensor is probably bad.
and you most likely need a tech.
DiclyO
Sep 06, 2011 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 Series II Since changing
The ribbon may not be fully seated on the ribbon deck. The blue latch has to hol it in place.
DickyO
Jun 30, 2011 | Lexmark Wheelwriter 30 Series II...
IBM WHEELWRITER 30 SERIES II
I believe a 215 code is a bad printwheel sensor. You need a tech.
DickyO
Mar 05, 2009 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 Series II Typewriter 6787
The book says turn the T/W off wait 30 seconds and restart, if condition returns call for service. However you might try removing the batteries and unplugging the machine waiting a few minutes and restarting. CAUTION ALL THE MEMORY WILL BE LOST!
DicktO
Jul 16, 2008 | IBM Wheelwriter 30 Typewriter
Error 121
121 says that the keyboard is not supported which means that the K.B. is bad. To get around this hold the code key, press & relase the "L" key type 001 rel the code key this sets the T/W to a US keyboard. You will have to do this until you replace the keyboard or repair it see my tip under WW1000.
DickyO
Jun 27, 2008 | IBM Wheelwriter 30 Typewriter
On the l. side of the keyboard there are keys labeled store, play & delete. Press & hold store then type an address 01 thru 99 release store and type whatever you want. Upon completion press store again. To play it back press play and the address, to clear delete and address.
DickyO
May 16, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 series II - prints only half a letter
If it types only the top half yhe platen is probably not all the way in. Make sure the 2 black latches are lined up with the side frames then press down firmly on both sides of the platen.
DickyO
Apr 14, 2008 | IBM Wheelwriter 30 Typewriter
Margin Problems
You are in auto return. Press code and R
This should doit
DickyO
Mar 10, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 Typewriter Logo
217 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
