I have an old Proscan PS52652 and do not have the original remote I have a universal remote which doesnt do much other than the basics. The tv has been muted some how and I cant get the volume back on from the front panel. Can you help? Thank you
Do not know if I can solve the issue, but I have a Manual and in reading your issue, it says to press the menu button repeatedly to get to the audi menu. Press + or - to select the audio menu. You can probably see the whole audio menu now and look at the bottom of the menu to make sure the speakers are not off. if they are then press menu until it scrolls to the Speakers on off option and press + or - to turn on. It also says to check the rear of the unit to make sure that the speaker switch is in the internal position. Are you using an S video cable? If so it says you also need to run the red and white audi cables from the tv audio in to the component audio out.
Sorry cant do more, hope it helps..
Posted on Jan 28, 2009
Spoiled original remote to the TV set PROSCAN.Dlya universal need a code.
Hello
I can't find any code for Dlya universal remote for your Proscan TV. There is codes for your TV with Philips Universal remote and I've its manual with me. If you are interested, get me know though Fixya. I'll send you the model number and codes for the remote you have to buy. OK.
Feb 27, 2011 | Televison & Video
I bought my 19" Proscan LCD (19LA25Q) used from a
The Proscan 19LA25Q came with a remote originally. Unless the IR receiver has failed, it should work with a universal remote. (Note: if the TV is newer than the remote (or released less than 6 months before the remote was programmed), the remote codes for your TV may not be included.) Since the code lists on universal remotes do vary depending on the age and model, please give more information than just the brand. GE remotes usually have a version code label in the battery compartment. This version code is needed to look up the correct code lists. Some GE universal remote built by Jasco codes are here: https://byjasco.com/support/ge-universal-remote-codes.
The Proscan 19LA25Q was probably built in 2007, since there are reviews from 2007. That was also the year when this size TV had to have an ATSC tuner. So if your remotes were programmed before July 2007, they may not be compatible. Some of the current Proscan TVs probably use the same parts as some Sylvania, RCA and Curtis TVs.The 19LA25Q was warranted by On Corporation which has control of the RCA brand now. However, I don't know when they bought the label.
Amazon lists a few direct replacement remotes for the 19LA25Q. See https://www.amazon.com/Original-Proscan-Control-E20F-19LA25Q/dp/B00KQVDRNK and https://www.amazon.com/PROSCAN-Replacement-Remote-Control-19LA25Q/dp/B009H5QVIO . Remotes.com also has a replacement remote: http://www.remotes.com/SearchResults.asp?Search=19LA25Q .
I hope this helps.
Apr 21, 2017 | Proscan 19LA25Q 19 in. LCD Television
None of the Proscan TV codes I have work In My COX universal remote
Than the COX universal remote dose not work with the Proscan tv.Try website like Remotes.com to buy the same exact to the original Proscan tv remote.
Oct 18, 2010 | Proscan 32LA30Q Television
Does anyone have the At&T U-verse remote codes?
Here is the list of universal remote codes given by PROSCAN in your owners manual. I hope this helps you with your problem. UNIVERSAL REMOTE CONTROL CODE LIST
For Universal Remote Control brands listed below, please use accompanying Proscan codes
and refer to your Universal Remote Control User Manual for basic instruction for changing TV code to
operate Proscan model.
Proscan codes for Sony TV=8003,8012
Proscan codes for Philips TV=1005,1006,1007,1035,1064,1216
Proscan codes for other universal remotes=272,132,134,116,040,016,024,056,019,262
May 18, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
I can't program a Direct TV remote for Proscan TV
Found these codes on the website for PROSCAN. www.oncorpus.com, for youmodel television.I hope this help you with your problem. UNIVERSALREMOTE CONTROL CODE LIST
May 16, 2009 | Proscan 32LA30Q Television
Proscan universal remote
Found these codes on the website for PROSCAN. www.oncorpus.com, for you model television.I hope this help you with your problem. UNIVERSAL REMOTE CONTROL CODE LIST
Feb 17, 2009 | Proscan 32LA30Q Television
No remote
If the TV is in fact an RCA (Proscan is an RCA brand), you can buy an RCA universal replacement remote and it will work the TV right out of the package. Depending on the TV model, some features may not be accessible with a universal remote, though. The original TV remotes sometimes have function buttons that the universals don't. But all basic functions would be available.
Jan 02, 2009 | Proscan PS35130 TV
Lcd 32" proscan need code for universal remote
Wow it took me a couple hours but hey i found the code ever1 needs and its a 5 digit code for comcast remotes with the red ok button the codes r 10090 or 10030 hope ive helped u out good luck
Oct 19, 2007 | Proscan 32LA30Q Television
Coaxial input only
I had the same problem... lost the remote. I was able to buy a replacement cheap at http://replacementremotes.com/
Here's the page that describes it:
http://www.replacementremotes.com/store/productdetailp.cfm?productid=780&categoryid=110
But they say they no longer carry it. Sorry. They also say these universal models will work with it:
MODEL: CRK83C1
PN: 221114
Can Use the generic RR62A, Proscan, RCA,GE, Proscan, PN: 221114, Model: CRK83C1, 221112, 240895, CRK83A1, 221114
Aug 29, 2007 | Proscan PS20105 TV
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
