Question about Canon MX300 Office All-In-One Printer
Fax cord lost
I lost the cord for my isdn fax facility Would like to buy a new one
    Scholar:
  • 65 Answers
I think that that is a regular phone line type cable/wire. Check with your owners manual to be sure. If you have misplaced your owners manual then follow this link to download it. http://www.crutchfield.com/S-lYwGyrh5jMw/p_280MX300/Canon-PIXMA-MX300.html Looks to be a regular USB cable to connect printer to computer. If still unable to determine if this is the correct cable call Canon customer service at 1-800-385-2155
Hope this helps. Ratings are very important to us so I want to thank you in advance for taking a moment to rate my response.
Matt
Posted on Jan 15, 2009
Hp m2727nf does not recognize incoming fax calls. problem occurs in switzerland with analog port on isdn line. research for problem with swisscom engineer shows, that m2727 works with isdn nt V1 - V3 and...
Hello walter727, could you find a solution to your problem? I have the exact same machine over ISDN in Switzerland. My ISDN line had some changes and the fax won't pick up calls anymore.
Oct 07, 2010 | HP Laserjet M2727nf Multifunction Printer
Lost AC plug-in power cord. Is it possible to
What fax machine?. if it looks like a computer power cord plug, that's what you need.
Feb 23, 2010 | Office Equipment & Supplies
How do i find out what modem to use for my win
Any internal or external modem less than 10 years old will support FAX-ing through it.
Telephone wall jack <--- telephone splitter --> telephone cord <--> modem
Telephone wall jack <--- telephone splitter --> telephone-cord <--> ISDN adapter.
Dec 08, 2009 | Dell Computers & Internet
Is the hp 920 fax machine digital or analog>
It is analogue.
If you are having problems connecting the fax , see this HP answer to trhe FAQ "How to connect your HP Fax to a ISDN, ADSL and PBX line":
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00294905&lc=en&dlc=en&cc=uk&product=60009
Aug 18, 2009 | Office Equipment & Supplies
Self test
not sure but if when you lift the handset do you get a dialing tone? if not usually cheaper to buy a new fax maybe the modem is faulty
Dec 01, 2008 | Samsung SF-340 Plain Paper Inkjet Fax
One line two Devices
WinFax will support two modems, but I believe only one ISDN device. So, you can't use both ISDN and analog fax modem at the same time.
Nov 24, 2008 | Symantec WinFax Pro 10.0 for PC
Fax
To test your fax setup
1 Press Setup.
2 Press 6, and then press 5.
This displays the Tools menu and then selects Run Fax Test.
The HP all-in-one displays the status of the test on the color graphics display and prints a report.
3 Review the report.
– If the test passes and you are still having problems faxing, check the fax
settings listed in the report to verify the settings are correct. A blank or
incorrect fax setting can cause faxing problems.
– If the test fails, review the report for information on how to fix any problems
found. For more information, you can also see the next section, The fax test
failed.
4 Press OK to return to the Setup Menu.
Make sure you used the phone cord supplied in the box with your HP all-in-one
to connect to the telephone wall jack. One end of this special 2-wire phone
cord should be connected to the port labeled "1-LINE" on the back of your
HP all-in-one and the other end to your telephone wall jack
This special 2-wire cord is different from the more common 4-wire phone cords
you might already have in your home or office. Check the end of the cord and
compare it to the two types of cords shown below.
If you used the 4-wire phone cord, disconnect it, find the supplied 2-wire cord,
and then connect the 2-wire cord to the port labeled "1-LINE" on the back of
your HP all-in-one. For more information on connecting this phone cord and
setting up your HP all-in-one for faxing, see Fax setup.
If the supplied phone cord is not long enough, you can extend it. For
information see The phone cord that came with my HP all-in-one is not long
enough.
● Try connecting a working phone and phone cord to the telephone wall jack
that you are using for the HP all-in-one and check for a dial tone. If you do not
hear a dial tone, contact your telephone company and have them check the
line.
● Other equipment, which uses the same phone line as the HP all-in-one, might
be in use. For example, you cannot use your HP all-in-one for faxing if an
extension phone is off hook, or if you are using your PC modem to send an email
or access the Internet.
● The phone line connection might be noisy. Phone lines with poor sound quality
(noise) can cause faxing problems. Check the sound quality of the phone line
by plugging a phone into the telephone wall jack and listening for static or
other noise. If you hear noise, turn Error Correction Mode (ECM) off and try
faxing again. For information, see Use error correction mode. If the problem
persists, contact your telephone company.
● If you are using a digital subscriber line (DSL) service, make sure that you
have a DSL filter connected or you will not be able to fax successfully. The
DSL filter removes the digital signal and allows your HP all-in-one to
communicate properly with the phone line. Obtain a DSL filter from your DSL
provider. If you already have a DSL filter, make sure it is connected correctly.
Make sure your HP all-in-one is not connected to a telephone wall jack that is
set up for digital phones. To check if your phone line is digital, connect a
regular analog phone to the line and listen for a dial tone. If you do not hear a
normal sounding dial tone, it might be a phone line set up for digital phones.
● If you are using either a private branch exchange (PBX) or an integrated
services digital network (ISDN) converter/terminal adapter, make sure the
HP all-in-one is connected to the port that is designated for fax and phone
use. Also, make sure that the terminal adapter is set to the correct switch type
for your country/region, if possible.
Note that some ISDN systems allow you to configure the ports for specific
phone equipment. For example, you might have assigned one port for
telephone and Group 3 fax and another port for multiple purposes. If you
continue to have problems when connected to the fax/phone port, try using the
port designated for multiple purposes; it might be labeled "multi-combi" or
something similar. For information on setting up your HP all-in-one with a PBX
phone system or ISDN line
you may also refer to the manual for this unit here
if you go there please refer to page 82 of the manual or chapter 10
Aug 02, 2008 | HP Photosmart 2710 All-In-One InkJet...
Lexmark x6150 unalbe to fax phone line is active using dsl
Hey Tony - Did you recently hook this up to the DSL for the first time? This unit is supposedly not able to work with a DSL line.
The fax modem in your AIO is an analog device and cannot be used on an ISDN, DSL, or PBX digital phone service. However, you can connect certain devices to your AIO that let you use the fax function in addition to these digital phone services.
To connect without an unsupported line:
Connect an active telephone cable from the AIO to the telephone wall jack.
To connect with an unsupported line:
If you use an ISDN phone service, you can connect to an analog telephone port (an R-interface port) on an ISDN terminal adapter.
For more help and to request an R-interface port, contact the ISDN provider.
If you use a DSL (Digital Subscriber Line) phone service, you can connect to a DSL filter or router that will allow for some analog (rather than digital) use.
If you use a PBX phone service, you can install an analog phone line for a fax machine.
If this was working on the DSL let me know. I don't know the location but obviously a separate phone jack is the easiest. Let me know. If this helps you fix it you can rate this as fixed. If you are just going to rate this as helpful I'd rather you please not rate it and just add a comment and say thanks for the info.
If you need more help just add a comment and I'll be glad to assist you further. Thanks.
Jeff
May 09, 2008 | Computers & Internet
Could not receive and send Fax
Sending faxes and revieng faxeng through a pbx you need te configure the pbx and youre fax too.( Dail a 0 before youre messages! ) You have to connect always on the pstn line on the 210sf even if you use a pbx.
The Ricoh spc210sf isn't supporting an pbx on isdn line!! Watch out for this because the isdn line is working on 24Volts!! Then you can blow youre fax modem of the spc210sf .
You can contact me true email= r.trip@alice.nl
Let me know is you encounter new problems?
Greetz
Richard Trip
Jan 16, 2008 | Ricoh Aficio SPC210SF All-In-One Laser...
Canon MX300 Office All-In-One Printer Logo
64 people viewed this question
old marine
old marine
