Question about Samsung PCN5425R 54" Rear Projection Television
HELP Please. Symptoms seem so similar to this unit.
I have a Samsung PCN5425R 54 in. Rear Proj. TV. My brother and I both purchases the same TV's back in 2003. About a year or so ago his screen started to become distorted and the picture appeared to curve horizontally across the screen and when we went into set-up menu we could see the various color lines in convergence and it would not allow us to align them up properly. Auto focus would not solve his problem either. He got rid of the TV before getting it fixed because he continued to watch it that was and eventually he heard a pop and smelled smoke. I felt I was fortunate because mine worked perfectly. That is until this morning. When I turned it on the picture was distorted the same way except it appears that when I go into convergence menu the blue looks like it is okay. All of the blue text and blue crosses are perfectly positioned and I can see red text that is across the screen like a wave it ripples across the screen. When I go into the red it looks so much worse and I cannot get the crosses to line up at all. Not even close. It looks as though by the amount of posts on this TV, this is a major problem with this unit. I am very good at electronics and have soldered parts before, I am hoping there is a relatively easy and inexpensive way to fizx it. I have been cursed over the last 6 months with a few major catastraphies in my family's life, We almost lost my wife to flesh eating bacteria this year as she underwent over 8 operations and skin graphs. Normally I would just call a repairman or buy a new TV but that is not an option at this time. I would greatly appreciate anyone's assistance in helping me figure out how to fix it. Where to get the proper parts, etc. I suppose I should also not turn it on anymore so that it doesnt damage anything else? Please Help. Thank You Jeff
  • Anonymous Jun 19, 2007
    I guess I came to the wrong site for my TV problem. Based on what I have read I feel it needs that new numbered convergance board for $81 but hait to just speculate and purchase it. I was hoping an expert would help me resolve my issue. Guess my guaranteed $19.95 was just a waste of time and money.
  • 398 Answers
This sounds as if one of your convergence IC's has shorted out. There should be 2 large black IC's on a heat sink, probably labeled STK392-040. There is a small fuse next to each IC that looks like a small resistor. The IC that controls red-red-half green is bad, leaving the blue where it should be. Replace that IC and its fuse and your picture should return to normal.
Posted on Jun 29, 2007
SOURCE:
After replacing convergence board, now tv will turn itself off when I try to manually adjust the convergence Red cant seem to get it to move, samsung pcn5425r proj tv, is there something else I need to do...
You probably also have a bad digital convergence box. I have a tip at http://www.fixya.com/support/r4273935-replace_digital_convergence_box which explains how to fix the problem and where to get the parts. Let me know if you need more help. Thanks for using FixYa and for the generous rating.
hardrocko
May 09, 2010 | Samsung PCN5425R 54" Rear Projection...
Samsung 52' TV Is showing red
MY SAMSUNG TV MODEL NUMBER LE32R87BD IS DISPLAYING A RED FLASHING LIGHT ON THE POWER BUTTON AT THE FRONT OF THE TV THERE IS NO PICTURE PLUS IT WONT TURN ON CAN ANYONE ASSIST ME WITH THIS PROBLEM
Feb 06, 2009 | Samsung PCN5425R 54" Rear Projection...
Samsung 46inch rear pro
Hi..not sure where you are but where I live it cost $250.00 to repair the DMD (Digital Mirror Display) board or $970.00 to replace it. I would check at the store you purchased your TV at or even look in the yellow pages.
Mar 23, 2008 | Samsung PCN5425R 54" Rear Projection...
Samsung Rear Projection screen went out.
MrPeab,
Where did you purchase the convergence amps previously? Your set takes two STK392-040 Sanyo amps and there is a high probability that that is the problem here again. The convergence amps for these units are really critical and chinese knock-offs are abundant. Is it possible that you didn't get Sanyo originals?
Another thought is what about the heat sink used when they were installed? Did you do the installation or have it done professionally?
Bill
I doubt seriously that unplugging the unit will have any affect.
Jan 30, 2008 | Samsung PCN5425R 54" Rear Projection...
Tv problem samsung PCN5425R 54 in.
Very easy repair....Just replace the convergence amp board part# BP95-00142E (about $80) It includes both convergence IC's and associated components (Five connectors,one screw,easy access)no soldering...
Sep 20, 2007 | Samsung PCN5425R 54" Rear Projection...
My 54" PCN5425R TV will not turn on
You will need to locate the convergence amp IC's, the STK392-040, and replace both of them. The originals IC's can be ordered here http://www.mcminone.com/search.asp?keyword=STK392-040&btnSubmit.x=4&btnSubmit.y=6 Good Luck
Jul 25, 2007 | Samsung PCN5425R 54" Rear Projection...
Samsung PCN5425R decided not to work this evening.
I've the schematic digram i can share it what's you email...?
Jul 16, 2007 | Samsung PCN5425R 54" Rear Projection...
Convergence: concave picture with double image
An easy replacement on the Samsubgs is to replace the convergence board. If you are doing this yourself it is just a plug in board. Here is a link for the part number and how to purchase it. http://www.partstore.com/Part/Samsung/Samsung/PCN5425/Samsung/Samsung/BP9400383A/New.aspx
Apr 09, 2007 | Samsung PCN5425R 54" Rear Projection...
Open Questions:
Samsung PCN5425R 54" Rear Projection Television Logo
95 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
