Question about Schiller Welch Allyn Cardiovit At 2 Interpretive Ekg Machine
Machine will turn off on me
I try to do a ekg on a patient and the machine will go off please explain what to do thank you
    Problem Solver:
  • 6 Answers
Or dirty pole connet cord shall cause you chang expensive batt,try take it out for new outlet charger and inspect said point !
Posted on May 27, 2013
    Problem Solver:
  • 17 Answers
Greetings. there is an internal fuse that is blown, and you battery is depleted. The AT2 will shutdown when the paper drive starts when the battery is weak enough. Your unit needs a battery and a PC board repair. The fuse is not operator changeable, nor is the battery. . Unfortunately, there is nothing you can do with one exception: Try a new lint cord, and make certain that the green AC LED is illuminated when the unit is plugged in. If so, try keeping the unit plugged in for a few hours. If proper operation does not come back, you have internal problems that require a skilled electronic/biomedical tech to re-mediate. In that case you should seek professional assistance in the dis-assembly and servicing of your unit.
Posted on Nov 21, 2011
There is an internal battery in this machine. Machine reads that first. You need to replace that battery. It is almost $30.
Posted on Jan 23, 2009
How do I calibrate a MAC 1200 EKG machine?
First thing is first.
Hook your ekg machine up to simulator. Run an ekg using the simulator as a patient's heart. If you get a clean 12 lead printout with the interpretation reading "normal sinus rhythm" then I doubt that you need a calibration. If you get something else, I will need to know what it is that you got. there is no true "calibration." If there are issues, they are addressed. Otherwise, you are good to go. Keep me posted,
Discount Cardiology- The ekg machine experts
Nov 15, 2011 | Ge Medical Systems Ge Marquette Mac 1200...
My Cardioline Delta 1 Plus EKG Machine is reading message " himem error" what does that mean?
First of all, the Cardioline Delta 1 if defective would require shipment to Italy for repair, parts and technical information is at a premium this sid eof the atlantic on that particular model. In this case you might be able to resolve your problem by clearing your directory. Acording to Cardioline technical support, that *may* refer to a directory full situation. If you have a copy of your operators manual, refer to it regarding clearing your patient directory and deletion of all the patient data files. Note that doing so will permanently destroy any saved patient data, so print out anything that is important first. I cannot personally vouch for the accuracy of this information, as we have not sold a Delta 1 in many years, and ill admit to being rusty. In fact the tech support engineer was also unfamiliar with your error message, so this amounts to a *very slightly* educated guess. I hope it helps.
Nov 03, 2011 | Schiller Welch Allyn Cardiovit At 2...
My AT-2 plus EKG suddenly stopped transmitting from the electrodes, i.e. all the leads show flat line. My e-mail is alaronov@mac.com
hi,
You have to check the patient cable of you machine first. you have to check the LF (left foot ) lead of the cable. if there is any other cable you can try it with that. if there is any other ecg machine you have which has the same connector. then try with that also. if the cable found faulty then replace it. Is there is any trace ( line trace ) in the paper for lead 1 to v 6 if not , the problem is with thermal printer of you machine. if so you have to contact the nearest schiller authorized service center. Because the thermal printer head is not available in the open market.
ok
Mar 31, 2011 | Schiller Welch Allyn Cardiovit At 2...
Welsh allen at-2 lead light is on however ekg machine will not give tracing
hi,
There is some problem with the patient cable. Any one of the lead is broken inside. AT2 senses the presence of all the lead first and then only it will acquire the ECG and store it in its memory,after that it will print the ECG.
If any one of the lead have some problem. it will not go to the next procedure. and will indicate the lead off light.
1. check are you connected the lead correctly.
2. clean the electrode properly.
then try one more time. if problem remains. you have to replace the patient cable.
ok
Feb 04, 2011 | Schiller Welch Allyn Cardiovit At 2...
We have following errors on Siemens BURDICK E350 ECG apparatus: ECG machine not write properly on lead V2 Paper jam accurred skipped 2 ECG paper instead of 1 case. Please help how solve the errors on...
we have a burdick e 350 ekg machine i can put the patient info with no problem
but when it comes to doing the ekg i get an error across the screen that says u1 or uI please help thanks
Jan 24, 2011 | Medical
Ekg machine states left leg fail, but none of the leads are reading anything. works sometimes, but does this occasionaly. Does anyone else have these complaints?
hi,
ur machines patient cable have some problem in its left leg lead ,it may be broken inside. no ecg will come if any of the lead have problem. machine sences all the leads is it proper or not , then only it will process th ecg and give printout. u have to replace the patient cable of ur machine. or try to replace the left leg lead if it is repairable one type patient cable.
ok
Jan 10, 2011 | Life Science Bionet Cardiotouch 3000 12...
How do i know if my ekg is interpretative?
Sometimes you can print out a report even though you are not connected to a patient. If a report prints out you will see "interpretation" on the top middle of the page. If interpretation is not there it most likely means you do not have interpretation. You could also call welch allyn and give them the serial number. They will be able to tell you.
If you have further questions you can contact me at wats@mesasales.com or through our website www.overstockme.com
Jul 18, 2010 | Schiller Welch Allyn Cardiovit At 2...
Cant read EKG Strip
I suggest opening unit and cleaning all mechanics first. For more suggestions I need Mgfr. & model number.
Feb 11, 2010 | Medical
I ahve a schiller welch allen EKG machine, and now it only prints
If it stops printing completely in the middle of doing the print, it is because the battery is bad and needs to be replaced.
If it only prints some of the leads but it does print the full report it is because you have the leads mixed up (Wrong spot on the patient) or the leads are mislabeled or some of the clips or electrodes are bad.
I can fix these. Let me know if you need help.
Apr 05, 2009 | Schiller Welch Allyn Cardiovit At 2...
Schiller Welch Allyn Cardiovit At 2 Interpretive Ekg Machine Logo
521 people viewed this question
Top Schiller Medical Experts
Electro Med Services...
Jim Goldsmith
Jim Goldsmith
Are you a Schiller Medical Expert? Answer questions, earn points and help others
