F843 front load samsung washer showing SE
My problem is that when setting was done and when it reached certain number of minutes for the setting you have set, it will stop and will show SE on its indicator. Why is that? Thanks for your help and I dont know what to do, my dirty clothes are piling up.
  • 15,935 Answers
The timer is likely failed - however it is not seperately serviceable on this unit - replacement of the ECU is recommended.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Affinity ATF7000e front load washer cycle selector not working
Good Morning Cesar, thank you for allowing me to assist you!
First, let's try reprogramming the washer. This can be done by either unplugging it or flipping the circuit breaker to the off position. It is important to wait roughly ten minutes and then turn the unit on. If the issue continues, then the unit may possibly be experiencing a communication issue with the control board, a potential wiring failure or a worn or damaged push button(s). Because it could be a number of any one of several underlying causes, I would recommend reaching out to an expert to properly diagnose and repair the unit.
Sep 10, 2013 | Frigidaire Affinity ATF7000E Front Load...
Affinity only works on delicate
Hello Ed - Often when a washer only works on a certain cycle, it is because the unit could possibly be experiencing a potential wiring failure, a communication with the control board or faulty timer. Let's try resetting the unit by unplugging it or flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn on the washer. If the issue persists, then at this point I strongly recommend reaching out to a professional to narrow down the precise issue before investing in parts that may or may not be the root cause. You can often locate a qualified service provider through the manufacturer website.
Jun 24, 2013 | Frigidaire Affinity ATF7000E Front Load...
I have samsung front loading f843 washing machine, when i start the inlet water and select the programs Cotton > 800 RPM > Prewash / Rinse / rinse hold, the water starts coming out automatically and...
SORRY but when you add additional water from a hose you are defeating the machines function .get the machine properly repaired by a repair service is all I can suggest .
Sep 20, 2017 | Samsung Washing Machines
SE keeps appearing on the machine
Hi.... SE on a samsung front load means you have a problem with your drain pump ... something is in the pump stoping it from draining or you need a new pump
Mar 29, 2011 | Samsung WF317AAG Front Load Washer / Dryer
It is showing an SE error code. Trying to find it in my trouble shooting book. Cant find anything
That code (5E, not SE) means the drainage is clogged. The code appears after 15 minutes of trying to drain the tube (not sure that´s the word, may be turbine, barrel...). check the lateral filter (a big plastic twist-off cap) for any solid that may be clogging the drainage
Feb 06, 2011 | Samsung SW62ASP Top Load Washer
Hi my samsung is reading either 5E or SE help!
check the back of the washer for a tech book. it should be taped to the back. in there it will show codes for that model.If not call 1-800-samsung.they can look it up
Feb 28, 2010 | Samsung WF337AA Front Load Washer
Frigidaire Affinity ATF7000E Front Load - shows pau and the number of minutes left
Its an issue with the front door sensor and the motherboard. I had to replace the mechanism since it could no longer work. Cost me 250 and almost 2 years later its happened again
Sep 15, 2008 | Frigidaire Affinity ATF7000E Front Load...
Samsung f843
LE is error saying hall sensor in motor is bad
Jun 02, 2008 | Samsung WF203ANW Front Load Washer
Washing Machines Logo
99 people viewed this question
Top Washing Machines Experts
