Question about Olympus Camedia D-395 Digital Camera
Does not turn on properly, says no picture
Mode menu is the only part of the menu that comes up, then only card setup, and setup comes up next,no matter what you change still no picture, plus you can no longer turn it on by sliding the lens cover over but rather by pushing quick view
Do i have to download a program to get the pictures from the camera to my computer.
Posted on Apr 15, 2009
I have a Nikon cooplix L18, I took a pictures with the date on, I want to print without date How can I do it?
From the Setup menu, select Date Imprint and turn it off. This will keep the camera from putting the date into the picture area in the future. It will not affect pictures you've already taken.
To get to the Setup menu from the Easy Auto mode, press MENU.
To get to the Setup menu from the other modes, press MENU to bring up the shooting menu, then use the multiselector to select Setup and press OK.
Feb 15, 2011 | Nikon Coolpix 4200 Digital Camera
Tip
How to Format a Memory Card with a Nikon D700
1) Insert the memory card you wish to format into the Nikon D700's body using the memory card slot on its' right side. Make sure the power is off before you insert the card and that you place the card in correctly. The D700 will only accept CF cards, so make sure you have this type available.
2) Turn the camera on with the power switch. Only do this after you have inserted the memory card and closed the memory card slot.
3) Press and hold both the Trash and MODE buttons down for about 2 seconds. Together, these are known as the 'Format' button. The Trash button is located on the back face of the D700 body next to the Preview button, and the MODE button is located on the top of the D700 body next to the shutter button and power switch. If done correctly, the letters 'For' should appear blinking in the shutter-speed sections of both the view finder and control panel.
4) Press and hold both the Trash and MODE buttons again to format the memory card. This will delete all photographs on your memory card and format it. Do not turn off the camera or remove the memory card while the card is being formatted. If you do not want to format the memory card, simply do not press the Trash and MODE buttons the second time and wait for the blinking 'For' to disappear, which it will do after about 6 seconds.
5) Wait until the blinking 'For' disappears. The display will now show the full amount of photographs that can now be taken on the formatted card.
6) Alternatively, you can also format your memory card from the Setup Menu in the D700 LCD menus. You can access this by pressing the MENU button on the back of the D700 body, selecting the Setup Menu and pressing Format Memory Card, OK. This will format your memory card immediately.
on Jan 10, 2015 | Nikon D7000 Digital Camera
Hello, How do I format my Lumix camera card? I have a folder on it called "found" that I cannot delete. thanks
Turn on camera, put camera in viewing picture mode. press menu/set, navigate to setup. on page 4 of setup, you have an option to format your memory card.
Jan 03, 2011 | Panasonic Lumix DMC-FZ18K Digital Camera
Shutter button does not respond to push. If D-90 camera is turned on, what is the most likely error I am making? Allan Fork afork1@aol.com
There are several possibilities.
Do you have a memory card installed? By default the camera locks the shutter release if no memory card is installed. Install a memory card if you have one, or change Custom Setting F6 to "Enable release" and see if you can take a picture.
What release mode are you in? If the camera is set to one of the remote release modes, it's waiting for an infrared signal from the ML-L3 remote release. Turn the camera off and on again, then try to take a picture.
What focus mode are you in? In AF-S, the shutter will not release until focus is acquired. Try turning off the autofocus (there's a switch just below the lens release button) and see if you can take a (probably blurry, but who cares?) picture.
Does the battery have sufficient juice? Press the menu button, navigate to the Setup Menu, then select Battery Info. If it's below 10%, I'd charge the battery. Of course, if the menu doesn't come up on the screen, that would tell me that the battery probably needs to be charged.
Is there a lens attached? What type? Certain older lenses and others lack the electronics to fully support newer digital cameras. With such lenses, you have to switch to Manual mode. Turn the mode dial to M and see if you can take a (probably an improperly exposed, but again, who cares?) picture.
Are you getting any error messages? If so, or if none of the above apply, then the camera may need service.
Jan 02, 2010 | Nikon Cameras
How do you transfer internal memory to memory card
-Turn On camera
-Press menu button and look for setup menu
-Under setup menu Look for the word image storage then Press Ok button
-Under image storage choose Internal memory then press Ok Button
-Now if your setting is in internal Memory turn Off camera.
-Turn On camera again
-Press review Button to show pictures in Internal Memory
-Press Menu button then Choose Copy.
-Now under copy wil provide three option copy ALL/PICTURE/Exit
-If you wnat to transffer all the pictures to you memory card choose all if selected picture just choose picture.
-Now your picture in internal memory is in your memory card
_Note; You need to set your iamage storage to Auto again for you to able to access or used the Memory card
Nov 08, 2009 | Kodak EasyShare C653 Digital Camera
Olympus u790sw unable to view photos / download
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup - right arrow to Format- You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
Apr 02, 2009 | Olympus Stylus 790SW Digital Camera
Lost pictures
Lost your photos on Android phone & need to recover deleted pictures, try GT Recovery for Windows- the World's 1st Data Recovery Software for Android smart phones.
It can directly recover deleted pictures, photos lost due to deleting, restoring factory settings, flashing ROM, rooting, etc., from SD cards inside Android devices. It let you preview the deleted photos before recovery. Watch the video tutorial to learn how to retrieve photos from Android phone easily with simple clicks.
Key features of Data Recovery - GT Recovery for Android:
1). Preview & selectively retrieve photos and video lost due to any problem
2). Support all Android phones/tablets, like Samsung, HTC, LG, Motorola...
3). Only read and recover the data, no personal info leaking, 100% safe
Jun 28, 2008 | Canon PowerShot A530 Digital Camera
Picture screen
You can choose whether or not to display the picture you have just taken on
the monitor.
ON : The picture being recorded to the card is displayed. This is useful for
making a brief check of the picture you have just taken. You can
resume shooting anytime during REC VIEW.
OFF : The picture being recorded to the card is not displayed. This is
useful when you want to prepare for your next shot while the
previous picture is being recorded.
1 In the shooting mode top menu,
select MODE MENU
 SETUP
REC VIEW  OFF or ON, and press
Jun 25, 2008 | Olympus Camedia C-350 Digital Camera
I cant see my pictures
Can you check the card by a car reader in the computer- or some one else computer? Failing that Format the card in the camera then have a try Come back let me know how you get on
Jul 21, 2007 | Olympus FE-230 Digital Camera
Can't Upload Pictures
What kind of system are u using? Mac or PC? What version of windows? If you are using their photoloader software please check the following: In picture taking mode press menu Go to setup tab Go up to USB press right arrow and highlight mass storage. press set. try that. If that doesn't work then try this: In picture taking mode press menu Go to setup tab Go to USB press right arrow highlight PTP press set. This will allow you to chose which program to open with. Chose the Microsoft scanner/camera wizard and then just follow prompts.
Aug 07, 2006 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Olympus Camedia D-395 Digital Camera Logo
61 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
