Question about Maytag Atlantis MAV6000 Top Load Washer
Where is the fuse located on matag washer LATxxx machine filled
The Maytag washer filled won't agitate, spin or drain
I located the fuse all by myself, the fuse was OK, It happens to be the safety system for the lid. After the machine fills up and it doesn't go into the cycle, I just get a small scerw driver and puch on the latch.
Posted on Jan 24, 2009
After troubleshooting ,it was found that the door switch is faulty. jumped line termial and machine terimal on lid switch, machine starting filling with water. problem solved.
Posted on Jan 21, 2009
  • 61 Answers
Yes there is a fuse disconect the power remove he 2 inner philips screws from the top of the control panell you will see a small rectangle pice with a fuse and a2 switches this is a lid switch asmbley you need to replace this hole pice if you just replace the fuse it will do it again
Posted on Jan 20, 2009
Maytag heavy duty super capacity washer - stopped mid cycle. Won't drain water. Won't agitate. Water fill function works. Any ideas what to check? Do you know where the fuse is located?
It is a computer problem. My daughters machine did the same thing and the company came out and replaced the computer board and it fixed the problem.
Jul 16, 2011 | Maytag Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Maytag will agitate instead of spin
http://allrepairmanuals.com/maytag-washer.htm?model_number=MAV7901AWW
Please download, the above, service manual, use the troubleshooting procedures, you should be able to locate and repair your problem.
May 05, 2010 | Maytag Neptune Washer
Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
May 17, 2009 | Washing Machines
Matag washer may be leaking, esp when in use.
Remove the front panel from the washer. Fill the tub with water and then set it for spin.
Look for water coming from the machine. If so, report back as to where the water is coming from.
If no water is coming from the machine......
While the water is pumping out, look at the drain line in the wall and see if it backs up.
If so, call a plumber to clean your drain lines.
Mar 04, 2009 | Maytag Washing Machines
Matag Atlantis MAVT634 will not agitate
Does the motor start and run for agitation with the belt connected?
Jan 29, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer will not spin
If your washer does everything but does not spin, it is your outlet filter which is blocked. Locate this and clean out, it has to work fine. Refer user's manual.
Jun 02, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
435 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
