Question about Epson RX620 All-In-One InkJet Photo Printer
Scanner wont work on our epsom rx620
Printer will work but scanner wont work says its not connected to computer wont reconize it but it will print if you go onto scanner you cant then get it to print can you help please
  • elaineparr08 Jan 27, 2009
    thank you very much but i think we have fixed it very gratfull elaine
  • The StickMan May 11, 2010
    You will have to go thought that again as I can not understand what you are on about put in some full stops in places please.
    Rgs
    The StickMan
    Habit-Forming:
  • 34 Answers
You might want to try to uninstall all of the printer/scanner software and drivers and re-install it, you can go to Start>settings>control Panel>Add/Remove programs from Win XP, and from Control panel there's a icon called system, open that one and remove the printer from there. if you don't have the CD that came with it or if you want to see if the manufacturer has an updated version of the application you may go to their website to find it, in most cases is the name of the printer's manufacturer with .com ( ie: www.canon.com, www.hp.com, www.epson.com, ect..)
Posted on Jan 28, 2009
Make Epson Photo RX620 print wirelessly
This model printer has only an USB connection.
It is possible to print wireless by connecting the printer to your computer and sharing your printer on your network that is connected to a wireless router.
OR connecting your printer to a wireless router that has an USB port for connecting a printer.
Aug 04, 2012 | Epson RX620 All-In-One InkJet Photo...
My epson stylus photo rx620 has a scanner erro and is not printing
Generally, the 1st best troubleshooting step is to uninstall the printer drivers, unplug the usb cable then download and install the latest driver from the manufacturer's web site, then re-connect the printer when prompted to in the installation of the new driver.
Sep 26, 2011 | Epson Stylus Photo RX620 All-In-One InkJet...
Removed epsom rx600 printer installed lexmark f480 get ocr prob
If you are using MS Vista Operating System then your scanner feature will not work as there is no provision for it in Vista. If you are using MS XP or older, unistall the software from your pc. Detach the device and restart the pc. Re-install the drivers from the cd. DO NOT CONNECT the printer at this stage. Connect it ONLY when prompted or at the completion of installation. Good luck
May 04, 2009 | Epson Stylus Photo RX600 All-In-One InkJet...
Rx 620 slow to print
Epson's RX620 scans and prints photos at high quality. Text, however, was slow to print and not that good.
it_portal_pic_41791_t.jpg Epson's multifunction devices fall into two categories: general-purpose models that are designed for home or small office use, and photo-oriented devices such as this, aimed more at the enthusiastic amateur snapper.
Because it's a photography-centred device, the RX620 uses dye inks. On photo paper, these produce more vibrant colours than pigment-based inks, and a true gloss finish, but on plain paper produce inferior, less vivid results.
The Stylus Photo RX620 is quite large, and looks dated - but it's not short of modern photo-printing features. Its built-in memory card reader is compatible with seven commonly used digital memory formats, including xD and SmartMedia. Photographers using film will appreciate the scanner, with its high optical resolution and transparency backlight.
On plain paper the RX620's text printing showed bandingand rough outlines on default settings. Our five-page black-and-white text document took two and a half minutes to print. Increasing quality settings made it even slower.
We tried realigning the print heads to improve print quality. The RX620's manual process involves choosing the best-aligned examples from four rows of 15 patterns. This takes good eyesight, and it can be hard to choose between similar-looking options. We needn't have bothered - text remained unchanged.
Photo printing was far better. The RX620 produced some of the best prints we've seen from a multifunction device, but only at its highest quality - and slow - setting. Our A4 test picture took 15 minutes 12 seconds to appear.
The RX620's scanner is excellent, previewing an A4 sheet in six seconds and scanning a 6x4in photo at 600 dots per inch (dpi) in just 14.5 seconds. Negative scan times were reasonable, with a single frame scanned at 2,400dpi in 1 minute 40 seconds.
The RX620 can perform many advanced functions without being attached to a computer, and its colour screen has a clear menu system. Prints can be made directly from memory cards, photo prints or even film. There are four document copying settings, but results using the default Text quality are adequate for most office purposes.
The RX620 isn't a brilliant multifunction device. It does many things well, but its printer is too slow, and simply not good enough on plain paper.
Please rate my solution after reading it. Thank you
Feb 27, 2009 | Epson RX620 All-In-One InkJet Photo...
Epsom RX620 Poor quality photo prints
I have got round this problem by routing my pictures via Picasa 2. Printing direct is still a problem, but I think I can live with that for now.
Richard
Nov 18, 2008 | Epson RX620 All-In-One InkJet Photo...
Epsom Rx620 states use originals for ink cartridges
Try to hold down both 'stop' and 'B&W' button when you press the 'on' button to start the printer machine. This should erase the error message and let you print.
Regards.
Gordon
Sep 25, 2008 | Epson RX620 All-In-One InkJet Photo...
RX620 wont communicate via powered USB hub.
on a windows system, go to printers and faxes, delete all icons there. unplug the printer, reboot your computer, then as soon as your computer is up, connect the usb cable... now wait.....
after about 5 mins, check printers and faxes if it has an icon for your printer, if it does then print a test page, if it does not show an icon, try another cable, try another usb port or try it on another computer entirely...
Sep 05, 2008 | Epson RX620 All-In-One InkJet Photo...
Hoe to connect the epson stylus to my computer
Hi Please provide more details.....I'll assume you have an older computer with only the large parallel port to connect to a printer, but the new printer requirews USB printer connection. If this is the case, unless your computer is VERY old, you should be able to buy a USB card to install in an empty PCI slot in your computer, and all should be fine. If you have Windows 98 you will probably have to install drivers. Good Luck!
Jul 10, 2007 | Epson RX620 All-In-One InkJet Photo...
Epsom stylus photo printer 360
Make sure there is enough room for the CD tray to move through the back of the machine. Describe fully exactly whit is is you are trying to do.
Jun 17, 2007 | Epson RX620 All-In-One InkJet Photo...
Epson RX620 All-In-One InkJet Photo Printer Logo
227 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
