Question about Casio Edifice EF106D2AV Wrist Watch
Removing the crown/stem of CASIO EF-321
In which position should the stem/crown be for removal?
What point exacty should be pushed or unscrewed to remove the stem to be able to remove the movement?
I can send a photo of the inside back of the movement where you could put a mark.
  • 1 more comment
  • herpich_akos Jan 16, 2009
    Thanks for the quick reply!
    So, is the setting lever (a piece, which has a small extruding metal point, and is moving when the crown/stem is pulled out/pushed in)?
    To make sure, i have marked it on the photo with the red arrow.
    There is a small opening marked with an arrow pointing towards it, on the left of the marked point. Could you please confirm, which of the two mentioned points is the right one? :)
  • herpich_akos Jan 17, 2009
    Maybe I shall help You by that... :)
    Thanks again for your kind help, everything is fixed and allright!
Other case for a simple Casio quartz watch :
Removing the crown/stem of CASIO EF-321 - ef77e0e.jpg
Posted on Jan 08, 2010
  • 2,334 Answers
There is a tiny point (end of small metal piece called setting lever) on the left side of the stem (on watch movement, very close where the stem is entering the movement).
You have to push that point down with a metal pin or tweezers. Crown (winder) must be pushed in to normal position otherwise you will not be able to put the stem back properly.
So, do as follows:
1) Push the crown in,
2) Lay the watch down on flat surface and push on setting lever point,
3) While holding setting lever pushed in- extract the stem by gently pulling crown out of watch.
If this doesn't work- upload picture here.
Do not forget to rate, please.
Posted on Jan 15, 2009
  • Arturs Kalnins
    Arturs Kalnins Jan 17, 2009
    That small opening with an arrow is the right one. Through that opening you will see the end of setting lever. If you pull out crown and then back in, you will see that end moving. So, put the crown in position that the setting lever end is exactly in that opening and push on it with needle. While holding down, pull out crown with stem.
    Sorry, i cant mark it on your picture as I haven't got any idea how to do that on PC.
How can I change the days in casio Ef 331
First of all avoid setting the day and day of the week between 9.00 pm and 6.00 am. The day and day of the week may not change in the following day if you do.
Try this,
1) Pull the crown to the first click.
2) Set the day by rotating the crown counterclockwise.
3) Set the day of the week by rotating the crown clockwise.
4) Push the crown back to its normal position.
Hope this will help.
Cheers
May 16, 2016 | Casio Watches
Zen
pull the crown out to second position then press start button till it gets to 12 then push crown back in......
Mar 28, 2014 | Casio Edifice EF-527L-2AV Chronograph...
How to wind up an invicta
Unscrew the crown by turning it counter clockwise until the crown is free from the stem. Then turn it clockwise six times. After this step push the crown in and continue turning it clockwise until it is once again screwed back on to them stem. DO NOT SKIP THE LAST STEP because although the watch will operate in the winding position it no longer water proof. A simple drop of water in the stem would mean death for your watch. If you wear the watch everyday I suggest you wind it once or twice a month.
Jan 01, 2014 | Invicta Watches
How do i release the pin crown from my omega f300
There is a small screw (or maybe push-stud) almost in line with the stem entry point and slightly in from the edge of the movement, half unscrewing (or pushing) will release the stem.
Mar 26, 2012 | Omega SeaMaster Watches
I have a F ossil Arkitekt (fs-2990) that is a several years old. I removed the back and the battery to change out the battery and noticed that one of the numeral bars on the face has dislodged itself. in...
The knob that adjusts the time is called the crown, and it will have a stem attached to it. You will need to remove crown and stem together.
If it's a screw-down crown, unscrew it.
Examine the watch mechanism very carefully while pulling out the crown (as if you were adjusting the time) and pushing it back, What you are looking for is basically anything that moves. If you do see parts of the mechanism move, look very carefully around that area for an arrow mark impressed in the metal pointing to a small dip in one of the metal parts.Often, this is on a tiny lever but not all manufacturers bother with the arrow.
Ensure that the crown is pushed back to it's normal position. Put a tiny amount of pressure on the dip (a needle is ideal for this), and carefully attempt to pull out crown and stem.You may need to apply slightly more pressure to get a result, but please take care not to press too hard or you may damage the mechanism.
Hopefully, that should sort it out. To refix the numeral bar, I'd recommend super glue - but you only need a tiny, tiny amount. Apply it with the tip of a needle and you shouldn't go far wrong.
Once you're looking at reassembly, you should be able to reinsert the crown and stem without depressing the dip but do it gently and don't force it - it may need a slight turn to relocate properly before it slides back in.
I hope this was easy to follow - get back in touch if you get stuck.
Sep 15, 2017 | Fossil Arkitekt Watch for Men
Need to remove crown stem on a Aspen wristwatch made in China.
on most movements the is a little arrow pointing to a hole. use a pin and push down and the stem should just pull out. please rate my solution
Oct 10, 2009 | Casio Edifice EF106D2AV Wrist Watch
Stem of watch won't return to its original position
The winding crown is loose on the stem. Get the stem completely out of watch and while holding in vice or pair of pliers screw the crown back on tight. Do not overscrew it, as the stem may brake. Even better would be to unscrew the crown first, dip the threaded stem end in to the Superglue and then screw the crown back. It will prevent from the same problem in future.
Rate, please.
Jul 29, 2009 | Watches
I cant pull out the date/time pin on my luminox 3204. any suggestions?
On some watches - scuba usually - the crown has a rubber seal and that seal is engaged when the crown is screwed to the case. If your watch is like this, you need to unscrew the crown before you can pull out the stem. Twist the crown in a counterclockwise direction several turns. You will be able to tell when it is completely unscrewed because youwill feel spring tension. Pull out the stem to set the watch. When you finish, push the stem back in. Push against the spring tension and carefully thread the crown back onto the case. That should do it.
Jun 12, 2009 | Luminox Navy Seal Dive 3204 Wrist Watch
Remove the winding stem/crown.
So, do as follows:
3) While holding setting lever pushed in- extract the setting lever by gently pulling crown out of watch.
Jan 09, 2009 | Fossil AM3425 Wrist Watch
Tag wk 1113-0
The crown is probably a screw down style. The screw down stem is designed to keep the water out and should be screwed shut when not adjusting the watch. Look at the watch stem from the side, look from the 3 oclock to the 9 oclock, you should see the end of the stem. Now turn the stem counterclockwise. After a number of turns, the stem should pop out a bit, it is now ready to set. Most waterproof automatic day/date watches have 4 positions for the stem:
1: screwed down (locked)
2: unscrewed position A
3: unscrewed position B (stem pulled out to first "click")
4: unscrewed position C (stem pulled out all the way.)
Position A:
This is usually used to wind the watch, although some automatic watches cannot be wound by the stem.
Position B:
Used to set day/date. Turning the stem one direction will advance the day and turning it the other direction will advance the date.
Position C:
Used to set the time. Some watches will "hack," a term used to describe the ability to stop the second hand for accuracy purposes.
Be sure the watch is at least a little bit wound before starting theis procedure or it will not run when you get it set!
Unscrew the stem and pull it all the way out to position C. Now turn the stem to advance the time clockwise. Continue turning until the day/date advances, now you know you are in the AM 12 hrs of the day. It is important not to advance the day/date with the stem during the 3 hours before and the 3 hours after midnight, so go ahead and move the time to 8 am.
Now push the stem in sligthly until you are in position B. Sometimes it is easier to go to position A, the out to position B. Once in position B, advance the day/date until it is set for the current day/date.
Pull the stem out to position C. Adjust the time to one minute past the current time. Watch your reference timepiece until it matches your watch and push the stem in when they match.
Your watch is now set! Screw the crown down and wear it in good health.
Hacking. If you stop the second hand at 0 seconds, and wait for your reference timepiece to reach 0 seconds also, you can set the watch to within a second accuracy.
Movement slop. If you advance the time past the time you wish to set your watch and then "backup" to your chosen time, you will remove the slop from the geartrain and make your watch set more accuretly
Jul 14, 2008 | Tag Heuer 2000 Classic WK1113.BA0311 Wrist...
Casio Edifice EF106D2AV Wrist Watch Logo
5,566 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
