Question about Air Tools & Compressors
Champion vr3-8 auto drain blowing out when compressor turns off
I have a champion compressor VR3-8. Every time the Compressor turns off the Automatic tank drain blows off air through the valve on the upperside. I replace the drain and lowered the pressure to about 100psi still happening.
    Scholar:
  • 169 Answers
If the air continues to come out on top of the drain valve well after the pump has stopped, you may have a faulty tank check valve where the pump discharge line enters the tank. when this valve sticks open it will cause this problem.
Posted on Nov 26, 2009
    Scholar:
  • 89 Answers
IS YOUR TUBING CLOGGED, PINCHED OFF OR MAYBE DIRT-DOBBER NEST IN IT. THE WATER AND AIR IS SUPPOSED TO COME OUT THE SMALL TUBE POINTING DOWNWARDS BUT SOME EXCESS AIR MAY COME OUT THE SILVER VALVE ON TOP. THIS IS THE EXCESS AIR WHEN IT IS UNLOADING AND THE SILVER VALVE IS BASICALLY A TIMER. YOU CAN ADJUST THE DURATION OF THE BLOW DOWN TIME BY LOOSENING THE THIN JAM NUT AND SCREWING IT IN OR OUT. DO NOT BLOCK THE SMALL TUBING OR PINCH IT SHUT, YOUR COMPRESSOR CANT UNLOAD AND WILL START HARD. DONT REPLACE THE WHOLE DRAIN BECAUSE THIS AUTO DRAIN TAKES A REBUILD KIT THAT COSTS AROUND 20.00 TO 25.00 AND IS VERY SIMPLE TO REBIULD. YOU CAN CONTACT ME FOR PARTS, PRICING AND INFO AT JBRIDGERS@CA-EQUIP.COM OR WWW.CANDAEQUIPMENT.NET
Posted on Jan 27, 2009
My Ac picks and drops from the compressor after 3-5mins. it seems like automatic how do I stabilize it
Auto Air Conditioning Repair - Problems and Solutions
www.myautorepairadvice.com/auto-air.html
You will find my answers to most of the AC repair questions that I get from my ... If this debris is pulled into the new compressor it can cause it to fail very quickly. ..... So after it was all fix I went to pick it up and a week later it happen again!
A/C Problem, compressor turns on and off - Nissan Forum
www.nissanforums.com/.../101541-c-problem-compressor-turns-off.htm...
Aug 8, 2005 - 15 posts - ‎10 authors
When I was draining the coolant, my compressor was working like you ... anyway, myproblem is that when I turn on my air conditioning, it will work fine ... hose on the condenser and the pressure drops, system turns on ie works, .... year, maybe I'll even go to my local pick-and-pull and find a good one there.
8 Preventable Causes of AC Compressor Failure - Arista
aristair.com/blog/8-preventable-causes-of-ac-compressor-failure/
Dec 21, 2015 | Heating & Cooling
My automatic tank drain leaks air
The unit could have trash in the valve not allowing it to seat. Relief air and clean. If the unit blows air out for a couple of seconds after the unit shuts down that is normal. That is how the pneumatic valve works.
Apr 18, 2014 | Champion Duplex Air Compressor W/ R-30D...
I have a porter cale C5101 compressor. It hesitate to auto start when the pressure is low, always trip my circuit breaker.
What amp breaker do you have this hooked to. I would use no less than 15 amp ,preferrably a 20 amp. Next do you drain tank after use on a regular basis. If you don't moisture can build up inside tank and cause hard starting on automatic. If you need to drain tank there should be a drain valve on bottom of tank. try turning it counterclocwise with compressor off. If it dosen't turn that way try clockwise,air and moisture should drain. If you have alot of water in tank then shut valve and turn compressor on and bring to full pressure,then repeat draining procedure until no more water comes out. Hope this helps. Thank you
Nov 12, 2010 | Porter Cable - Cable C5101 Oil Free...
Having problems with my champion air compressor
Crankcase vent may be stopped up. Could have too much oil in the compressor.
May 28, 2010 | Champion International Champion 532 2...
I have a champion air compressor that has power but will not turn on? I see 2 wires on the top that look to be disconeccted the are from the pressure switch to the compressor itself
loose wires would probably keep it from working
if you could view a working one at a store you could see how to reconnect the pressure switch.
by being disconnected the compressor probably thinks the pressure switch is open so as to show a fully pressurized tank
Jan 02, 2010 | Champion International Air Tools &...
Champion compressor pops manifold relief on head
depends on what relief valve it is, if it is a 2 stage pump and it is the relief on the inner-stage that is lifting indicates the second stage is not pumping correctly! I would check for a broken valve. if it is the one on the discharge line to the tank, then something is restricting it, check for blockages in the line or in the check valve entering into the tank. Most important you isolate the compressor and drain all air pressure before you attempt any repairs
Dec 29, 2009 | Champion International Air Tools &...
Where can I get the Schematics?
go the web and get the number to dixie sale
Oct 11, 2009 | Champion International Air Tools &...
I have a Champion VR3-8. Tank will not fill with air
By the tube that points down you mean the drain tube to drain water I take it. If so that tube has a valve that must be shut off to allow the pressure to build up. With that valve open your compressor will keep running.
Aug 29, 2009 | Air Tools & Compressors
CHAMPION COMPRESSOR CYCLING ON AND OFF EVERY 10 SECONDS. WHAT COULD CAUSE THIS?
CHECK TO SEE IF THE TANK IS FULL OF WATER FROM NEVER DRAINING THE TANK......IF ITS NOT THIS BUY A NEW PRESSURE SWITCH
Apr 01, 2009 | Champion International Air Tools &...
Cant set my compressor to automatic start/stop mode
Sorry, what do you mean it 'blows off',, the relief valve is letting off pressure ? Sounds like you need to replace it with the proper psi Relief valve or just a new one. Then you say it restarts but in your question you say 'Cant set my compressor to automatic start/stop mode' If it is restarting that means it is automatically 'stopping' then automatically 'starting' Please clarify your question.
Nov 12, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
1,006 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
james allen
james allen
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
