Question about Dell Latitude C400 Notebook
D400 can not find dbay drive
My Latitude d400 will not find the external cd drive.  The tool bar beeps that the drive is installed but it will not show up in my computer.
  • mykrajput Feb 19, 2009
    hi,
    i have dell c400 laptop, its to much simple to install xp
    first you just take out hdd from laptop
    plug in tht hdd in desktop pc by external usb box
    now u just start windows 98 setup in it
    when it started first format ur drive then install it
    when windows 98 setup files copies to 100%. machine need to restart
    u just plug out the hdd and plug in back to laptop
    now the setup will remain start in ur laptop and when the installation complete u just upgrade ur windows from 98 to xp by intalling xp from external drive on OPERATING SYSTEM OF 98 WINDOWS
    NOW WAT U SAY???
    ITS TO MUCH SIMPLE
  • 44 Answers
Do you have a USB drive to try? I have seen those dbay holders go bad.
Posted on Jan 15, 2009
D400 is not booting up from usb
Is your system set up to boot from USB? What is attached? A flash drive or an external cd/dvd drive? If a flash drive, was the software on it created to be bootable? Is this the first time you are trying to boot from USB? Please provide more details.
Mar 01, 2014 | Dell Latitude D400 Notebook
Hi i have this problem with my dell latitude d400,i did some installations some time ago and up till now i have not been able to use usb device on it,my external dock bay i cant use it neither so pls help...
Do you still have this problem if you boot into safe mode? If not, then there is a problem with one of your programs interfering with usb drivers.
If it does still happen in safe mode, then you may need to re-install your drivers. To do this, boot up normally, go to Start/control Panel/System/Hardware/Device Manager. Find your USB section, and right-click the USB Root hubs, and uninstall them. Then reboot, and windows will then detect the usb ports, and reinstall the necessary drivers for proper operation.
Hope that helps.
Cheers from NZ
May 27, 2011 | Dell Inspiron 9100 XPS Latitude D400...
Internal dvd/cd-rom
Looks like the answer is yes. Call to be sure. For prices and availability of parts and upgrades for this system, call 1-800-357-3355. Give them the service tag number and they will be able to tell you for sure.
Assembly 24X CD-RW/DVD Combo Drive Usually Ships 3-4 DaysManufacturer Part# R3117 Dell Part# R3117
Starting Price spacer.gif $109.95
Apr 14, 2010 | Dell LATITUDE D400 D500 D505 D600 D800...
Can i use any external cd/dvd on dell latitude d400?
Any external CD/DVD drive that connects to USB should work.
Feb 07, 2010 | Dell Latitude D400 Notebook
DELL Latitude D400 - what are the series of (blinking) icons?
sometimes this indicate a fault with memory or the system itsef.Before you begin you will have to remove the battery and the ac adapter.Remove the memory modules .Replace the battery and the ac adapter without the memory.Power it on if it comes on and beep several times then the memory is bad.If not remove the battery and the ac once again.Press and hold the power button for twenty seconds to clear the nonvol memory.Replace the memory the battery and the ac adapter.If still no go remove all the same items along with the hard drive and cd rom,Insert the battery and the ac adapter try again.If you hear a beep this time replace the battery(remember whenever you install to remove power).If nothing works and you none of the desired results you will have to replace the motherboard.
Good luck
Jul 16, 2009 | Dell LATITUDE D400 D500 D505 D600 D800...
Sound driver
Select your model on website below to download drivers:
Dell Drivers and Downloads
Mar 04, 2009 | Dell LATITUDE D400 D500 D505 D600 D800...
Need to install software but have no cd drive
Your best bet is going to be an external CD Drive. I assume you have all of the disks that Dell sent with the computer.
You could remove the drive from the laptop, get an adapter that will allow you to connect it inside of your pc, and copy installation files to the drive, and make the drive bootable, but this is not simple. Booting to the Dell CD is simple, and is the easiest. Spend $80 (or less) and get a drive.
Mar 19, 2008 | Dell Latitude D400 Notebook
Help
Look at the picture below. It plugs into the D/Bay connector on the left near the rear of the laptop.
Jan 20, 2008 | Dell Latitude D400 Notebook
Dell Latitude C400 Notebook Logo
Alun Cox
