Question about Konica Minolta DiMAGE Z6 Digital Camera
"System Error" & camera turns off when I try to us the instant playback.
When I try to look at the picture I took, I try to go to instant playback and "System Error" shows on the screen and the camera turns off.
Remove the SD card, use a card reader to view files on your PC. Save any pictures that you want to keep - and then delete the file and also the DCIM parent folder. Once you have done this, try it back in the camera. Worked fine for us after this.
Posted on Jul 12, 2008
  • 3 Answers
I have the same problem. Did you ever get any advice?
Thanks
Posted on May 21, 2008
    Genius:
  • 2,985 Answers
Try for the Technical Support team at Minolta[May be Sony now] you could try to upload images to vomputer to see if they are there I cant say whether this is a camera problem or card problem, what you say
Posted on Jun 17, 2007
SOURCE:
Canon 60D playback images turning up black
Did you switch to Tv (shutter mode) and took pictures for several seconds? like in the dark? Because saving the picture can take as long as the shutter time was.
Before panic. (Actually you never should panic) check your camera in automatic mode. And make sure you did not select any power save action, that puts your display on dark while shooting.
But always be sure your battery is charged and check its capacity. In the menu yo can check under the wrench symbol, when you select Battery info. Page 268 of the manual.
Working with a bad battery can damage the camera in the end.
Dec 27, 2013 | Canon EOS 60D Digital Camera
Canon G10 wont turn on
Try removing the card first and then trying to power up the camera. Cameras often fail to turn on/off when a card goes faulty. Next I would try pushing the playback button, it also acts as a power button but starts the camera in playback mode. If this works it could indicate a problem with the power switch circuit itself. If there is still no sign of life I would suspect a fuse to have blown. They are internally located and very small, you would need to have a service centre try replace it for you. Good Luck!
Apr 13, 2009 | Canon PowerShot G10 Digital Camera
Camera turns on only in playback mode
davidpl i think there is a problem with the memory card try using a diffrent memory card and it will work fine
Feb 22, 2008 | Sony Cyber-Shot DSC-P73 Digital Camera
Lumix tz3
Low battery maybe? Try holding camera firmly in one hand, with camera on and in record mode, and strike in on its edge firmly on the heal of your other hand. This technique is often sucessful with temporary camer 'quirks' like freezing, lens not fully retracting, etc.
Dec 31, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
File error issue
If the images are on the card and transfer OK to computer then we will have to look back to the camera.
You are sure that playback mode is selected correctly - are you?
Check out the hand book for this.
If you are sure - then it would seem to be a fault and the camera should be returned to the seller or the Sony support site contacted with a view to obtaining a replacement
Oct 24, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
DSC-W35 file error
It sounds like the memory stick would be full why not format it and limit your number of pictures to its capacity.  Download pictures to your PC to have more space.
Oct 23, 2007 | Sony Cyber-shot DSC-W30 Digital Camera
Can't take picture
Needs to go back to Panasonic- an inherent fault.
Aug 16, 2007 | Panasonic Lumix DMC-LZ7 Digital Camera
I cannot look through images or even delete them.
Try upgrading the firmware at your local dealer.
Aug 10, 2007 | Canon PowerShot S70 Digital Camera
Camera freezes in any picture taking mode
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. you need professional service to fix it.
Dec 28, 2006 | Gateway DC-T50 Digital Camera
Can't find pictures I took, but camera counts down the number of pictures left
first try to set playback folder to all: Platback menu - Playback fldr - all I am sure it will fix it, if not try diff memory card. good luck.
Nov 09, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
Konica Minolta DiMAGE Z6 Digital Camera Logo
324 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Ekse
Damen Wong
Damen Wong
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
