Question about Kenmore 20172 Top Load Washer
How do I unplug the water pump? - Kenmore 20172 Top Load Washer
  • Mark Egan May 11, 2010
    How do you know it's clogged? Most Kenmore washing machines have a belt that drives the pump and agitator. If the agitator is not working either, then you will need to replace the belt.
    Please provide the complete Model number for additional help. The number is usually found on printed on a tag on the back of the washing machine.
    Champion:
  • 244 Answers
If newer vintage, you have a rubber drive coupling that turns pump. take case of unit (Under concole are2 screws and clips). Take cover off(Unplug lid switch wire harness) and you'll see pump right in front of you. take off two clips to epose coupling. fairly easy job. replace pump while at it.
Posted on Jan 15, 2009
How do I remove the water pump from a model ID1002A-261
Unplug the power remove the front cover, Top, and sides. unplug the wiring harness to water pump. Remove the water supply tube that runs from pump to distribution bar. remove two screws that hold pump to the bracket then lift out.
Sep 09, 2014 | Kitchen Appliances - Others
Won't pump water
UNPLUG PUMP AND SEE IF THE IMPELLER IS JAMED, IF IT SPINS FREE TRY IT WITH A SHORT DISCHARGE HOSE. POSSIBLE BLOCKAGE IN DISCHARGE HOSE WILL TRAP AIR AND WONT LET PUMP PRIME.
Apr 19, 2014 | Cal Pump 5500 GPH Waterfall Pump
Pump won't drain water and keeps faulting for pump cleaning. Have turned it off, unplugged pump filter, cleaned it and restarted it several times with no luck. What else could be wrong??
Check to see if there is a drain filter. My GE has a small "door" at the bottom of the machine that has a filter behind it. If so ALL of the water will drain when you open it so be prepared. Then clean all of the junk from inside the filter or "trap"
Apr 15, 2013 | Washing Machines
We are getting code 37 . we have a top load machine Intuitive model - what does that mean?
37 is slow or no pump out.check that water is flowing out at a good stream.if not then pump is either jambed with debris or blocked.the water needs to be bucketed out as much as possible then tilt machine back against the wall as far as you can so any eccess water is to the back of the tub.With machine unplugged from wall lay down on the floor & unplug wires from pump.release plastic locking tab & twist out pump anti clockwise,remove ant debris.
May 29, 2010 | Washing Machines
Spin cycle does not work.Water does not drain. When I run it, I get multiple beeps. The manuals to turn off and unplug. Repeat if necessary. Problem not solved.
Unplug the machine slide it out and tip back so you can reach under it. In the front corner underneath is the pump with a paddle wheel type fan on it that shpould turn very freely. If it is turning freely and won't pump it is either the pump or motor controller board.
Most likely something stuck in it though, try turning it to free it, If that works pump out the water if you can and then remove the pump. If it won't turn remove all the water you can, tip back at least 45 degrees and disconnect the 2 plugs from the pump (power unplugged first) then remove the pump by turning anticlockwise, it will first move just a little and stop, at this point realse the catch that is stopping it turning further and remove. clear what ever is blocking it. If the pump is rusty or the copper windings appear burnt (will be darker in the middle section REPLACE THE PUMP.
Re fit the pump, make sure it turns freely, if not take it off and try again.
Apr 16, 2010 | Fisher and Paykel GWL11 Top Load Washer
Dishwashing machine whirlpool electronic control ADP 4520
Check the Water Indicator (WI).
When you think it should be enough water, unplug WI connector from control board and check if on WI connector is closed contact (WI written on the control board housing). If not, try with some more water. And so on. When too much water with no contact on WI, it is the one to be replaced by new one.
NOTE: by every check UNPLUG the machine
Jan 03, 2010 | Electrolux Dishwashers
LG WASHER WATER WON'T DRAIN SO IT WON'T
Hi, you got a water pump problem, some time small object (handkerchief, coins etc. ) can get into pump impeller, or possible your pump motor burnt out, remove back panel of machine, locate water pump, (device where all hoses connected to) remove hoses from water pump and clean hoses and water pump, you can check water pump winding, remove 2 wires, from pump terminals, check with ohm meter, place tester leads one on each terminal of water pump, if you get a beep sound, water pump is o/k, if you didn't get a beep, replace water pump, you are smart, you can do this, but first try to clean water pump, that could just be your problem remember to unplug your washer before you start any repairs. good luck.
Aug 11, 2009 | Washing Machines
Pump runs continuously with not water
replace the pressure guage.
prime the pump by pouring in water in the impeller basket area and replace lid-try running pump again
Mar 22, 2009 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Indesit IS70c condenser dryer
CHECK PUMP AND FLOAT AT REAR OF DRYER EITHER PUMP IS BLOCKED OR PIPE FROM PUMP BUT MAKE SURE THE DRYER IS UNPLUGGED WATER AND ELECTRIC DO NOT MIX,
IF YOU ARE UNSURE WHERE TH PUMP IS GET A QUALIFIED ENGINEER
Dec 25, 2007 | Dryers
Kenmore 20172 Top Load Washer Logo
44 people viewed this question
Sal De
fordexpert
Robert Rankin
