Question about Whirlpool Calypso GVW9959K Top Load Washer
What does L5 mean? - Whirlpool Calypso GVW9959K Top Load Washer
  • 15,935 Answers
The control should flash this error code if it cannot detect the lid switch opening and closing properly.
This error code may also be used if there is a disagreement between the motor and machine controllers on the state of the lid switch.
The control should not allow the unit to run in this condition. This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Posted on Sep 16, 2010
What does code L5 mean
Google L5 along with the make and model item on which this code appears.
Oct 16, 2017 | Exercise & Fitness
What is l5 error
Probable Cause A LS error on the Landice L-Series treadmills can also look like L5 and this error code means there is a loss of speed signal. If this error occurs with no belt movement, the causes for the LS or L5 error are:
A) Faulty upper display board or faulty relay board
B) Improper speed control wiring
C) Improper motor control wiring
D) Worn or faulty motor brushes
E) Faulty pwm/relay combo board or faulty drive motor
This error can also occur with belt movement but speed will not increase. Causes for the LS or L5 error with belt movement are:
A) Speed sensor is out of adjustment
B) Speed sensor is damaged or faulty
C) Display cable is damaged or faulty
D) Improper speed control wiring
If you find yourself needing any further assistance please do not hesitate to call our technical support team at 888-713-2880 or check out our technical support center at we would be more than happy to help!
Aug 03, 2015 | Exercise & Fitness
Nautilus t714 error code L5. Can you tell me what this error code means? Thank you. Tim
Dear Sir:
I just want to say to L5 means many things.
1)You must check socket wiring from upper board(display) vs lower board(controller motor board)
2)Short circuit in capacitor(EMI) in input circuit or Short circuit in Main Motor Test.
3)Faulty Controller Motor Board-Replace.
4)Realign Sensor Speed Motor and clean or Replace
Since the Controller Motor Board control 90% function in Treadmill , will the most probably cause, after you did Test all Step before mentioned. And strong concluded the Lower Board is Faulty.
If you need further assistance, please reach me.
Nov 22, 2011 | Exercise & Fitness
I have a l5 code what does that mean
L5 means it cannot sense the lid open or closed.
Lid switch is likely bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 26, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I have a error reading of l5 or ls not too sure york fitness z16
The L5 message means that there is a problem with the speed setting switches. Some models have one set of speed adjusting stitches on the handlebar and another set on the console. One of them is defective and is causing the problem.
Dec 29, 2009 | York Exercise & Fitness
How do you wire l5 to 2 ohm
Hello lholt07,
If the L5 has 4 ohm voice coils, you simply wire both voice coils in parallel, both marked and unmarked positive terminals together and to the amp and likewise with the negative terminals. If the L5 has 2 ohm voice coils, it cannot be wired to 2 ohms.
Hope this helps.
Sep 19, 2009 | Kicker Solo-Baric L5 Car Subwoofer
After approx. 30 min. of walking on full speed it
I had this happen on our machine after about 5 years of use. I just recalibrated it and it appears to be working fine now. See the manual for information on the steps needed to take in order to do this.
Jul 11, 2009 | Bowflex Treadclimber
L5 code appears after it stops on the Z500 Treadmill
LS mean low speed error, Please check the sensor wire( if moor move). if not move please check control board.
Mar 30, 2009 | Spirit Fitness Z500 Treadmill
System error
Look for a reset function in camera manual If no manual download one - if nada, then contact Nikon customer service for inside assistance with dilemma. Due to high cost of camera repairs you just might have to go shopping.
Aug 26, 2017 | Nikon COOLPIX L5 Digital Camera
Nikon coolpix L5
Lence will not open all the way
Jan 01, 2008 | Nikon COOLPIX L5 Digital Camera
Whirlpool Calypso GVW9959K Top Load Washer Logo
102 people viewed this question
Dan Webster
Dan Webster
Sal De
