Question about Konica Minolta Minolta DI1610FP Multifunction 200 x 400 dpi resolution, 33.6 Kbps modem speed, scan and fax functio... Printer
Konica Minolta Error Code: C14A3 Blown fuse or Exposure Lamp Printer was printing black and suspect it may be the lamp. Where can I get a replacement and instructions on replacing it myself?
  • 210 Answers
Go to a Konica Minolta dealer and ask for assy, the part number is 4980 1001 01 and it is called CCD MODULE. I cannot find only the lamp, you'll have to replace the full assy in which the lamp is included.
Posted on Aug 25, 2009
    New Friend:
  • 51 Answers
IR lamp malfunc-tion
Check the connection of the connectors,
and then correct them if necessary
Replace PWB-P.
(4) Removal of the Controller/Mechanical Control Board
<Removal Procedures>
1. Remove the Rear Cover.
☞ D-7
2. Remove the Network Interface Card Board. (Option for Di1610p, Di1610f, Di1610fp)
☞ D-10
3. Remove the Network Control Unit Board. (Di1610f, Di1610fp only)
☞ D-10
4. Remove the PCL Board. (Di1610p, Di1610fp only)
☞ D-11
2. Disconnect all connectors from the PCL Board.
4980S536AA
3. Remove four screws.
4980S537AA
5. Disconnect all connectors and flat cables from
the Controller/Mechanical Control Board.
NOTES
The two connectors marked with “*” in the illustration
are provided for Di1610f, Di1610fp only.
Use utmost care not to snap off the flat cable.
4980D003AC
D-12
(5) Removal of the Control Panel
1. Remove the Exit tray.
☞ D-7
6. Remove six screws.
7. Remove the Controller/Mechanical Control
Board
Posted on Aug 30, 2009
    Sergeant:
  • 210 Answers
Were are you located? What country, state your in? If you are in US there are lot of konicaminolta dealers branches and they sell parts as long as you know the part number.. If your machine is in warranty you might lost the warranty, if you will do it yourself. If you work on copiers before it is easy to figure it out to remove the platen glass to access the lamp and the fuse.
Posted on Jul 09, 2009
  • Herminio Halili, Jr.
    Herminio Halili, Jr. Jul 09, 2009
    were are you located? What country, state your in? If you are in US there are lot of konicaminolta dealers branches and they sell parts as long as you know the part number.. If your machine is in warranty you might lost the warranty, if you will do it yourself. If you work on copiers before it is easy to figure it out to remove the platen glass to access the lamp and the fuse.
    Herminio Halili, Jr. Aug 10, 2009
    You may contact any Konicaminolta service branch or authorize dealer. That is the only place where you can buy the right parts
What can I do when my Konica Minolta bizhub 160 says machine trouble, service call (C14A3)
C14A3 means IR fluorescent lamp fault. Check the Exposure Lamp (LA2) . The Scanner Exposure Lamp fails to turn ON. Test the voltage supply & the Lamp.
Nov 04, 2014 | Konica Minolta bizhub Office Equipment &...
I am getting an error message that says error C14A3. How do i fix it?
The bright that normally come on under the big glass is having issues, replace the scanner assembly can't just get the lamp.
try this web site for starters
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jul 07, 2014 | Konica Minolta bizhub 161f All-In-One...
How do I cure Konica Minolta 240f lamp error message?
replace the lamp what is exposure lamp under the glass.
Jun 14, 2014 | Konica Minolta bizhub C250 All-In-One...
C-6708 code
Does your exposure lamp come on ? Mite have a problem with the scanner lamp or the Scanner reader that the CCD the black device under the big glass that views the document to be copied. Exposure lamp is what high lights the original document(s)
May 30, 2014 | Konica Minolta Developer 02xk Dv710 for...
IM GETING A C14A3 SERVICE CALL ON TH SCREEN
This code means your scanner lamp, the one that lights up under the glass is not coming on properly. Usually this code will reset and the machine will work again. In some cases the scan lamp has gone bad and must be replaced.
Aug 17, 2010 | Konica Minolta DiALTA Di1610p Printer
Clearing a service code ''C0400'' on a Minolta CS Pro 6001
C400 is exposure lamp fails to come on, on start up the main exposure lamp should come on and do a scan.
If the lamp is not detected by the sensor, then you get the code.
Restart the machine, watch for the exposure lamp. if it does not come on before the code occurs, then the lamp or thermal fuse is likely gone.
if the lamp comes on then the code, the AE sensor is likely gone.
Hope this is of some help.
Ed
May 11, 2009 | Konica Minolta Office Equipment & Supplies
Copier problems
Hello sir;When you make copy, does exposure lamp on, if not, check the thermos fuse or replace exposure lamp.
Apr 14, 2009 | Konica Minolta Office Equipment & Supplies
Bizhub Di1610fp
C0500 code that is fuser.try reset this one first by powering machine on while holding down STOP BOTTON ON THE OP PANEL
hope that help
Oct 10, 2008 | Konica Minolta DiALTA Di200 Copier
Konica 7415 erro code C14A3
You have a blown exposure lamp or fuse. When repaired code will automaticaly reset.
Oct 15, 2007 | Office Equipment & Supplies
Konica Minolta Minolta DI1610FP Multifunction 200 x 400 dpi resolution, 33.6 Kbps modem speed, scan and fax functio... Printer Logo
3,330 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
