Question about Whirlpool WFW8300SW
Water pours out from soap/softener drawer at top...
My MAH9700 pours water all over during fill and rinse. A repairman told me to contact Maytag for a new door gasket, and left. I opened the soap-fill drawer at the wash start and found water not draining into the drum fast enough, causing overflow down front on to the floor. If I hit pause and wait for it to drain (babysit the entire wash/rinse) it's ok. All hose clamps are ok and there's no kink or visible problem with the drain hole. Could this be as simple as a water pressure problem? I have the same issue with the Whirlpool WFW8300SW01 (Duet Sport). I've checked the drain at the bottom, pulled some stuff out, yet there is no change in the problem. If I leave the drain open at the bottom, the water (left over from the waterfall in the dispenser) will slowly drain out. Otherwise the it just sits there.
  • lanmy_mai Apr 15, 2009
    My Whirlpool Duet sport WFW8300SW02, at the washer start and found water not draining into the drum fast enough, causing overflow down front onto the floor.
I'm guessing, what with this having been posted nearly a year ago, that this has been resolved, one way or another, but I thought I would post this solution for the benefit of others:
We had this same problem, where water was flowing out from underneath the detergent dispenser. The problem we had was a blockage between the dispenser and the drum, so after taking the console and door-panel off the washer, I removed that black tube from the dispenser to the drum and pulled out the matted-up sock which had somehow made its way there. Good luck!
Posted on Nov 13, 2009
  • 4 Answers
We had the same problem and I just fixed it based on advice here and other websites. I used a slightly different approach and came at it from the top side. I think it may be more work from that direction but eventually I got to a sock stuck between the drum and the watersupply hose coming from the detergent bin.
DONT FORGET, if you have something stuck in this location, you may also have some things stuck in the drain trap under the drum. 2 weeks prior we had a leak from the bottom of the washer and from advice on this site and others I pulled the 3 screws that attach the bottom panel (pull drawer out and look for screws) and unscrewed the drain trap to find it was loaded with socks.
I think the moral of the story here is to buy a mesh bag of some sort and put small items in it. Kids socks, washcloths, etc slip in between the washer seal and clog these two locations. The washer really does eat socks. :-)
Posted on Apr 22, 2010
  • IndyJared Oct 15, 2010
    Another 6 months of experience with this washer....
    1. I have had to clean out the drain trap 2 more times. My wife's thin stockings now have to go into the mesh bag along with kids socks and bibs. The mesh bag has helped quite a bit.
    2. One day a kids book got into the washer and was turned into paper clumps. Shortly after this the seal around the washer started leaking. I check the top clogging point and the drain but they were clean. The issue had to be the main seal. I inspected the seal and the door and found a build-up of soap-scum/mildew that I thought may be compromising the seal. I used TILEX mold-mildew remover and cleaned the door and the seal really well. I applied a thin layer of white lithium grease to the seal and no more seal problems.
    3. Leveling - the washer is VERY sensitive to leveling. You need to have your level bubble EXACTLY right in order to reduce washer noise. It takes a while but you CAN get it leveled and working well.
    4. If we have many more problems we are considering getting what we can for the washer as scrap metal and buying another. At least we have not had a board failure yet...*knock on wood*
I just wanted to thank-you for posting this solution(#2). We had a washcloth stuck in ours! You have saved us $$$$!
Posted on Feb 18, 2010
Buy a new washer
Posted on Jan 16, 2009
Water leaking from detergent drawer
The first thing to do is take note of what the washer is doing when water leaks out in order to help pinpoint the cause. Does it only leak when filling? Is it leaking during wash or rinses? Or is it leaking only when it goes into spin?
Only leaks when filling
  • Water pressure that's too strong. Some dispensers can't cope with high water pressure. Make sure the washer is level as one leaning forward can leak if combined with high water pressure. Try turning the tap on the washer down. Only suspect this if you know the water pressure is high and it looks like it's gushing in quite fast on fill
  • If there is an optional detergent flap fitted in the drawer for holding liquid detergent make sure it is removed or drawn into the up position if using powder otherwise it prevents detergent running down into the drum
  • A build up of grease and slime in the nozzles at the top of the dispenser where the water flows in causing water to spray at the front and run out when filling. Check this article -black jelly-like substance in soap dispenser and on soap drawer (In extreme cases I've had to replace the dispenser.)
  • A build up of undissolved detergent in the base of the soap dispenser under the drawer (depending on the design). Remove the soap drawer and check the bottom of the soap dispenser for a build up of detergent that could allow water to run over the lip of the dispenser
  • Blocked dispenser hose: Some washing machines can flood water out of the soap dispenser if the hose leading out of the dispenser into the tub gets blocked. Blockages can be something put into the drawer by a child or a chunk of undissolved detergent tablet. Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and it wasn't wide enough. Undissolved powder from a tablet or lumps of detergent through poor water pressure can block this hose solid causing water to back up. Unplug machine, remove lid and feel this hose carefully for obstructions.
  • Overfilling: If the washer starts to fill and never stops it will flood out of the drawer eventually - Washing machine overfills
Leaks out of drawer during the wash or rinse cycle
  • Too many suds? If you can see the door glass is white with foam up to the top it could be foaming out of the dispenser. Too much foam in the washing machine
  • Overfilling: If the washer starts washing but the water doesn't stop coming in it will eventually fill the drum so much it will start to pour out of the soap drawer and other places. If this is the fault you should be able to see the drum is so full of water it's making a different sound, maybe labouring under the load, and the door glass full to the top with water. You should also hear that water is still running into the machine and be able to detect it by opening the drawer. However, in most cases an over filling washing machine should trigger an error code long before it gets to this stage but if you suspect overfilling check this page - Washing machine overfills
  • Surging: There are (often intermittent) faults that can cause the motor to spin out of control on wash or rinses. Instead of turning slowly the fault causes the motor to surge into spin instead which throws the laundry and all the water about violently. Water can then be forced out of the soap dispenser drawer. This fault should be relatively rare these days but if you observe this behaviour call an engineer to diagnose the cause.
Leaks from drawer only when spinning
  • If it only comes out on spin it can be caused by a partial blockage preventing the water being pumped out fast enough resulting in excess water being thrown around on spin and backing up into the dispenser. This fault is similar to the surging fault described in the last list but different in that the problem only occurs when it's on a proper spin cycle and much of the water has been pumped away. Troubleshooting this fault is all about finding out why it isn't emptying the water properly which is usually due to a partial blockage. Follow the same troubleshooting as described for a washer not pumping any water out at all - Washing machine won't empty water
  • If water is being forced out of the drawer when the washer is spinning but it is on wash or rinse and shouldn't be spinning follow the procedure for surging in the previous section above
Dec 23, 2016 | Washing Machines
Water pouring out of the detergent drawer
Remove the dispenser draw and pour water down the soap chute as much as you can to soften any soap causing the blockage. When the water level drops, add more water. After a while use a soft flexible rubber hose and run it down the chute up and down to remove caked soap. Once this has been achieved, run the machine on "Rinse & Spin" to clean out the drum.
Mar 19, 2014 | LG WM2101H Front Load Washer
WATER LEAKING from Soap / Softener dispenser
Close the water faucet slightly to reduce the speed of the flow into the the soap drawer...The machine will fill a little slower, so what??!
Oct 25, 2017 | Maytag MAH8700A Front Load Washer
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
Fabric condtioner won't go through into drum during rinse cycle
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question
May 25, 2009 | Candy AQ130 Front Load Washer
We have a Maytag front load washer Model MAH 4000 AWW
tHE PROBLEM IS YOU NEED TO CLEAN YOUR SOAP, SOFTENER AND BLEACH DISPENSER, REMOVE THE BLEACH AND SOFTENER DISPENSER TRAY, AND YOU WILL FIND THAT IF YOU HAVE BEEN USING LIQUID SOFTENER, THAT IT HAS GUMMED UP AND CLOG THAT AREA AND IS CAUSING SPILL OVER. WHEN THE WATER IS POURED INTO THE TRAYS TO DISPENSE THE BLEACH AND OR SOFTENER.
Mar 18, 2009 | Maytag Neptune MAH7500A Front Load Washer
Epic Z - Water coming out the front soap tray
you can try pulling the soap tray out and clean all the old detergent and softener in there. they do clogged the outlet of water for the water to overflow.
check also where the soap box is inserted. it would also have lots of dirt.
tnx 4 using fixya,
drcool
Oct 19, 2008 | Washing Machines
Fabric softener won't empty
as you have said you have cleaned out all of the soap drawer a good place to start is assume the problem could be the water supply solenoid, the water not getting through, remove power plug, the lid, and test the solenoid for open circuit, and replace if needed, if this has helped please rate me
Sep 13, 2007 | Maytag Neptune MAH9700 Front Load Washer
Fabric Softener doesn't empty
My husband just fixed ours after not seeing a solution on any other site. He pulled out the dispensing unit and pulled off the blue plastic piece on the top of the fabric softener and bleaching section. He then ran warm/hot water (not boiling hot) through the holes where the fabric softener is suppose to flow through. This cleaned out excess fabric softener that had coagulated in the elbow and blocked the flow of softener to the unit.
Feb 14, 2007 | Maytag Neptune MAH9700 Front Load Washer
Whirlpool WFW8300SW Logo
470 people viewed this question
Dan Webster
Dan Webster
Sal De
