If you are mechanical incline then open up the unit and remove a couple of gears. It will have two motors, one to slide the screen in/out and one to flip it up/down. Remove one of the gear next to each motor and make sure no other one will fall or pop out of place to cause jam later. Now you can operate the unit in manual mode(by hand, lol). Be very careful and remember what goes where and handle loose pieces gently or you might creat more problems than fixing it. I charge $50 shipped to perform the same service. Goodluck.
Press a button marked as Fn and press at same time button on functions keys (F1 to F12) representing a sun or likewise with an arrow or triangel pointing up.
Someone has turn down the background light on the computerscreen.
If thats not the case its problably the background lightsource stop function and you need a tech to look into it.
Put the set on for several hours and let the electronics warm up. It is possible that some capacitors have dryed and putting on the set for sometime can build up the charge and help to retain the circuit to perform in order. This is all what could be done and hope you have not started on the trip. It is important that any electronics units must be in action at least some time as some low quality components can malfunction with aging in course of time. If this wont solve then you will need help to open and probe for fault inthe power/ display unit. Good luck Good day
you cant fix it.
if your game is stuck in there DONT open it up or you will void the warranty
phone sony, they will organize a date to swap ps3's. + you keep your extended warranty
5 times blinks shows White Balance error in tv. You need to adjust Screen Volts (G2) and problem will resolve. Screen volts controls located at Focus Block as shown in below picture.
The control is automatically set to turn off the oven after 12 hours baking or 3 hours broiling should you forget and leave the oven on. If you want to remvoe this feature do the following steps:
1. Press and hold, at the same time, the BAKE and BROIL buttons for 3 seconds, until the display shows "SF".
2. Press the DELAY START TIME button. The display shows "12Shdn" for 12 hour shut off.
Press the DELAY START TIME button again. The display will show "no Shdn" for no shut off.
3. Press the START button.
