Question about Panasonic Viera TH-50PZ80U Plasma TV
Plasma, panasonic viera
Hi l am having problems w my tv, fos some reason it turns off by itself and it just blicks and the light flashes like 10 times. l have to umpluged it, even so would not solved it. any thing that you can help me with, it would be nice. thank you so much.
jose.
  • Anonymous Feb 23, 2009
    I have the same problem I put a fan behind the tv to keep it from over heating until they can come out and fix it
  • crigtus Apr 03, 2009
    I have the exact same problem with the same model Panasonic. Vortechsoto's, how did you fix it? When it first happened I unplugged it for ten minutes and it worked again. Now, I have the same problem as you.
I had a similar problem with my Panasonic Viera 46 " 80U. I believe it was caused by HDMI ideoscyracies. When I turned off TV before shutting down the HDMI connected with my computer. It froze up. I could not get the TV to reboot, even if I pulled the plug, until I reconnected the HDMI to my computer and when I shut the computer down properly, something in the HDMI communicated to and released the TV from the freeze. At least that seemed to be the answer.
Let me know if this makes sense or if anyone experienced something similar.
Posted on Apr 10, 2009
  • 3 Answers
Clearly your TV is faulty. There arent any user serviceable parts in this product. I suggest you get an qualified engineer to repair it. Dont try to do it yourself.
Posted on Jan 17, 2009
PANASONIC VIERA TH-42PZ82BA 42" PLASMA TELEVISION 1080P Full HD
Your TV is showing symptoms of power supply failure. It needs to be repaired or replaced. The remote has nothing to do with the power supply problem
Mar 21, 2013 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
I have a Panasonic model TH-42PZ80U Plasma Tv the red light keeps blinking 10 times and it won't turn on?help
hi,
In your tv there some problem with power supply. you have to check the followin voltages. Sub 5v SOS ,Main 3.3v SOS A-Board,DTV 9v SOS , Tuner Power SOS. If any one of the voltage fails it will shows 10 blinks.
ok
Jul 18, 2011 | Panasonic Viera TH-42PX80U Plasma TV
Panasonic Viera TH-46PZ85BA Will not switch on
Yes, the unit has a problem. I work for Panasonic in New Zealand and the unit needs to go in for servicing. 10 flashing lights means a fault has occurred (if I was at work I could tell you what 10 flashing lights means).it should be repairable.
Sep 26, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic Plasma HDTV 50" Viera--won't turn on. Red light flashes 10 times followed by a 3 sec pause, then repeat 10 flashes. Have solved problem by unplugging it and plugging it back in, but that is not...
Please make sure your connectors are in the proper place.
The HDMI inputs on the rear of the TV are optimized for use with Audio/Video devices, Blu-ray Disc Player, DVD Recorder, etc.
The front or side HDMI inputs only are designated for PC. To use the TV as a PC monitor, advise customers to use only front or side HDMI inputs.
Jun 16, 2009 | Panasonic Viera TH-50PZ800U Plasma TV
Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Oct 07, 2007 | Televison & Video
Panasonic Viera TH-50PZ80U Plasma TV Logo
462 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
