Question about NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111)
Netgear Wireless adapter
Since using this I have run into loads of problems. Not connecting to the wireless hub and now the PC running on WXP is not closing down.
Can you help?
1. Windows not shutting down may be due to mouse incompatibility. e.g Toshiba with Logitech Mouse. Microsoft mouse works better with Toshiba in my view.
2. Set modem to NAT mode, ensure pass phrase upper and lower case preserved on your wireless machine (case sensitive).
3. Transfer WEP or WPA-PSK[TPIK] pass phrase to your Netgear Wizard as a Hex Key (Key 1).
Posted on Feb 28, 2009
How many computers can the netgearN150 run at the same time?We r trying to run Xbox live, desktop ,mini hp notebook and a ipod...Is this to many devices?
No problem if you are connect using the wireless, but if you are connecting by LAN cables then it is limited by the number of LAN ports on the Netgear router unless you attach a LAN hub to the router to increase the number of LAN ports.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Feb 14, 2011 | NetGear WNR1000 RangeMax 150 Wireless...
Problems with WiFi netgear WNDA3100
the drivers should be installed in windows 7 by default, their so called "smart wizard" has some compatibility issues with windows 7, I get it to load up and it will shut down or glitch out. What I did was uninstall the downloaded driver and use the default windows drivers, flipped the switch off to my built in G wifi adapter and the netgear automatically kicked in and took over as the default wireless adapter.
Nov 06, 2009 | NetGear RangeMax Dual-Band Wireless-N USB...
Bt home hub (shuny black one) wont connect wirelessly
Try to disable the netgear interface and let windows manage the wifi card. This could also be happening if the signal is not strong enough where the machines are.
Is your wifi hub also a netgear? If not it may not be compatible with the cards if that is the case you will need to replace them with diffrent make of the cards preferably the same brand as hub.
Jul 27, 2009 | NetGear WG311T 802.11g/b (wg311tge)...
Netgear wireless adapter disconnects from router randomly
check for firmware update for your adapter...since it usb..u need to put it in open..i believed the USB extension is included when u purchased that.
do not connect the USB adapter to a USB hub unless the HUB is powered so that it can performed better. Connect it directly to your PC slot
Mar 13, 2009 | NetGear WPN111 RangeMax Wireless USB 2.0...
Netgear DG834G V4 Website connection problems
Please try to use a difrent DNS service.
For example open DNS:
Primary: 208.67.222.222
Secundary: 208.67.220.220
Jan 14, 2009 | NetGear DG834G Router
Wireless not working from netgear wg311 to a new bt homehub2
Hi Backatya,
Check what kind of security you upgraded BThomehub 2 uses. Since the hub supports more security-types then your adapter does, I suspect an incompatibility there.
You can solve it by connecting through cable and changing security to WEP or WPA (not WPA2).
Regards Ronnie
Dec 15, 2008 | NetGear WG311T 802.11g/b (wg311tge)...
Installed a wireless usb adapter to an old computer running windows 98
you re-install your wireless adapter and install the driver of the win 98 only ok the try it.
Sep 12, 2008 | NetGear WG111 802.11g/b Wireless Adapter
Netgear WPN111 wireless adapter won't connect
Is the computer Windows 98 SE [Second Edition] ?
What is the exact error message that you get ?
Mar 29, 2008 | NetGear WG111 802.11g/b Wireless Adapter
Wpnt121 and wpn824v2
the rangemax may be 108mbps transfer speed, but are your wireless network adapters able to run at 108mbps?, as most earlier ones will only run at 54 mpbs, especially notebook wireless adapters. You will only gain on 108mbps transfer speed when file transfering or streaming to each pc, it will not speed up your internet connection, although you probably already are aware of that.
Jun 16, 2007 | NetGear RangeMax 240 WPNT121 (WPNT121NA)...
Usb compatibility with windows xp service pack 2
Install the service pack 2 and update via Windows Update!(Go to Tools then Windows Update in Internet Explorer) Install the USB Wireless Adapter! Follow the procedures here! http://support.dlink.com/faq/view.asp?prod_id=1398&question=DWA-130%20/%20DGL-3420%20/%20DWL-AG132%20/%20DWL-AG530%20/%20DIR-330%20/%20DWL-AG660%20/%20DWL-G120%20/%20DWL-G122%20/%20DWL-G132%20/%20DWL-G510%20/%20DWL-G520%20/%20DWL-G520M%20/%20DWL-G550%20/%20DWL-G630%20/%20DWL-G650%20/%20DWL-G650M%20/%20DWL-G680%20/%20DWL-G710%20/%20DWL-G820%20/%20WDA-1320%20/%20WDA-2320%20/%20WNA-1330%20/%20WNA-2330%20/%20WUA-1340%20/%20WUA-2340%20/%20DWL-P100%20/%20DWL-P200%20/%20DWL-P50%20/%20DWA-142%20/%20DWA-542%20/%20DWA-552%20/%20DWA-556%20/DWA-642%20/%20DWA-643%20/%20DWA-645%20/%20DWA-652%20/%20DWL-M60AT%20/%20DWL-R60AT%20/%20DVG-G1402S%20/%20WBR-1310%20/%20WBR-2310#sp2 Now try the connection! If you still have problems, let me know! regards, babb
May 04, 2007 | D-Link : DWL-AG132 a/g Wireless 108M USB...
NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111) Logo
142 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Brian Sullivan
Brian Sullivan
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
