Question about Whirlpool 24 in. GU1200XT Built-in Dishwasher
Whirlpool built-in dishwasher - has sprayer for lower and upper racks. Have had to have repairman out to clean out dishwasher as residue blocks water from getting to upper rack - is there any way to do this myself?
  • 38 Answers
Yes, you will need to purchase a set of torx style screw drivers at your local hardware store. Remove the upper and lower spray arms and clean the debris out of the spray holes. Remove the screws that hold the filter in place and remove the gunk out of the sump. In the future stop using gels or gelpacks, just use electrasol powder or cascade powder. The gels and gelpacks clog up dishwashers like you would not believe. Run some Lemi-shine through the machine on a monthly basis, Lemi-shine is available at most walmarts.
Posted on Feb 23, 2009
Glasses do not come clean in the upper rack but do in the lower. Is there someplace that should be cleaned out to make the upper rack work again
Not knowing what dish washer you have I would check on the sprayer make sure it turns or is not blocked in any way. If the water can't spray up you will not get clean dishes.
Apr 28, 2017 | Dishwashers
Bottom water sprayer not spining
If the dishwasher won't clean dishes, check the lower wash arm assembly. If the lower wash arm isn't getting water, all of the dishes in the lower rack will come out dirty. Check to be sure the lower wash arm assembly spins freely. Also check to be sure the little holes in the lower wash arm aren't clogged or blocked.
Aug 28, 2014 | LG LDF6810ST Stainless Steel Built-in...
Dishwasher won,t clean dishes ontop rack
Make sure the top rack is pushed back all the way to connect with upper sprayer arm water port. Also make sure nothing is preventing either sprayer arm from rotating and there is nothing blocking the sprayer arm holes, like seeds or pieces of plastic debris. Also make sure your water heater temp is hot enough.
May 18, 2011 | Electrolux EIDW6305GS Builtin Dishwasher
I have a Kenmore model 1374 (ultrawash quiet guard). Recently I've noticed a lot of dirty residue left on the top rack dishes. I looked in the back of the dishwasher and noticed something with the little...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Dec 26, 2010 | Kenmore 13742 / 13744 / 13749 Built-in...
We have a 2007 LG ldf6810ww dishwasher that suddenly is not getting dishes in the upper rack clean, nor is it fully removing the soap from its dispenser. I assume they're related and due to a lack of...
I once had gunk in the rotating sprayer itself that was blocking things...is the dispenser opening properly? I reckon a thorough cleanse with a dishwasher cleaning detergent (the one that takes a super wash to do it) and check the sprayers...no joke a chicken bone was in one of them!!
Aug 19, 2010 | LG LDF6810ST Stainless Steel Built-in...
Have a whirlpool GU2400XTPT1 undercounter dishwasher for the past 5 years. Has worked perfectly until a few weeks ago the glasses and such on the top rack haven't been coming completely clean. Everything...
have you change you dish soap -to a phosphours free agent there has been rumor that these new cleaner will leave residue on glass.you can alos make sure the the dishwasher is clean after time they can build up lime and scale,calcium you can use any kind od dishwasher cleaner this may help
Jun 10, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
We have a GE dishwasher with upper and lower sprayers. The upper sprayer (one located right under top rack) won't spray or turn which leaves the dishes in upper rack dirty, any suggestions on how to fix...
try c.l.r. to clean dishwasher check and clean lower and upper spray arms out, run no detergent you can also run vinegar in it as well about a cup full,let the machine start to run then stop dish washer for a few hours then restart see if this works for you use a short cycle.
Dec 01, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
My dishwasher is leaving a lot of residue on dishes
I had the same problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Most dishwashers have 'risers' that bring the water up to the top sprayer or arm located under the top rack. If the recirculating pump is plugged even a little there won't be enough volume or pressure to get the water up there.
Test this by putting a dry muffin pan in the top rack, flat, and running the dishwasher for a bit. If there is no water on the top (or the bottom) either the top sprayer or the sprayer arm underneath the top rack is not getting enough volume.
To fix this you need to clean out the screen and filter, where the water returns to be recirculated. If you don't have any confidence to remove the parts and clean it out yourself, get an appliance repair person to do the job.
Aug 26, 2009 | Dishwashers
Dishwaher does not clean, upper rack
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary (part # 8268383). If the motor gear is broken, replace the sump and motor assembly (part # 8535150). Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
Mar 13, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
KitchenAid Superba KUDSO1FLSS3 Not Rinsing? No Cleaning at all!
Here are a couple of things that you can try:
If there is hard water residue or film left on the dishes:
Check water hardness.
If the water is hard, use maximum detergent or try pouring 1/4 cup of Dishwasher Magic into the bottom of the dishwasher. I would also recommend using the High Heat option to ensure proper cleaning. To clean the dishwasher, use a cup of vinegar and place it in the upper rack.
Detergent carryover:
If it's below 10 grains, use less detergent and the High Heat option.
It is also possible that you may have a problem with the drain loop check valve as it's not sealing. This may cause residue or food to be left on the dishes. For this, I would recommend you have a technician do it, as it requires replacing the entire drain loop.
Let me know if any of this solves the problem.
Oct 12, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Whirlpool 24 in. GU1200XT Built-in Dishwasher Logo
172 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
