Question about HP ProCurve 2650 (J4899A#ACC) 48x10/100 Mbps and 2x1000 Mbps Networking Switch
Locked out of HP Procurve 2650 switch
I need to reset the logon on the Procurve. We purchased a small company which had no IT, someone along the way had setup the admin login on the switch. There is no one I can ask, and seemingly no information that I have been able to find on the web. Any help would be....helpful. ;-)
  • marsel90 Mar 12, 2009
    i put all port in tagget and now the connection is dead, how reset all switch
  • Michael Lucas
    Michael Lucas May 11, 2010
    Have you tried this?
    http://www.hp.com/rnd/support/manuals/26...
    This is a manual for that switch
    Problem Solver:
  • 14 Answers
If you have forgotten the switch's IP address or administration password you can return the switch to its factory default state by following these steps:
  1. Remove the power cord from the back of the switch.
  2. Connect port 1 to port 2 on the front panel, using a standard network cable.
  3. Reconnect the power cord to the rear of the switch.
  4. Wait at least 40 seconds before disconnecting port 1 from port 2.
After completing this procedure, the password will be empty, the network address will be returned to the default 192.168.2.10, and all configuration settings will be returned to the original factory defaults. NOTE: Since this process creates a temporary loopback condition on the switch, it is recommended that you remove the switch from a production environment until the process is complete.
Posted on Jan 27, 2009
    Problem Solver:
  • 8 Answers
HP makes it easy to clear any passwords that have been lost or forgotten. You'll need access to the front of the switch but take a paper clip and hold in the CLEAR button on the front panel for a second. That will clear out any stored passwords and allow you access to the switch. You can also disable the use of those front panel buttons in the programming of the switch if access to the room the switch is stored in is in question. Below is the tech doc on the 2650 too, hope this helps.
ftp://ftp.hp.com/pub/networking/software/j489990001.pdf
Posted on Feb 10, 2009
  • udaythp4 Apr 12, 2014
    What if REset and Clear Button not working ...... then how would we factory reset thi hp sw
I have a HP Procurve Switch 2650 which keeps rebooting
Your switch has a lifetime warranty, contact HP for replacement
Mar 25, 2013 | HP Hewlett Packard J4899B New ProCurve...
Default password for HP procurve j4899a
This link should tell you the answer. http://h30499.www3.hp.com/t5/Switches-Hubs-Modems-Legacy-ITRC/Clear-password-in-Procurve-2650/td-p/4598369#.U0sRNfldUok
Nov 01, 2012 | HP Hewlett Packard J4899B New ProCurve...
Have HP Procurve 2650 switch with some cisco wireless accespoints (WAP2000) attached. when roaming the user-device from one AP to the other, network connectivity is lost for quiet a while, when APs are...
What I saw is that you can only set it to three roaming types, (PMK Caching, Opportunistic Key Caching, PreAuthentication).
Try to turn them all on and see what happens. Here is a screen shot for it.
Aug 05, 2011 | HEWLETT-PACKARD ProCurve 2650 Stackable...
Fault led glowing on hp procurve 2650
operate a factory reset to make sure it is hardware Fault: press reset and clear simultaneously for 3 good seconds then release Clear, when Switch fault and ports start flashing let go of Reset button. If Fault Light still on, contact HP Support.
BE WARNED, this operation will remove passwords and configuration.
Aug 20, 2010 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
Our hp 2650 when boots up all the grn and org lights continually stay flashing what could be wrong, although 1 port doesn't flash and works
It could be a Failure on those Flashing Ports, try to console in to the Switch and access the event log to verify that. try the troubleshooting part of the manual at this link, see if it helps: http://ftp.hp.com/pub/networking/software/Mgmt-Oct2005-59906023-AppC.pdf
cheers
Aug 19, 2010 | HP ProCurve Switch 2650
Dv6700 hp laptop wont power on
This is a dumb question i'm going to ask but is the power cord plugged in. Mine recently killed over. Come to find out it was the battery pack, which was fully charged, just didnt work anymore.
Aug 03, 2009 | HP ProCurve Switch 2650
Wont wake up
Try removing the battery for a few minutes with the power unplugged. Reinstall the battery and power and give it a shot. If this works then you had a very locked up system; if not then it's likely to be the main board.
Jul 16, 2009 | HP ProCurve Switch 2650
Buttons wont work when i press on them
The HP Procurve 2650 switch does not have buttons. What hardware has the problem?
Jun 30, 2009 | HP ProCurve Switch 2650
HP ProCurve 2650 (J4899A#ACC) 48x10/100 Mbps and 2x1000 Mbps Networking Switch Logo
9,999 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
