We are receiving the error "Paper Jam 0" on our Xerox Workcentre PE 120i, however there is no paper jam. After opening and closing the doors (and making sure there's no paper jam), the fax seems to reset and we'll receive the last fax in memory, then we'll get the error message again. Thank you for your help!
SOURCE: Xerox WorkCentre PE120i - Paper Jam 1
Normal
0
I suggest you get a sheet of Card Stock (Heavy
paper) and place it in the feed way. Then press the print
button applying a slight amount of pressure on the Card Stock so it
will feed through the printer. The reason for this is in some cases I
have been able to clear the paper track of debris that was deposited there
over time.
Worth a try, as I have fixed a number of printers this
way, saving costly repairs.
Hope this helps.
Bud
SOURCE: Keeps showing "document jam" even though the jam was cleared
Most likely one of the jam sensors was knocked out of its clip. You would have to take the document feeder off and apart to find and reseat it.
SOURCE: Our XEROX Worcentre 4150 often jams and displays a
In the main door at the top in the middle there is a little black leaver that moves up and down if it gets stuck in the up position it thinks that there is a papper jam just check the little black lever and make sure its down
SOURCE: I cannot find a print driver for my workcentre PE
You can download the driver here...
http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=PE120_PE120I&Xlang=en_US&Xcntry=USA
regards,
Jeep Brainy
For the a last 3 months every time i print have of the job prints and then it comes up paper jam. So I check to see if we have any paper that needs to be removed and nothing. I open and close the tray and then it prints out the remainder of he job until i need to print again. So not worth having this printer
same problem..but found a solution --was the pickup rollar and separation pad in the bottom tray that had worn out--was not hard to fix myself and done for under 40 bucks.
