Question about SanDisk Sansa e250 MP3 Player
When i try to turn the record player on i can't cuz it is stuck
U know the little button that says stop start and auto it is stuck won't move please help me
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jan 17, 2009
My 1992 Nissan little truck with the 4.2 L in it turns over but won't start I have spark have air and fuel what else would cause it not to starr
Cacilia, Try new plugs to start with, bad gas,maybe timing has moved or slipped, bad distributor,very bad compression, the list goes on.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Problem 5 Engine Cranks But won Start
http://www.linnbenton.edu/auto/perform/no_start.html
car wont start it gets gas spraying from the fuel rail and spark from...
Here How You Diagnose An Engine That Won Start
Mar 21, 2016 | Nissan Cars & Trucks
DVD stuck in my Panasonic DMR-E30
Hi Rock.
I had the same problem like this on my machine. The best way to fix it is to turn the machine off completely and hold on the eject button then turn the power on. You want the first thing the player does is to eject the disk without trying to read it first.
I hope it works let me know if it doesn't and i'll try and recreate the problem on my player and see what i can do to get the disk out.
The last resort is to manually take the disk out but lets cross that bridge if my suggestion above doesn't work.
Thanks
smeags.
Feb 18, 2008 | Panasonic DMR-E30 DVD Recorder
How can I fix this???
See if you can leave ideal to adjust its performance and try turning it off after about 30 mins to 40 mins
Jun 12, 2013 | Audio Players & Recorders
Record button will not push down with play button, to record.
Are you using a new cassette???? Check to see if the tab is missing on top of the tape.....If it is put tape over it
Mar 14, 2012 | Memorex MKS5009 Karaoke System w/CD/CD+G...
Just bought a used Sony TCWR610, to reproduce some valued cassettes. Cannot get the B deck to record. There is a little red light that comes on that says REC, but deck does not turn as I start the tape...
I have the same tape deck. To do a copy on this machine you first press the normal speed button below synchro dubbing, then hit the pause button on the recording side to start the copy. It will automatically start both decks.
And to stop the recording hit either of the stop buttons.
Jan 07, 2011 | Sony Dual-Deck Cassette Player/Recorder...
Crosley Record Player Stopped Spinning...
I had this same problem with my Crosley 704 and it bamboozled me to no end.
After digging around I dug up the manual online (I bought mine used so I didn't have one to consult). It turns out the record stops when it gets to the end, and to get it spinning again you have to lift up the tone arm and move it right (past the holding latch) until it clicks, and voila, it starts spinning again, ready for a new record.
You'd think that they coulda made it more obvious :(
Jan 12, 2010 | Crosley Audio Players & Recorders
I have sansa sandisk e 260. last time, after charging it in my computer, i plug it out without having safety mode in the computer. After then i can not open my disk. when i try to turn on pressing on Menu...
1. Download the Sansa firmware.
2. Turn the player off.
3. On the top of the player is a Hold switch located.
Move it to the right so you see "Orange".
4. On the left hand side of the player is a Record button.
Press and hold the record button while connecting the player to the computer.
Continue holding the Record button until you see a new icon under "My Computer": named "16MB FORMAT".
Once you see that icon release the Record button.
5. Drag and drop the download firmware files to your player (16MB FORMAT).
6. Disconnect the player from USB cable.
Several things will be displayed.
When you see Key Lock, System Shutdown, move the Hold switch on the top back to the left.
Otherwise download the Sansa Updater and start follow the points 2-4 and start the Sansa Updater.
After updating the firmware follow point 6.
Jun 08, 2009 | SanDisk Sansa e260 MP3 Player
Problem starting
Get the Sansa Recovery Tool from the sandisk website
Jun 28, 2008 | SanDisk Sansa e270 MP3 Player
Stuck
Try holding down the power button for 10 seconds to reset it. if this does not work you need to go onto Sansa's website and download the updater and upgrade the firmware. Let me know if this works or not, if not I will look into it a little further.
Mar 14, 2008 | SanDisk Sansa e250 MP3 Player
Record from FM
If you press the play button while in FM mode it will start to record then press stop to stop.
Jun 13, 2007 | iLO (2 GB) MP3 Player
SanDisk Sansa e250 MP3 Player Logo
16 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Sanath Kumar V
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
