Question about HP Pavilion zd8000 Notebook
Recessed USB Port ?
Friend has a ZD8000. Can someone please tell me, is the USB port on the left hand side of the Laptop meant to be recessed about 6 inches inside the laptop, UNlike most usb ports ??
Please advise.
  • kiafoster Jan 15, 2009
    What happened is this. Someone ,we dont know who, pushed the power cable
    through the hole that houses the ,allegedly recessed, USB Port. and it got stuck through
    the hole. Admittedly the power socket is close to the shape of a USB port "ish" .
    Anyway I looked at it and told my friend the port had been pushed through into the inner
    part of the laptop. Ive only ever seen normal usb ports. The laptop works fine
    but were worried that it might shake lose and short out so someone took it to a computer
    repair shop who said would cost £50 (75$) to fix. Then 3 days later, today, they
    charged £50 to tell him the port was a recessed usb port and it is meant to be like that.
    Thats why the question. As I say laptop works fine. 6 inches maybe slightly more than is
    but say 3 inches to 4 inches inside. Would need to be skilled to use that USB port
    unless there is special way of plugging into it.
    thanks Kia
  • Michael Lucas
    Michael Lucas May 11, 2010
    If that port is recessed, 6 inches you said, then that port is broken. How is the performance of the Laptop otherwise.
    Scholar:
  • 108 Answers
Through my experience and my friend having the same laptop. His is not like that. I have never heard of a recessed usb port. Most all usb connections on have about a half inch male fitting. Unless you are Tech savvy and know how to open the case and fix it yourself I can see it causing you problems down the road. I could be wrong, but like I said, I've never heard of a recessed usb port. Have a great day and I hope this helps you out.
Posted on Jan 16, 2009
What kind of parts connect to connector2?
For this laptop?
http://www.msimobile.com/level3_productpage.aspx?cid=3&id=152
Right side of the laptop? 4th and 5th port back from the Front?
They are USB ports. A USB cable plugs into them.
Left side of the laptop? 2nd port back from the Front?
It is an HDMI port. An HDMI cable plugs into it,
http://en.wikipedia.org/wiki/HDMI
Plug an HDMI cable into it, then to an HDMI port on an HDTV that has this port.
X-Box, PlayStation, and Wi uses an HDMI cable, and plugs to this port on the laptop.
Just some of the uses.
Regards,
joecoolvette
Aug 10, 2012 | MSI ATHLON NEO MV-40 (L2100-036US) PC...
WHERE DOES MY STICK GO IN AN IBM THINKPAD LAPTOP
The model number is located either on the bottom of the right corner of the screen and on the label on the bottom of the laptop and the location and number of USB ports vary with different models.
The USB port is a connector/port that is 12x5 mm in size, some model thinkpad have onlt one USB port and some have 2 USB ports.
The USB ports are usually located at the back or at the sides of the laptop.
The T30 model has 2 USB ports at the back of the laptop located between the LAN and PS2 connectors.
The T40 model has 2 USB ports located at the left side of the laptop.
The A31p model has 2 USB ports located at the back left hand corner of the laptop.
The R32 model has 2 USB ports, one is located at the back left hand corner and the other is located on the left hand side of the laptop.
Feb 08, 2012 | IBM Computers & Internet
I own a Dell Latitude C610, how do i upgrade my usb 1.1 to 2.0? if i need any hardware can you please provide me with a link?
you will need to purchase a usb 2.0 pcmcia card.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=USB+2.0+PCMCIA+card&x=0&y=0
May 27, 2011 | Dell Latitude C610 Notebook
I want to purchase a laptop printer Canon bjc 80 will it connect to my vaio via the usb or whatever the 15 pin plug is on the left hand side
According to the specs this printer uses IEEE 1284 connection which is infrared. So you would have to have an infrared receiver/transceiver on your laptop or purchase and install one. In other words this printer does not connect directly to your USB port or your Paralell Port.
Mar 27, 2010 | Sony VAIO PCG-K35 Notebook
Acer USB Ports - Unknown Device - Will Run Mouse but not Printer
Sumtimez ports r damaged.somtimes not.. just chek other devices..if done..thn chek RAM!! lil chance tht u hv lost ur laptop!
Oct 12, 2009 | Acer Computers & Internet
I want to know and identify the parts of my laptop
On the right hand side starting from the front to the back, the ports are
1. (2) USB Ports
2. TV/Cable jack if applicable, some models don't have.
3. RJ-11 Modem Jack
4. Security cable Slot
5. Power Connector
On the Left side Starting from front to back. the ports are.
1. Express Card Slot
2. Digital Media Slot (below the Express Card)
3. 1394 (firewire) slot (some models don't have)
4. USB Port
5. E-Sata Port
6. HDMI Port
7. RJ-45 Ethernet Port
8. Expansion Port Type 3 (attaching docking station etc.)
9. External Monitor Port
Oct 10, 2009 | HP Pavilion dv6-1030us Notebook
USB port loose
Unfortunatley, there isn't an easy way to fix something that is physically broken. Your only options are:
1) Replace the motherboard of the laptop. (would need to be done by a professional, and may cost as much as a new laptop depending on the model)
2) Learn to deal with it. :)
Mar 19, 2009 | Computers & Internet
Usb ports not responding
Ports are need to be re soldered or replaced.
Mar 18, 2009 | Computers & Internet
Good evening....I own a model T43 Lenovo laptop. . Contiue to have pop up window telling me following: "Power Surge on Hub Port. A USB device has exceeded the power limits of its hub port. For assistance...
My friend had that happen to his laptop after something had shorted out in a USB port.
Any additional info would be great, such as things you did with the PC for prior to this problem.
Jan 04, 2009 | Computers & Internet
HP Pavilion zd8000 Notebook Logo
472 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
