Question about Alpine CHM-S620 6-Disc CD Changer
Changer does not work
When i put cds in the changer and hit the cd button on my radio it goes from disc 1 to 6 and then it says no disc when i got the car it played it just skipped alot not it does nothin at all please help im tired of listening to the radio
Had the same problem!! Found the solution here under "Wont Play" question. Push that cd chngr magazine (holder) all the way into the unit and tap with a blunt object( Dont tap too hard,it's plastic!!) screw driver worked for me! Push the eject button and you'll hear the unit working! Pop it in and out and it seemed to unfreeze whatever was frozen!! It finally loaded a cd and started playing again. I checked all 6 and they were okay!!
Thanks support guys for your help!!
I'm now a member!!
Posted on Jan 16, 2009
This happened to me, but after tapping countless times with a screwdriver with no result, I gave the changer a firm smack with the palm of my hand and it fired right up! cool site! thx 4 tha help!
Posted on Jun 15, 2009
Stuck CD in JBL 4 disc CD Changer / Navigation
before you press the cd on button keep holding the eject button while you press power on, I know this works for computers etc.
Feb 13, 2016 | 2013 Toyota Highlander
6 Disc CD Changer Error
Forcing the CDs back into the magazine may have damaged it.
Mar 09, 2014 | Cars & Trucks
We can't get the factory 6 disc cd player to load more than 1 disc. What is the sequence for loading additional discs?
The following is the owner's manual for your 2004 Dodge Neon:
http://www.dodge.com/en/owners/manuals/index.html?year=2004&nameplate=Neon
P.99 describes how to load discs:
1. Select and press any numbered button without an illuminated light above it.
2. Insert the CD while the light above the chosen button is flashing and the two lights on either side of the slot are illuminated.
3. Upon insertion, the CD will begin to play, and both the button light and the lights in the corner of the loading slot will illuminate.
4. Repeat the process for loading any additional CDs. The CD playe rwill stop while additional CDs are loaded.
Playing Discs
The radio will show the CD number, the CD track number, and the Track Time Elapsed while the radio is in the CD mode. IF more than one CD is loaded in the changer, the changer will automatically play the next disc after playing the last track of the current disc.
Wow, that's a lot of typing.
I didn't know the 2004 Dodge Neon had such a nice changer.
Good luck.
Jul 04, 2010 | 2004 Dodge Neon
Sony cdx-t69 CD Changer Unit
hi there that is sorta the problem i had and if you press eject nothing happens its still in there what i done was disconnect the battery for at least one minute and the cd changer lost its memory and was fine so i ejected the cd magazine and cleaned all the cds and blew out inside the machine has worked everytime its woth a try
Jul 01, 2008 | Sony CDX-T69 6-Disc CD Changer
Problem with 6 disc changer
Hi I believe it is tellinng you that you do not have a disc Jacket. The case that holds the 6 discs. If you have this the switch inside the CD changerneeds some investigation.
Oct 09, 2007 | Audiovox SP6CDP 6-Disc CD Changer
Won't Play CDs
hi make sure that you cart is inserted all the way in, push the eject button why hitting the mag with the handle of ascrew driver. this may dislodge the jammed arm/lever. otherwise its down to your repair agent.
regards
Mark
www.carradiospares.co.uk
Oct 08, 2007 | Alpine CHM-S620 6-Disc CD Changer
Changer won't acknowledge discs
regards
Mark
Jul 30, 2007 | Alpine CHM-S620 6-Disc CD Changer
Volume is uncontrolable
Hi sounds like you have the audio out from the cd changer connected to the RCA/Phono out of the radio. double check that the output from the CD changer is going into the correct phono/rca connector regards Mark www.carradiospares.co.uk
Apr 04, 2007 | Panasonic CX-DP88 8-Disc CD Changer
Kenwood KDC-C669 error message
HI when you put the mag in does it try to load? ie does the cd select the trays? if not then it sounds like you have a faulty unit and will need to get it repaired. regards Mark www.carradiospares.co.uk
Aug 15, 2006 | Kenwood KDC-C669 6-Disc CD Changer
Alpine CHM-S620 6-Disc CD Changer Logo
946 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
