Question about RCA CC-439 Camcorder
What is this camcorder?
Though this is not a 439, I saw no decent place to put this question (mods please move this to the appropriate place!). I have an RCA camcorder with the model number of CC275. It has an optical zoom only and a grayscale viewfinder, and no LCD. It records in VHS beautifully. Packaged with it is an A/V switch that changes the signal to a Channel 3 or 4 RF signal for connecting to a TV (similar to the original Nintendo game system), which hooks in close to the 1.5AH battery of unknown type (probably either Lead-Acid or NiCd, it's about an inch and a half thick). With its solid state image sensor, it records in VHS, High Quality, but cannot view in low light conditions. Controls for a high-speed shutter are also handy, as well as a macro lens button. Its lens is a 12 ~ 72mm witha 1:1.6 ratio. Focus is either auto or manual power, with controls to adjust the focus, as well as an auto-iris control. I'm trying to find a downloadable manual for it, as well as some accessories, such as a light. Has anyone heard of this camcorder? I used to see a bunch of these when I was a kid.
  • Roger Gilbert Jun 18, 2007
    It still works beautifully. I just need a manual!
3 Suggested Answers
SOURCE:
SOURCE: RCA CC617
Had the same problem took mine apart and found the ribbon cable going to the viewer was cracked and broken probably because of the flexing of the cable during adjustments. Not fixed yet.
Posted on Oct 17, 2008
techman007
  • 1112 Answers
SOURCE: camcorder won't record
Check the tape and make sure the record tab is still on the tape and has not been removed. If the record tab has been removed then use a new tape for recording as the unit will not record. This tap is usually on the lower left end of the back of the tape. When the tap is present it closes a record mode switch letting the system know the tape is able to bv recorded on..
Posted on Dec 27, 2009
Tip
How to Upload/Put and Play JVC, Panasonic, Canon Camcorder MOD Files on Mac
Similar to TOD, MOD is a kind of recording format being used in digital tapeless camcorder like JVC, Panasonic, Canon. MOD video format is comparable to XDCAM EX, HDV and AVCHD.
MOD is used exclusively for standard definition video files, while TOD is used for high definition files. Both MOD and TOD are file-based formats that are stored on a random-access media. Directory structure and naming convention are identical except for extensions of media files. Standard definition video is stored in MPEG program stream container files with MOD extension; in most other systems these files have extension MPG or MPEG.
The following list is about JVC, Panasonic, and Canon MOD camcorders.
JVC MOD camcorders
* 2004: GZ-MC100 (SD), GZ-MC200 (SD)
* 2005: GZ-MG30 (HDD), GZ-MG70 (HDD)
* 2006: GZ-MG37 (HDD), GZ-MG77 (HDD), GZ-MG505 (HDD, SD/SDHC card)
* 2007: GZ-MG130 (HDD), GZ-MG155 (HDD), GZ-MG255 (HDD), GZ-MG555 (HDD, SD/SDHC card)
* 2008: GZ-MS100U (SD/SDHC card)
* 2008: GZ-MG7230 (30 GB HDD, MicroSD)
* 2009: GZ-MG630 (60 GB HDD, MicroSD), GZ-MG670 (80 GB HDD, MicroSD), GZ-MG680 (120 GB HDD, MicroSD)
Panasonic MOD camcorders
* 2003: SV-AV100 (SD card)
* 2005: SDR-S100 (SD card)
* 2006: SDR-S150 (SD/SDHC card)
* 2007: SDR-S10 (SD/SDHC card), SDR-H18 (HDD, SD card), SDR-H200 (HDD, SD/SDHC card)
* 2008: SDR-H20 (HDD, SD/SDHC card), SDR-H60 (HDD, SD/SDHC card)
* 2008: SDR-S7 (SD/SDHC card)
* 2008: SDR-SW20 (SD/SDHC card)
* 2009: SDR-SW21 (SD/SDHC card)
* 2009: SDR-S26 (SD/SDHC card)
Canon MOD Camcorders
* 2008: FS100 (SDHC), FS10 (SDHC), FS11 (SDHC)
* 2009: FS200 (SDHC), FS21 (SDHC), FS22 (SDHC)
For Mac users, when they want to watch MOD files shot by JVC, Panasonic, Canon camcorder with iPad, iPhones, iPods, in Quicktime, in iMovie, in iTunes, or on PCs, etc. They may be annoyed that how to upload MOD files to Mac and play MOD video on Mac OS.
Now, there are tutorial and guide for you below will help you solve these problems.
1. Connect your JVC, Panansonic, or Canon camcorder to your Macs or PCs with cable USB or Wifi.
2. Turn on your camera and select the mode of camcorder like PC mode. iMovie on Mac will open automatically the Import Window.
3. You can review your video or select "Import All"and select your JVC, Panasonic, or Canon camcorder on the computer screen and click "OK."
4. All camcorder MOD videos will have the file extension "MOD" Once the backup is complete, then close the program.
After uploading your camcorder MOD files to your PC or Mac, you can use a MOD Video Converter for Mac to convert MOD files to Mac firstly, and then you can play JVC, Panasonic, or Canon MOD files on Mac. More information about how to convert MOD files on Mac and edit MOD files on MacOS you can click here.
on Aug 12, 2010 | Computers & Internet
I need to take what i recorded and put on my computer to burn on a disk...how?
Since the camcorder records on Mini DVD+/-R and RW, and SD/MMC cards, just eject the media from the camcorder and insert it into the appropriate drive on your computer. Open the burning software of your choice (which you may or may not already own) and follow the directions for burning the files with that software. If the disks are DVD RW or SD/MMC delete the files after burning is complete. Even though the manual states that it will work with DVD-R, the camcorder seems to have issues finalizing these particular formats, so I recommend using DVD+R and DVD+RW. I hope this helps and good luck. Please vote appropriately and leave a comment.
Oct 30, 2009 | Samsung SC-DX103 DVD Camcorder
JCV MOD conversions to MPEG
How to convert .MOD file to mpg, avi, wmv and others?
If you got a JVC camcorder, or Panasonic camcorder or Canon MOD camcorder, you would have probably encountered such issue--- what to do with the MOD/TOD files----the God forsaken video format? And you want to convert the recorded .MOD file type to mpeg, avi, mkv, flv, mp4, wmv or whatever more common, so that you can put them on Youtube, Myspace, Google video and Hulu later on to share the camcorder video with your friends or more people? And there is another headache thing is that most major video editing suites seem to unwillingly accept the MOD/TOD format. Even windows video maker, I have to say it's too complicated to use
Someone successfully made it simply by changing the extension from .mod to mpg, but for most people, they just failed only to find there is no audio after the extension is changed, or the changed one doesn’t allow you to import these files into Windows movie maker, not to mention upload some video to Youtube.com or Facebook.
any alternativs? There is a very simple program that convert .mod NOT ONLY to mpg but many others like avi, mkv, flv, mp4, wmv, rm, rmvd, mov, dv, mg2 and swf. MOD converter is the one shoot all the trouble. This excellent mod conversion tool is not just a converter but also a video editing tool. From now on, with the MOD converter, you can enjoy your mod video on many media player, even on portable devices like blackberry, Gphone, PSP, Creative Zen,etc.
MOD converter is a package tool, whcih actually includes mod to mpg mod to mp4 mod to avi mod to wmv mod to 3gp mod to mov
May 18, 2009 | JVC Everio GZ-MG130 Camcorder
Device has malfunctioned and Windows does not recognize it.
Hi
i m having the problem with my USB while connecting the my mobile (USB Port) i m getting the following message
"problem attached to this computer has malfunctioned and windows does not recognize it "
Please help me, how to resolve the my problem ?
Thanks n Regards
Srinivas.T
Apr 16, 2009 | Pure Digital Flip Video Ultra Camcorder
Get no sound when download movie from camcorder
this is a common issue to many camcorder users,
the camcorder video downloaded to where?
you know that some video editing suite won't accept .mod or .tod file that mostly exported from camcorder like jvc, sony, cannon. so you might need to convert the .mod or tod to common format like mpeg, avi or wmv.
i have successfully helped some guys by recommending them to use mod converter
take your time finsh reading the article below, hope this helpful.
Things will be easier if you take a moment to finish reading the Step by Step on how to convert .mod to mpg, avi, wmv and others
Step by Step
How to convert .mod to mpg, avi, wmv and others?
Step1 Turn on your pc. Download and install MOD converter
Click here to download and install it by running iOrgsoftmodconverter.exe
Step 2: Turn on your camcorder and connect it to pc. Import the .MOD file onto PC.
Run MOD converter; select the .MOD file you want to convert by clicking the Add or File button to load MOD info. Click the profile button to define the output video format.
Step 3: click the Edit button to set detailed info for the desired video.
A. Click the Trim button to set the length/range of the video that need to be converted.
You can choose a part of a MOD or the whole one to convert
B. Click the Effect button to tune the saturation, contrast, brightness values and make sure are the one you preferred, preview the change on the screen.
C. Click the Crop button to cut the unnecessary part or black part of the movie.
D. Select .AVI or .MPG and select the directory that you’d like your file stored to.
Step 4: Convert video
After all settings is done. You are ready to start conversion. This step will take you a while to carry out the conversion process, the time vary with different parameters you set.
MOD converter is a package tool, whcih actually includes mod to mpg mod to mp4 mod to avi mod to wmv mod to 3gp mod to mov mod to ipod mod to iphone mod to psp mod to iriver mod to creative zen mod to apple tv mod to blackberry mod to zune Wait a minute, if your exported camcorder video is in a .tod extention file style , it doesn't matter, we have TOD converter
Mar 27, 2009 | JVC Video Cameras
Conversion of .mod file.
How to convert .MOD file to mpg, avi, wmv, mp4,mkv, flv and other common video formats?
People who own JVC MOD camcorders, Panasonic MOD camcorders or Canon MOD camcorders encountered the same issue with--- what to do with the MOD files---the God forsaken video format. And they hope that there is a magic tool to convert the recorded .MOD file type to mpeg, avi, mkv, flv, mp4, wmv or whatever more common, so that they can put camcorder video on Mysapce, Google video, Hulu later to share with more people,...and thers is another headache thing is that most major video editing suites seem to unwillingly accept the MOD format. even windows video maker, i have to say it's too complicated to use
any simple soulution? There is a very simple program that convert .mod NOT ONLY to mpg but many others like avi, mkv, flv, mp4, wmv, rm, mov, dv, mg2 and swf. MOD converter is the one shoot all the trouble. This excellent mod conversion tool is not just a converter but also a video editing tool. From now on, with the MOD converter you can enjoy your mod video on many media player, even on portable devices like blackberry, Gphone, PSP, Creative Zen,etc.
Step by Step
Click here to download and install it by running iOrgsoftTODconverter.exe
Wait a minute, if your exported camcorder video is in a .tod extention file style , it doesn't matter, we have TOD converter .
Mar 09, 2009 | Panasonic SDR-H40 HDD Camcorder
MOD file
The MOD file is just MPG format,
a simple MS-DOS command line instruction to rename your MOD files to MPG files (first copy your camcorder-harddisk files to PC-harddisk). I use to do the same!
Just execute the following command in the proper directory (or place this line in RENAME_MOD2MPG.BAT, and execute BAT file by doubleclick); the command assumes the JVC 3hexa-digit method of numbering:
ren MOV???.MOD MOV???.MPG
Oct 21, 2008 | JVC Everio G Camcorder
What the heck
try renaming the .mod to .mpeg, but I would suggest making a copy first
Jul 02, 2008 | JVC Everio GZ-MG130 Camcorder
Jvc everio editing software
Have a look on the site http://www.convertmod.com, you will find your happiness with this wonderfull software that converts .mod files and that converts .tod files
Oct 09, 2007 | JVC Everio GZ-MG21 Camcorder
RCA CC-439 Camcorder Logo
87 people viewed this question
Top RCA Video Cameras Experts
Marvin
Marvin
Lawrence Oravetz
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
