Question about Lexmark P6350 All-In-One InkJet Printer
AOIC exe is not responding 6350 all in one
Lexmark 6350 All In One
downloaded drivers from website for new computer
can't find original disks
5 Suggested Answers
SOURCE: Lexmark X1270 scanner problem
The only way i can get my Lexmark X1270 to scan is to use the Windows Vista "Windows Photo gallery" to scan :
Start > All Programs > Windows photo Gallery > File > Import from Camera or scanner > select the scanner > save scanned file to your computer
This is the only way I have been able to use the scanner on my lexmark X1270,hope it works for you too.Be lucky.
FossyBear
Posted on Dec 18, 2007
THANK YOU THANK YOU THANK YOU.
After downloading all the X1270 drivers for Vista - and my gods, there are alot of them - the darned thing refused to scan to Photoshop, my main program. Without your help, Fossybear, I'd still be stuck cursing and gnashing my teeth. Stupid thing. Gosh.
DeerRaven
Posted on Jul 31, 2008
SOURCE: Installation of a downloaded driver for Lexmark X1290 All-In_One
I bought a Lexmark X1290 printer and installed a wrong driver (for WinXP) from the enclosed CD. Then I could not run the All in One program. After many reinstallation attemps, I finally found a solution (which is unfortunately quite hidden at the Lexmark website):
1) Unplug the printer's USB cable from the computer.
2) Download the cleaning utility from ftp://ftp.lexmark.com/driver/inkjet_drivers/Cleanup/.
3) Double-click on the cleanup utility and follow the on-screen instructions to run it.
4) Restart the computer.
5) Download all files from ftp://ftp.lexmark.com/driver/inkjet_drivers/Cleanup/reg/
6) Follow the instructions in the "Vista BackDoor Instructions.txt" and delete all remaining Lexmark
keys in the registry.
7) Restart the computer
8) Download a proper driver for Windows Vista from the Lexmark website.
9) Install the driver accordingly to the instructions (it's important to plug the printer's USB cable when you are ask to, not before)
The problem with Lexmark Unistall and CleanUp Utility is that you cannot delete all Lexmark registry keys while you arelogged in the system. This is anellegant way how to circumvent the problem.
Posted on Sep 14, 2008
SOURCE: Trying to download printer driver for lexmark z645 series
I've lost my installation driver of Lexmark Z645 printer... how can i get the driver?
Posted on Dec 05, 2008
  • 8 Answers
SOURCE: aioc.exe
What you need to change is your screen resolution to either 800 x 600 or to 1024 x 768 (in your desktop settings)
What is happening is that your Lexmark all-in-one center doesn't think your monitor can handle the program (or something to that effect).
You will NOT have to restart your computer either.
Just restart your Lexmark All-In-One program and you can start scanning.
Posted on Jan 07, 2009
I tryed to scan a paper. When I went to the lexmark imaging center and pressed scan it says, "Preparing lexmark all-in-one-center for first use, Searching for applications" then it goes to AIOC...
You have to uninstall the printer, go to lexmark site and download the most current driver (it's free), then reinstall your printer. make sure you restart your computer before you download new driver.
Jul 31, 2011 | Lexmark X2350 All-In-One InkJet Printer
I have a Lexmark x2500 and I had the same problem. I went to C:\drivers\printer\2500\applications/setup.exe and ran the program. It said everything is ready but when i open up Lexmark Image Studio, it...
Uninstall the existing printer driver first. On your computer, go to Start menu > Programs / All Programs > Lexmark 2500 Series > Tools > Uninstall. Your computer will then start the uninstall process. Reboot pc when prompted.
Download and install the Lexmark X2500 using the downloadable driver available in the Lexmark website at http://bit.ly/aKlcOJ. Select your operating system, download and execute the file. Follow the instructions on your computer screen.
Jul 28, 2011 | Lexmark X2500 All-In-One InkJet Printer
New computer will not run the printer. The all in one lexmark X4270 purchased in 2005. New computer e machine bought yesterday 3/17/10 at best buy. The disc will not run, printer is not working. Computer...
You may have done this already but go to www.lexmark.com and go to the support/downloads tab and search for your printer. Download and install the printer driver for your printer which is for Windows 7. let me know if this works.
Mar 19, 2010 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X1155 all-in-one software download ndows 7
Hi. There is a Vista driver available for download in the Lexmark website. The driver is compatible with Windows 7. Before downloading, check if your computer is running on 32-bit or 64-bit operating system by going to Start > right click on Computer > Properties. To download, click on this link to the Lexmark website. http://bit.ly/9R9E0w . Then, click on the Microsoft tab on the center of the page.
For 32-bit operating system:
- download cjrX1100EN.exe
For 64-bit operating system:
- download cjsX1100EN.exe
Hope this helps.
Mar 12, 2010 | Lexmark JetPrinter X1185 All-In-One InkJet
Xp to windows 7 printer is ok but have lost the imaging studio
Hi. Try downloading the driver available in the Lexmark website. The driver is for Vista operating system but it is compatible with Windows 7. Before downloading, check if your computer is running on 32-bit or 64-bit operating system by going to Start > right click on Computer > Properties. To download, click on this link to the Lexmark website. http://bit.ly/ajIYH7 . Then, click on the Microsoft tab on the center of the page. Download cjr4300EN.exe for 32-bit or download cjs4300EN.exe for 64-bit. Hope this resolves your problem. Good luck!
Mar 12, 2010 | Lexmark P4350 All-In-One InkJet Printer
Upgraded to Windows 7 and now my Lexmark X6750 printer won't work
Hi. If your printer is the X6570, there is a driver for Windows 7 available for download in the Lexmark website. First, you have to uninstall the existing driver. Go to Start > Programs > Lexmark 6500 Series folder > Tools > Uninstall. Then, reboot pc. Also, checkif your pc is running on 32-bit or 64-bit operating system by going to Start > right click Computer > Properties. To download the driver, click on this link to the Lexmark website. http://bit.ly/9iZgtC . For 32-bit, download cjb6500Win7en.exe. For 64-bit, download cjq6500Win7en.exe. Then, run the installation software. Hope this helps.
Mar 10, 2010 | Lexmark X6575 All-In-One InkJet Printer
Hi ,,,,I have a Lexmark x 7170 working ok on XP profissional ,but NOT working with my new computer Window 7 I have the originl CD but probably needs updates ..Tried updates from websites but still not...
Hi. I presume you already tried installing the software using the the cd. You need to uninstall the existing driver first by going to Start > Programs > Lexmark folder > Uninstall. Reboot pc. Then, check if your pc is running on 32-bit or 64-bit by going to Start > right click on Computer > Properties. Then download an updated version of the driver from the Lexmark website. It's a Vista driver but compatible with Windows 7. Just click on the link to the website. http://bit.ly/aFWPZx . Click on Microsoft tab on the center of the page. Download cjr7100EN.exe for 32-bit or download cjs7100EN.exe for 64-bit operating system. Hope this will resolve your problem. Good luck!
Feb 20, 2010 | Lexmark X7170 All-In-One InkJet Printer
Lexmark printer 6350
To download the drivers, Please click on the below link or copy the URL and paste it in your web browser. Select the operating system you are using and click on the download to download the driver.
http://downloads.lexmark.com/perl/downloads/downloads.cgi
To ad the printer. Click on the below link and follow the steps....
http://kb.iu.edu/data/aksl.html
Thank you........
Sep 18, 2008 | Lexmark P6350 All-In-One InkJet Printer
Lexmark x1270 printer.
You might want to download the Vista drivers from Lexmark Canada website.
It works perfectly fine for me.
- JNY Consultants Inc. Toronto, Canada.
Apr 16, 2008 | Lexmark X1270 All-In-One InkJet Printer
FossyBear
Dec 11, 2007 | Lexmark X1270 All-In-One InkJet Printer
Lexmark P6350 All-In-One InkJet Printer Logo
114 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
