Question about Dell OptiPlex GX260 PC Desktop
Computer turns on and beeps.
That pretty much it, I can turn it on and there is just one long Beep. Nothing comes up on the monitore, just one long beep from the computer.
    Problem Solver:
  • 10 Answers
I suggest you check you memory sticks, and make sure they are seated properly. The long beep usually signifies a memory problem. If you have 2 memory sticks, I suggest removing 1 of them, then tuen on the PC, if it still beeps, powerdown by holding the power button in until it shuts down, then replace the removed one, and remove the other, if it boots, fine, then you will need to replace the memory that you have removed, but,,,,,if you only have 1 memory stick, I suggest you replace it, if the pc still beeps a long beep, then 1 of the memory sockets is bad, and a motherboard replacement is needed, either case, that long beep is a memory problem.
Posted on Jun 17, 2007
Computer won't come on
All computers have beep error codes, if you provide the following details I may be able to help.
1 Make and model of PC
2 error code ( you can count the code for example: 123 could correspond to
Beep - pause- beep beep - pause - beep beep beep
3 does the fan turn
4 does the monitor turn on ok
5 can you hear the hard drive an DVD rom spin a little then go quiet or do they spin and then chuntle on for a little while
Nov 25, 2016 | Computers & Internet
Desktop: Gateway LX6810-01 PC will not power on. When I hit the Power button on the tower, a long continuous BEEP comes on and nothing appears on the monitor. After the BEEP, the On light (on tower)...
Thank you for using FixYa
I would try shutting down the computer in the normal way, and turning off the monitor.
Boot up and turn the monitor back on.
If it still doesn't work, then I would check the cables and power plugs and wall plugs.
Check the mouse and keyboard cable and any other cables plugged into the computer.
The next step requires a seperate monitor or laptop.
Try unplugging the monitor and pluging in another monitor. Most laptops have a common
VGA adaptor jack or even an Svideo jack.
If the other monitor does not work, Then take to a qualified technician for repair.
It could be your power supply in the computer or video controller.
I hope this was useful and please comment if this was helpful to you.
Mar 24, 2011 | Computers & Internet
Unable to see monitor. saying no signal. Will not switch to monitor. When I turn computer on I hear a beep beep beep beep. Then nothing
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your
((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Jan 03, 2011 | Computers & Internet
MPC model D945GCZ serial:4237231-0001 INTEL
It should at least beep. Those beeps are diagnostic codes. Listen to the beeps and google 'bios error beep codes'. If it doesn't beep, the motherboard must be replaced.
Apr 20, 2010 | Computers & Internet
No input signal
that is the problem of cpu not a monitor to confirm disconnect signal cable and power on. monitor will show "no signal check signal cable" it means that monitor is ok and fault lies in cpu .then open the cpu and disconnect ram and listen the beep. contineus beep should be heard then ram is faulty replace it. if no beep heard then motherboard is faulty .
Mar 08, 2010 | HP vs17
My hp computer wont display picture and makes a beep noise when i turn it on
It should make one beep. That means it passed the self-test.
If there is nothing on the monitor (is the monitor light green or yellow?)
then the monitor is bad.
I suggest you try another monitor to be sure. Borrow one from a friend.
Dec 10, 2009 | HP Pavilion 512n PC Desktop
Monitor won't turn on.
There is a component/s failure...this is a job for a Techo
Oct 19, 2009 | Samsung T220HD LCD Monitor
Monitor beeps when turned on no picture
disconnect signal cable if monitor show massage no signal check signal cable then monitor is ok then open cpu check whether dust is in ram then clean the dust and again fit the ram the problem will be solved if not then disconnect ram listen beep and if contineus beep comes then motherboard is ok if no beep then motherboard is faulty replace it
Nov 26, 2008 | NetTV DTV 34XR 34" CRT Monitor
Computer will not load anything
Turning you rmonitor on then your comp my monitor has a delay and if i dont turn it on before i turn my comp on or before i here the little beep noise my comp makes the monitor wont display anything.
Jul 14, 2008 | Systemax AOL Optimized PC (100607) PC...
My monitor screen stays black when i turn my pc on help
have heard some beep,eihther long beep or short beep? if you heard a short beep replace your memory and when it is long beep replace your video card but if no beep,there is a problem in your motherboard
Nov 01, 2007 | Fujitsu Siemens Siemens Business Line 19P4...
Dell OptiPlex GX260 PC Desktop Logo
1,409 people viewed this question
Clive
Clive
Alun Cox
