Company sent replacement part and said there would also be instructions on how to install. No instructions were sent. I can probably figure it out but would be nice to see a diagram or some form of instruction.
1) Copy following links:
http://waterheatertimer.org/How-to-replace-thermocouple.html
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
2) Inspect for broken TRD
http://waterheatertimer.org/How-to-repair-Rheem-TRD.html
3) Rheem air intake located below combustion chamber.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: can no light up a new Rheem 22V40FN water heater
Air in system. Make sure there is no sources of ignition and loosen the supply line at the heater and purge all air. Mske sure your source valve is open. then turn off yje heater after tightening the line. Let sit in off position for 15 minutes. Then turn therm knob to on slowly and then over to pilot, depress pilot button and hold a ffew seconds. Pilot should light. If so, hold for a few and then release and turn ti on position. Good Luck.
SOURCE: I have a Rheem 50 Gal. Power Vent 2 hot water tank
Don, if you have done this before go for it. If not call a pro,you will thank yourself later!
SOURCE: Pilot light won`t stay burning on my hot water
check gas pressure best of luck isn,t set to high best of luck
SOURCE: I have a Rheem 50 gal. natural gas water heater
The most common reason a pilot light will not stay lit is a bad thermocouple. How old is the water heater? If the pilot light will light, but then go out when you release the safety button, that is a sure sign the thermocouple is bad. You can buy a replacement thermocouple at your local home improvement store. There is a small chance that the control valve has gone bad, but that is highly unlikely.
SOURCE: working on a 3yr old
Sorry to read about your problem, I hope this helps you out.
That means you gas control valve is defective....
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
