Hi, I have a similar probleem with my Sony KP-41T15. It had a really distorted picture so I replaced the STK chips under the advice of someone. The picture has improved greatly however now I can't get the convergence in on the edges of the screen. I didn't change any resisters (which I read about after) but I don't think the chips blew again. I also read how to get into the service mode and possibly adjust it there but don't know how to navigate through it. I'm not sure where to go from here. Could the resisters be causing this problem even if the chips are ok? If not, what else can the problem be? Any help would be appreciated.
Comments:
Jan 16, 2009
- I will replace the pico fuses, there cheap anyway. As far as the service manual, I did a search on that sight and didn't come up with anything for my model. I might need some direction as to which ones they are. I don't remember what site I was on when I read about them.
most likely cause is one of the 3.5 amp picos have blown when the old Ics failed. You can get replacement picos at the following link, and they also have the service manual which will explain how to adjust the colors through the service manual. Here is the link. http://servicemanuals.vstore.ca/
I got very blurry image... on my sony kp-41s4 projection tv and want to know if i can do something...
(More)
I got very blurry image... on my sony kp-41s4 projection tv and want to know if i can do something about it
i have a sony kp41t65 television, the varister from ey33 to ey34 smokes/burnt out.. i need the value...
(More)
i have a sony kp41t65 television, the varister from ey33 to ey34 smokes/burnt out.. i need the value or part # to order and try to replace myself,,am having problems downloading a schematic to find the info.. can you help
I have a sony kp-41t65 tv, I purchased it new in 1998. Today it's acting like a computer screen at...
(More)
I have a sony kp-41t65 tv, I purchased it new in 1998. Today it's acting like a computer screen at is out of whack. The tv screen at the top bowed inward towards the middle in the middle of the screen, bottom same as top but upwards. The colors are out making the letters and numbers look doubled. I realigned them it helped the middle to cear up but top and bottom still the same. If you could help Thank you very much!!!!!!!! Dennis
