Question about RCA F32632SB 32" TV
Need to locate the pincushion circuit on RCA F32632SB 32" TV
Where can I get a free manual or pictures to help me locate this circuit and then narrow the circuit down to a bad component?
  • ddempdd Jan 16, 2009
    Yes, The Model # is CTC187CH3.
  • rah1379 May 11, 2010
    can you tell me the model (ctcxxx)?
  • 120 Answers
Ok this might help rca labels their circuits this way..
0000 tuner
1000 the tv processor
1100 remote receiver
1200 audio IF
1400 a/v hifi outputs
1500 s-video inputs
1700 stereo audio demodulator
1900 audio output
2300 video IF
2400 sync separator
2700 luminance processor
2900 rgb bias and drive
3100 system control
3300 analog interface
3400 front panel assembly
3600 tuner control
4000 ac input
4100 b+ regulator
4200 degauss
4300 horizontal osc.
4400 horizontal output
4500 vert deflection
4600 standby regulator
4700 secondary power supplies
4800 pincushion correction
4900 x-ray protection
5000 kine driver
7500 fm radio
Posted on Jan 15, 2009
RCA G35831AT
This is a loss of the "pincushion correction" circuit. These sets are known for bad high voltage capacitors in the horizontal circuit that cause a loss of pincushion correction. It could also be loose solder connections in the horizontal circuit. This can be a dangerous circuit to work with. Have a shop check it for you. Thanks for using fixya.
Jan 11, 2010 | RCA G35831AT 35" TV
I need to find the pincushion circuit on my RCA F32632SB TV to check a problem with the TV displaying an hour glass picture. Where can I find a picture of this or a manual to guide me to the circuit?
The pincushion it intimately related to the horizontal circuits,the electron beam must travel farther to reach the corners of the crt and it does to the middle and so without pincushion circuits the raster would be bowed in on the sides on crts 27 inches are larger.Pincushion corrections straightens the raster by modulating the horizontal yoke current at a vertical rate.In an RCA tv the pincushion circuits are usually numbered 4800and the pin amp will probably be numbered 4801,its drive transistor should be Q4802,R4802 will be the width control,and R4805 the e/w pin amplitude. its inputs from the vertical should be Q4801 (subtractor) Q4803 (buffer) you should have a parabola waveform at 4801,yoke current can be modulated here without effecting high voltage.when Q4802 conducts voltage should decrease across Q4801 and the voltage drop across the yoke increases. The east west pin amp control 4805 controls how much of the vertical parabola is input to U4801 to compensate for changes in width caused by variations in beam current.By varying the e/w control resistor you can know if the circuit fault is in the input or output,if the picture varies in size the fault is in the input to U4801,if it does not vary check the output or U4801......hope that helps
Jan 15, 2009 | RCA F32632SB 32" TV
Hour Glass picture on a RCA TV F32632SB
I looked up this model and found the following electolytic capacitors to be the most likely culprits within the pincushion circuit. Check these first. The starred one is the one I have replaced in the past to resolve this.
C4851 10ufd 50V
C4853 10ufd 63V
C4854 2.2ufd 100V
C4855 2.2ufd 50V
* C4862 100ufd 25V
Good luck,
Dan
Jan 13, 2009 | RCA F32632SB 32" TV
Have you ever had this problem?
Sorry Ginko, but a convergence problem would have the curves down from the top and up from the bottom. The hourglass shape is a pincushion problem. This can be as simple as a bad capacitor in the pincushion circuit.
Could you please confirm the model number so I can look up the probable part?
Thanks,
Dan
Jan 08, 2009 | RCA F32632SB 32" TV
RCA TV with an hour glass shaped picture
I am sorry that its took so long for me to reply been backed up in shop, anyway what you have is bad solder joints on large Diodes Resolder ends on all of them and this should slove your problem if you havent done so by now.
Aug 02, 2008 | RCA F32632SB 32" TV
#F32632SB Picture problem
I know what is wrong with your set but i am not at my shop in order to let you know what it is,it is a cap in high voltage area.let me know if you still need help with this.
Jul 06, 2008 | RCA F32632SB 32" TV
Picture, No Sound
Try unplugging the tv for a few seconds, this will reset it. Also check the menu and make sure the speakers are on.
Sep 08, 2007 | RCA F32632SB 32" TV
Sound but no picture
yes the tv is fixable an estimated cost is about $40.00 to a $200.00.the problem is in the video circuit.
Apr 01, 2007 | RCA F32632SB 32" TV
RCA F32632SB problem
That is a coil for the pincushion circuit in the TV. The part number is 215506 and here is a link to purchase the part. http://www.partstore.com/ProductDetail.aspx?ProductSKU=2149167&ProductType=PART
Mar 05, 2007 | RCA F32632SB 32" TV
Televison & Video Logo
620 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
