Question about Kenmore 44042 Front Load Washer
Front loading wash machine
I have a Kenmore front loading wash machine, model 417.44142400. It is making a loud buzzing sound when I pull the start knob to begin the wash cycle. The water fills, but the door can be pulled open easily, rather than being locked as it should. Any suggestions?
  • trish lopacienski Jul 24, 2007
    I've already had it fixed, but you were correct. Thanks for your input.
  • 641 Answers
It sound like door lock unit is broken or removed from the door. Good luck !
Posted on Jul 23, 2007
Where is the filter on my Kenmore 44072 washer?
you have a sock or simler item stuck in you pump .adrianxxx
Jun 19, 2012 | Kenmore 44072 Front Load Washer
Very loud banging noise when front load washing machine spinnning
Ensure that the appliance is balanced/level on the floor. Contact an appliance service company.
Feb 22, 2010 | Kenmore HE2 Plus Front Load Washer
Washer runs until rinse cycle, then starts making
pull problem code from machine. give knob a turn to wake machine-wait 5 seconds-then hold down start and cancel buttons at the same time. Your problem code will come up.
Nov 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore front loading washer won't drain or aggitate, just buzzes
take the front bottom panel off. inside there is a drain pump. you need to remove filter from drain pump its look like a knob. be careful because their is water inside your drain pump so use some big thing for water. clean your filter. put filter back tight. i hope will solve your problem.
May 23, 2009 | Kenmore 43142 Front Load Washer
Buzzing/Ratcheting sound while drying
Hi, Try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
May 19, 2009 | Kenmore HE2 Plus Front Load Washer
Top load washer machine will not agitate
Hi There,
Check to see that the belt is being driven by the motor when it goes into the wash cycle. Let me know if this helps and thank you for using FixYa!
Mar 10, 2009 | Kenmore 24902 Top Load Washer
Nd error essage
nd= no drain. loud buzzing noise sounds like something stuck in pump assy.remove the door(2screws) adn other 2 screws oppisite side, and hte front panel comes off giving you acess to the drain pump, pull the hoses and look for the obstruction
Mar 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 44042 Front Load Washer Logo
187 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
