Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
Open power cord housing on kenmore 116 vac
My Kenmore model 116 vac won't retrieve the power cord back into the spring-leaded reel. Thank you.
  • 3 more comments
  • zitaray Jan 15, 2009
    Dear MrMark52,
    Before buying a new reel assembly, I want to get inside to determine if that is in fact what's wrong. I have been able to remove the two screws on the front part of the motor and reel housing, but there is still something stopping it from coming off (either one or more screws or possibly a lip in the plastic?) at the back of the housing. I believe it is underneath the on-off pedal at the back just above the cord hole, but I can't get inside under the pedal without risking damaging the housing itself. Thank you.
    Ray
    Dear MrMark52,
    Thank you for your excellent help. And unbelievably prompt! Unfortunately the Model # 116 2421590 which I took off the plate on the bottom of the canister seams to be wrong or something. Sears tells me: "We're sorry. No exact matches were found." So I have not been able to access their page with the exploded view and parts list, etc.
    Do you have any suggestion?
    I hope having to do multiple responses doesn't dilute your profit on this case.
    Thank you for everything you have done and all the best to you.
    Zitaray
  • zitaray Jan 17, 2009
    Dear MrMark52,
    Thank you very much. I can't understand how you can do this stuff for free. Anyway, I want the company to hear that you were, masterful in handling my request, and prompt beyond belief!
    A grateful zitaray.
  • Mark Egan May 11, 2010
    The spring is probably broken inside the reel. It is normally replaced as an assembly with a new power cord.
    Please provide the Sears P/N and I can help you further.
  • Anonymous Mar 22, 2014
    will not turn on
    President:
  • 1,214 Answers
You can go to the Sears Parts Direct website and type in your Model number. It will return both an exploded view and parts list, with pricing for replacement parts. You can also order from them, and they can tell you stock status as well.
Posted on Jan 15, 2009
  • Mark Egan Jan 16, 2009
    Thanks Zitaray, and I'm doing this free gratis.
    Take the space out of the number 1162421590 .
    I found it.
  • Mark Egan Jan 19, 2009
    Thanks zitaray!
How do I change the belt on Kenmore vac model # 116 32213200?
Your model has two levers on top of the nozzle housing that you slide to allow you to remove the cover to gain access to the belt and brush roll.
Dec 21, 2014 | Kenmore Vacuums
Help! i have a whispertone 300 model 116 28612790. the retractable cord is jammed & i could only get the front part of the canister open that houses the motor, etc. there are only 2 screws to open it...
even if you get it apart chances are it needs a new spring but it requires a special tool to get the rubber molding off that separates the top from bottom and sears repair guys and vacuum shops have them. I would take it to a used vac store and get them to fix it before you try yo remove the rubber seal as it will not go back on well and that will cause the machine to not get aproper seal and lose airflow.
Oct 06, 2010 | Kenmore 23313 Whispertone Bagged Canister...
Model 116 Kenmore vacuum cleaner. 20+ years old,
Greetings,
I believe that this is probably a Kenmore Canister vacuum cleaner, but I can't be positive. The model number 116 is just the first part, and all Sears vacuum cleaners start with model 116. There is a . after the 116 that will identify the vacuum. If you'd like me to be more model specific, or if this is an upright vacuum, please just request a clarification and I can take pictures even for you.
If this is a canister style vacuum, then you'll need to remove the foot pedal that rewinds the cord reel. There are 2 or 3 (depending on which model you have) hidden screws underneath of this pedal. You may simply pry off the pedal using a flat head screw driver. Also when you have the bag door open, you may just pull forward while it's open, and this will remove the bag door housing. There should be two screws in the front of the motor housing that need to be removed as well.
My guess from the age of the vacuum that's probably the motor that's gone. If this is the case, you probably can still get a motor if you'd like to just replace the motor inside, rather then buying a new vacuum. Typical Sears Kenmore canister motors sell for 79-120 dollars.
Again, I'd be happy to try and help you further, I will just need the entire model number after the 116. to know which vacuum you have.
If this was helpful, please click the 4 thumbs up icons in the top of the page. Thank you,
Chris J.
Mar 21, 2010 | Vacuums
Also have a Kenmore Model 116. Power retractor not holding cord
The cord winder on these is spring loaded and has cog which is meant to lock with every full rotation of the spool the cord winds onto. It is tricky to work on.
Try pulling a bit more slowly and see if the rewind will stop.
The back housing on top of the vac needs to be removed to access the rewind. The housing snaps into place at the back corners, generally must be carefully pried and popped off by someone familiar with the vac. Some models may also have 2 screws under the lid in the bag area.
Sep 10, 2009 | Kenmore Canister Vacuum Vacuum
How do you take the canopy cover off of a kenmore cannister vac?
Flip the vac upside down and look for two screws from the underside near the wheels. If they are not visible you will need to remove hidden screws from above by prying gently at the back of the vac where the body panels meet at the bumper. Also look for two vertical screws in the bag area.
Sep 02, 2009 | Kenmore Vacuums
Kenmore whispertone 100 model 116. powerhead no
  • The motor / cord compartment cover must be removed to access the cord reel. There are four screws that hold the cover to the chassis. Two of the screws are found under the cord-retractor-foot-pedal on the top back of the canister. To access these screws the pedal must be removed. To do this, press the pedal down and look (from the top) for the four plastic clips that attach/hold the pedal hinges to the cover. There are two at the end corners and two in the middle. Using a long, thin flat-head screw driver (or similar instrument) press each clip to unhook/popout the hinges. Note: the foot pedal spring will also come out when the pedal is removed.
    The other two screws are found under the curved hinges of the vaccum bag compartment cover. To access these, lift the cover as if accessing the vacuum bag. Keep pulling the cover back until the hinges release from the motor cover. Don't worry, it is disigned to do this and will not break but it may require a little force. A long phillip-head screw driver will be needed to access and remove each screw
Jul 18, 2009 | Panasonic Kenmore Canister Vacuum Vacuum
How do I open my Kenmore Whispertone 12.0 to get to the cord reel
The other two screws are found under the curved hinges of the vaccum bag compartment cover. To access these, lift the cover as if accessing the vacuum bag. Keep pulling the cover back until the hinges release from the motor cover. Don't worry, it is disigned to do this and will not break but it may require a little force. A long phillip-head screw driver will be needed to access and remove each screw. Good luck. - Gary
Mar 30, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Need Manual for Kenmore Progressive with Direct Drive vacuum clea
You can check for the manual at:
www.managemyhome.com
I would suggest checking the hoses for clogs. Especially the hose right after the carpet brushes. Don't forget to clean off your brush. Hope this helps.
Jan 12, 2009 | Kenmore 31913 Progressive Direct Drive...
Kenmore/Sears Progressive 116 How to get housing off to replace cord
There are four screws, two at the front and two at the back under the step bar that rewinds the cord.  It lifts off from the bottom.  Be careful not to snap off the tabs.
Sep 20, 2008 | Kenmore 23913 Progressive PowerMate Bagged...
Need to replace power cord and can't find how to open canister to replace
I had the same problem and could not find the other screws. You need to pry off the power cord retraction button, you will find two more screws under there. It's pretty easy after that!!!!
Jun 02, 2008 | Kenmore 22612 Bagged Canister Vacuum
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
1,827 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
