Question about Braun M880 MultiMix Hand Mixer
Bottom Slide Cover (Part 2a in the manual)
The bottom slide (that covers the opening for the handblender attachment) popped off of my blender. I cannot get it to reattach straight, so now that blender only works on bursts or at high speed (there is no response on the slower speeds). Is there a trick to working it back in? Thanks in advance!!
    Habit-Forming:
  • 57 Answers
See the description for the speed problem and repositioning of the slidere at this link. The slider should snap back in place easily if everything is ok. The slider also operates a switch inside the mixer. This switch is intended to only allow you to run on full power when using the hand blender. You may need to open up the mixer to check this switch is not stuck in the activated position permanently. Otherwise consider the description of the speed problem in the link.
Posted on Dec 05, 2010
SOURCE:
A701a. How can I replace lost blue cover where blender attaches?
Check with a local appliance parts distributor and/or Kenwood to determine availability and source.
Sep 10, 2015 | Kenwood Food Mixers
Can you put ice in the blender part of the food processor?
It is unwise to put whole ice cubes in the plastic processor vessel. If you have the pyrex glass attachment, Ice is fine.
Feb 25, 2015 | Chef's Mark 14 in 1 Food Processor
I can attach the immersion blender attachment but it does not turn on. The machine works fine with the mini-chopper attachment or the beaters. How can I fix this?
Hi
Make sure you use the pulse function of the power switch. Only this position (forward, away from you) will activate the immersion blender, and then at full speed only.
Feb 09, 2011 | Braun M880 MultiMix Hand Mixer
I seem to have lost the instruction manual for my mixer. I would like to use the immersion blender, but I can't figure out how to attach it to the mixer body. The shaft on the blender is too short to...
Hi
The blender does not attach to any of the two holes for the whisks.
You need to push back the sliding cover in the center, bottom part between and behind where the whiskers attach. This will uncover a third attachment possibility, where you insert the blender and twist it a quarter turn into place.
Dec 13, 2010 | Braun M880 MultiMix Hand Mixer
Blender attachment does not work
It could be the drive belts. There are three. One for the motor to the belt drive. one from belt drive to bowl mixer spindle. one from belt drive to mixer spindle. mine started to do the same thing. I ordered the belts from Bosch.
Jun 08, 2010 | Bosch 700 Watts MEK7000 Concept Series...
My DeLonghi DSM800 when running sometimes stop for a second and then starts up again. It also seems to speed up at times and almost sounds like it is skipping a gear or something. Any ideas.
I had the same problem and fixed it.
  1. I took it apart, unplug unit, remove the small black cover inside the stand portion, 1 screw. Underneath you will find four screws with a white plastic wire junction.
  2. Loosen two screws and remove the black and brown wires which connect to the control panel with the dial attached.
  3. Remove rear attachment cover, front top cover, and front delonghi cover.
  4. Remove top three screws where the blender attachment goes. Now remove the aluminum cover that covers the entire top.
  5. Slip belt off. Remove three screws with plastic washers that attach motor to chassis.
  6. Remove 2 torx screws that are located next to metal bar that keeps top half from swinging too far from bottom half.
  7. Now you can pull the motor out and the control panel with the dial. Remove the three slip on electrical connections on the control panel and reinstall. Carefully remove the two slip on electrical connections on the motor and reinstall.
  8. Re-assemble and test unit.
I thought I had a problem with the control panel or the motor, as it turns out the connections were the problem. Carefully removing them and reinstalling them solved the problem.
Jan 03, 2010 | DeLonghi 800 Watts Cucina DSM800 Stand...
Universal Plus 800W, blender section got liquid in it, is it easy to pop the cover off and regrease the drive? It looks like the whole cover is one piece
I don't know about easy, but it should be serviceable. Use only food grade grease available at appliance parts supply.
Oct 31, 2009 | Bosch MUM6612 Universal Series Mixer
Runs fast for a few seconds , then runs very slow
Jan 06, 2009 | DeLonghi DSM7 Stand Mixer
Broken blender attachment
Wolfgang Puck Housewares Customer Service
800-275-8273
Monday - Friday
9:00 am - 4:30 pm Eastern Time
I would call the number above they should be able to help you out.
Aug 04, 2008 | Wolfgang Puck Stand Mixer
Kenwood chef excel attaching blender
http://www.kitchenmanuals.com/manuals/mfg/kenwood/km300_km400_km600_km800.html
hers the manaul for u rate me as fix ya ok its a pdf file also thx nick use adobe reader to view it 43 pages thx agian for using fix ya
Feb 04, 2008 | Kenwood KM400 / KM410 Chef Classic Stand...
Braun M880 MultiMix Hand Mixer Logo
348 people viewed this question
Top Braun Food Mixers Experts
ray gallant
ray gallant
Tom Chichester
cwcollectr
Are you a Braun Food Mixer Expert? Answer questions, earn points and help others
