Question about Canon PowerShot A570 IS Digital Camera
The LCD screen only switches ON in C(Custom) Mode and tansfers to Viewfinder in other Modes.In display Images mode it regains to the LCD screen but as soon as the click button is pressed it again switches over to the Viewfinder I have tried with the Power Saving options and the Custom Settings with no fruuitful result. Please kindly help me in sorting out this problem
    Sergeant:
  • Canon Expert
  • 285 Answers
Try pushing the disp. or display button. I hope this helps! Please rate my answer.
Posted on Jan 30, 2009
No image is captured by the screen itself (LCD screen works but completely dark).
Did you try pressing the display button several times? in both viewing mode and record mode? Cycle through all display modes, s you get used to the button, so it does not trow you off when it happens again.
Feb 16, 2015 | Canon Cameras
When I turn on my camera the LCD screen is balck and I cant see anything thruough the lens. It does take pics because when I upload the disck Ic an see the new pics
Double check if the viewfinder is operable (not the LDC but the little thing you look through with one eye above it). Try pressing the display button to flip through the different modes as you're looking through the viewfinder. If the viewfinder does work (and the LCD screen doesn't come on as you're scrolling through the modes) then it is most likely dead (broken). If the viewfinder works, you're can still use the camera otherwise it's probably time to get a new one.
Dec 09, 2009 | Canon PowerShot S3 IS Digital Camera
S1IS canon camera
Apparently the vendor-supplied CCD image sensor used in this Canon digital camera may cause the following malfunction: When the product is used in recording or playback mode, the LCD screen and/or electronic viewfinder may exhibit either a distorted image or no image at all.
To determine if the CCD (image sensor) is working properly, follow these steps:
1. Insert a memory card with known good images on it into the camera.
2. Power the camera on to the Playback mode.
3. Press the DISPLAY (DISP) button to enable the LCD panel, and observe
the LCD.
a. If the images are displayed properly, please proceed to step
four.
b. If the images are not displayed, or a "NO IMAGES" message
appears, please ensure that the memory card contains known good images.
c. If the card contains known good images, and the issue persists
with a second memory card, the camera will require service.
4. Switch the camera to the Camera mode. You may use any shooting mode
(i.e. Auto, Manual).
5. Press the DISPLAY (DISP) button to enable the LCD panel.
6. Point the camera at a well-lit scene and observe the LCD and/or
viewfinder. If the scene the camera is pointed at appears on the LCD
and/or viewfinder, the CCD is operating properly. If the LCD and/or
viewfinder remain black, the camera requires service.
Effective immediately, and regardless of warranty status, Canon will
repair, free of charge, products exhibiting the above-mentioned
malfunction if the malfunction is caused by the CCD image sensor. Canon will also cover the cost of shipping and handling in connection with this repair.
Regards.
Dec 01, 2009 | Canon PowerShot S1 IS Digital Camera
Blank screen
Sounds like you accidentally pressed the DISP (Display) button on the back of your camera. This manually turns the screen on and off in picture taking mode to save battery power. You could then use the optical viewfinder in its place. To turn it back on, just the DISP button one more time.
Jul 07, 2009 | Canon PowerShot SD600 Digital Camera
LCD has gone blank
Hi this is tech crazy
Based on the information you have provided, it appears that you may have
encountered this issue. To determine if the CCD (image sensor) is
working properly, please follow these steps:
the LCD.
four.
Hope this solution helps you a lot
Please rate me on the above said solution
Feb 04, 2009 | Sony Handycam DCR-HC21 Mini DV Digital...
Camera screen remains black when I turn on shooting mode
Turn the camera on. With the screen showing, press the DISP button and this will give you a selection of different screen views i.e. squares for aligning shot squarely; black - thru viewfinder only; etc. Different modes will give you different screen displays i.e. P setting screens are different to when you have the camera set on AUTO.
Hope this helps.
Jan 11, 2009 | Canon PowerShot S51S Digital Camera
Recording problem
Knowledge Article C116445
There is no picture or a black screen appears in the viewfinder or LCD when attempting to record. Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record. NOTES:
  • Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
  • It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
  1. Ensure the lens cap on the front of the camcorder has been removed.
  2. Ensure a fully-charged battery is inserted in the camcorder.
  3. Ensure the STANDBY/LOCK switch is set to the STANDBY position.
  4. Turn on the camcorder and set it to the CAMERA mode.
  5. Look to see if an image can be seen in the viewfinder or LCD.
  6. IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
  7. If the issue is not resolved, reset the camcorder to factory specifications.
NOTE: If the issue is still unresolved after completing the troubleshootin
Nov 30, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
LCD Monitor on ,and the Electronic Viewfinder turned off
If you turn on the back LCD, the electronic viewfinder will remain on while in a shooting mode. There is no setting on the camera to use only the back LCD monitor while shooting. If you playback images in the Play mode, only the LCD monitor will turn on. However, if you press the Monitor button while in the Play mode, than the back LCD monitor will turn off. The image will display only in the viewfinder LCD.
Sep 04, 2005 | Olympus Camedia C-730 Digital Camera
LCD monitor and electronic viewfinder
Sep 04, 2005 | Olympus Camedia C-725 Digital Camera
LCD Monitor on and the electronic viewfinder
Sep 04, 2005 | Olympus Camedia C-720 Ultra Zoom Digital...
Canon PowerShot A570 IS Digital Camera Logo
62 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
