It's supposed to be super capacity, i put a load of towels in, on the spin cycle it was jumping so hard, it moved over to the dryer and moved it too. I thought it was unbalanced, couldn't get the door to unlock (not in the manual) can't figure out how to reset it. HELP ME
Betty, if you suggesting the machine is out of balance/ causing the machine to jump around in spin cycle
1. it may be due to a heavy wet load ,like towels unbalancing the machine, try less load or slower spin ,then fast spin
2. could be concrete balancing block inside machine has come loose, both problems causing a unbalancing affect on the spin cycle.
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
If this is a newly installed washing machine have you taken out the four big bolts on the back of the machine? It holds the drum to prevent it from moving during transportation when it was delivered. if machine runs during fast spin it will make the machine vibrate heavily causing it to move
sorry to say you have a very expensive to repair problem ): the transmission has a brake built into which is suppose to hold the tub in place during the agitation cycle and then release on the spin cycle to spin. the brake isnt engaging and the only fix is to replace the transmisson which is very expensive. it may work for awhile then as it gets worse and the tub moves more during the wash cycle water will slosch out of it all over the floor,sorry to break the bad new
This machine will rotate the motor to agitate in one direction and then reverse to activate the pump and the clutch for spin. I would remove the inspection plate and watch the motor and pump in action in both wash and spin, go to www.apdepot.com and dig around you will find parts and a wire schematic on this machine.
Have you checked the lid switch??? This will prevent it from spinning look on the lid you will see a plunger.. watch where it goes down to you can use a pen to press the sw while the lid is up to see if it is working ...PS: dont forget to set it into the spin cycle first..let me know what happens
