Question about Fuji FinePix A345 Digital Camera
Shutter release button
My shutter release button broke off is it possible to get that button and if so where or how can i get it .? Also with just a small piece like that would fuji send me that piece for free .?
    Genius:
  • 2,985 Answers
Fraid not. It is increasing the case now that -with the exception of warranty work repairs are not feasible - The technology and models change so much are are no spares for older kit. A repair shop will cost you -packing shipping and inspection fee plus packing and shipping back to you with little prospect of a repair Money best put toward the next-more up to date camera in my view
Posted on Jun 17, 2007
SOURCE:
How do I fix the broken release button for the handbrake?
Check with a Ford dealer regarding replacement. This is a safety issue and should be taken care of promptly.
Jul 16, 2014 | 2001 Ford Focus
Nikon N80 stuck shutter button
needs repairing at a qualified shop
Aug 09, 2012 | Nikon N80 35mm SLR Camera
Plastic shutter button broke. Can release shutter by pushing in the middle but button is gone includeing screw int piece for shutter release. Is this an easy fix?
The only easy fix is to glue with a super glue with the broken part or parts. If this is lost then you need to fabricate a similar type knob to be glued into the slot making sure that glue does no overflow and get the whole shaft stuck.
other wise the original can be sourced or replaced from a worn out/discarded camera or consult the Pentax service for estimation.. to restore it originally.
Jan 25, 2011 | Pentax ME Super 35mm SLR Camera
Is it possible to achieve a 20sec shutter release via remote control
With or without the remote control, in the M exposure mode you can select the bulb/time setting. Without the remote, this opens the shutter when you press the shutter release and holds it open while you keep the shutter release pressed. With the remote, this opens the shutter when you press the button on the remote and keeps it open until you press the button again. This allows you to keep the shutter open for up to 10 minutes.
Nov 29, 2010 | Nikon Coolpix 8800 Digital Camera
Shutter does not work.
It's not a shutter, but aperture unit is jammed.
Try these: Move lens all the way out and while pressing release button, gently tap on the tip of the lens using something soft/havy like small rubber hammer or piece of rubber.
Apr 16, 2009 | Fuji FinePix E500 Digital Camera
Nikon d40x shutter stuck
The manual (pg 112) simply, and unfortunately, states this message "Press shutter release button again. If error persists, consult with Nikon-authorized service representative".
Some questions that might help: have you had the camera in some extreme conditions, damp, sand, etc. Clean the shutter button really well. Maybe use a small air blower and clean in the shutter release creases.
In the end, if the error continues, it will need to be serviced.
Dec 28, 2008 | Nikon D40x Digital Camera
How to reattach shutter button
The fix is real easy. No need to take the camera apart.
Order the Shutter Button Release Assembly from Sony. Cost was around $18.00 + tax + Shipping. I received the new assembly in one week.
Note the angle of the old assembly before removing it so that you can line up the new one correctly.
To remove the old button assembly, use a rubber bottle opener to get a good grip. Turn slightly counter clockwise. Then use your fingernail to lift it up. Look inside using a magnifing (sp) glass and find the pieces that broke off, a spring, a small plastic tip and a small snap ring.
Look at the opening and you'll notice two slots, that's where the two little feet will line up. Again using the rubber bottle opener and pressing down slightly, turn the newassembly clockwise. You'll feel it.
Make sure to clean out the pieces that broke off. I couldn't find the spring, now I can't use that little wheel to bring the viewfinder into focus for my eye. LCD is still sharp as are the pictures. Just the viewfinder.
Good luck.
glenn gorman
Sat, 18 Aug 2007 18:50:55 +0000
Whoops: x21083252
Sony Direct Accessories
May 07, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
Stuck shutter release button on my D100
Ouch...
The damage may require parts, but maybe not. If I were doing the work, I would charge in the $50-$60 range , plus parts if needed.
Nikon will likely quote you much higher $200+
You can use the repair service locater here on Fixya to find a repair shop in your area
Mar 24, 2008 | Nikon D100 Digital Camera
DSC H5 - shutter button problem
Here is a $2 fix to this problem.
It just takes some electrical tape, a small piece of manila paper or similar and one thumbtack.
After the silver shutter button fell off, I tried a thumbtack and found that it did a good job of doing the pre-focus and capturing of the image. I then took a piece of black electrical tape about 3 inches long and in the middle, pasted on a small circle of construction paper or manila folder type of paper slightly bigger than the head of the thumbtack. This piece of cardboard will lie on top of the thumbtack head. This prevents the electrical tape from sticking directly to the thumbtack so that the thumbtack is free to move up and down (and trapped in position) without being stuck to the tape. I then put the electrical tape in position so that the thumbtack is held with its pin stuck into the shutter button.
Works well and doesn't look that bad either since the black tape blends into the body and the thumbtack is not visible.
Oct 19, 2007 | Sony Cyber-shot DSC-H5 Digital Camera
Failed shutter release
If you decide to open your camera, here's a pictorial disassembly. Don't go any further than popping the top off to examine components in the vicinity of the shutter button. Look for anyhting different than what's showing in the picture. Remember that you can be creative with a little bit of glue, and a small piece of scrap plastic:
http://qman.fotokala.ee/Kaamerad/PowerShotA95/index.html
And keep in mind there's a potential for electrical shock. Read this first before you turn any screws:
http://camerarepair.blogspot.com/2007/11/important-warning-camera-flash.html
Oct 02, 2007 | Canon PowerShot A95 Digital Camera
Fuji FinePix A345 Digital Camera Logo
66 people viewed this question
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
