Question about Ionic Pro 901P2RIP04 Air Purifier
Ionic pro sizzles and crackles when I turn it on. it doesn't crackle constantly but, it like slowly pulses. it crackles for about a second every 4-6 seconds while it is on high, and a little less often (8-10 seconds) on medium and low.
    Novelist:
  • 135 Answers
"A blinking light indicates when the blades should be wiped clean with a damp cloth." I actually had a "handyman" contract last year to visit an elderly gentleman once a month and clean all 9 of his Ionic Breeze GP air purifiers. Before I did that for him, they would make hissing noises and he really didn't like that. Here's how to clean the operative compnents of these machines: First, unplug the machine and place on a work surface, such as a table or kitchen counter. Second, remove the metal blade insert from the top by gripping the release tab and lifting it up and out. Also remove the front and back grilles by pressing on the plastic tab at the bottom and lifting up on them. Third, use a damp rag or paper towel to wipe the three metal blades clean. Do not immerse this assembly in water, because it has to be completely dry when re-installing it in the machine. Fourth, use a small piece of damp paper towel to VERY GENTLY wipe clean the two thin wires inside the unit. These are located behind the two rubbery flat blades just inside the unit and can be accessed from the front side. You won't damage these rubbery flat blades by pushing your hand gently between them, but be VERY CAREFUL when wiping the wires clean. (This step is important, as the wires must be clean.) Fifth, using another bit of damp paper towel, carefully clean the wire attached to the inside of the front grille. Dry this off with a dry bit of paper towel, then clean any accumulated dirt off the front & back grilles. Check the metal contact near the bottom of the front grille (attached to the wire) to verify that it's clean and will make good electrical contact. Sixth, pick the unit up and turn it upside-down & right-side up about 6 to 8 times. The two wires inside have plastic beads on them that slide up and down the wires. This brushes any bits of leftover dust or lint off of the wires. (Again, these wires must be VERY clean.) Seventh, replace the front and back plastic grilles by placing them in their slots and sliding them down to snap into place. Verify that the assembly with the three metal blades is COMPLETELY dry, using a hair dryer if necessary to dry off damp areas, then slide it back into place from the top of the machine. Now the cleaning process is done, so plug the unit in and turn it on to test operation. If it makes ANY noise, then some component is not completely cleaned off, or still has a presence of moisture, which must be completely dried off before the machine is ready for operation. Hope this helps! ;)
Posted on Aug 05, 2007
  • 3 Answers
I found that the buzzing can be removed by blowing out the unit, cleaning the blades and taking a long cotton swab and alcohol to thoroughly clean the corona wire - carefully - don't break it. The wire should be clean enough that the slider/wiper runs smoothly up and down the wire after cleaning. If it drags or is rough to slide, you will still have noise no matter how many times you clean the blades. The wire gets a "crust" on it.
Posted on Sep 16, 2009
  • 4 Answers
I had the same problem but before I did all of the above suggestions I tried this and it worked fast...Unplug unit and turn it upside down and right-side up 4-5 times and the problem went away instantly.
Posted on Jul 08, 2009
    New Friend:
    Problem Solver:
  • 6 Answers
I checked after reading these answer. Mine had a latch on the back top with a label, " pull up to clean if crackling". I pulled it up and observed a wiper sliding up the big wire inside. I did it up and down several times and that fixed mine. I noticed my machine is quite a bit newer these the others in the post. They must have added the latch/stick after.
Posted on Oct 17, 2017
SOURCE:
Where is the ionizer wire?
On the opposite half as the plates. Look for but don't touch the big insulator at the top. The wire run from it to the bottom of the machine. Older ones have a cleaning bead and you must turn the entire machine upside then right side up several times to clean it. Mine had a latch on the back top with a label, " pull up to clean if crackling". I pulled it up and observed a wiper sliding up the big wire inside. I did it up and down several times and that fixed mine.
Jun 23, 2014 | Ionic Pro TURBO Air Purifier
Can I still use the air purifier if I put clean filters even if light is on red light wont go off
Jun 13, 2014 | Ionic Pro 901P2RIP04 Air Purifier
My ionic pro ca500 has the blue light on but also is making a intermittent sizzling sound, I have wiped the blades, the clean light is not on.
What does the blue light mean? I had 4 Ionic breeze air cleaners, ionizer wires are broken. I was thinking about buying the Ionic Pro cleaners, but have no input about how well they work.
Dec 02, 2013 | Ionic Pro CA500 Air Purifier
Crackles even after blades are cleaned
To stop the crackling sound, you need to remove all of the dust particles from the wire in the back. Sometimes when the unit is extremely dirty you can see sparks emanating from the wire, this is what causes the crackling sound. The unit has a built in cleaner you can lift up and down to perform this task, located on the top, but this doesn't work extremely well.
I usually take a can of compressed air and blow as much of the dust I can off the wire and all surrounding internal areas as I can. To do this, approach the unit from the front, and turn the blade door slightly so the wire can be seen. This along with a thorough cleaning of the blades should eliminate the crackling noise. Of course, make sure the device is unplugged before performing any cleaning.
Oct 19, 2011 | Ionic Pro TURBO Air Purifier
Unit will sometimes make a crackling noise.
Mine does it too, I finally just tried something else when I was cleaning the blades. I took some alcohol on a qtip and with the blades out of the machine I wiped up and down the line wires that are inside that go from the top to the bottom, and also the little balls that are on the bottom of the wires that slide when you turn your unit upside down. It seems to work, I do it every time I clean the blades. scribner062
May 22, 2010 | Sharper Image Ionic Breeze Quadra Air...
Sharper image ionic cleaner wire problem
these things are junk. you could also be doing more harm than good to yourself and the indoor air quality in your home with the amount of ozone these appliances omit into the air. throw it away
Aug 15, 2009 | Ionic Pro (HW-020002) Air Purifier
My Ionic Pro Turbo air purifier is blowing air in intervals of 30 seconds, blows for 30 seconds then stops for 10 sec. then repeats. Is this normal or do I have a defective unit? Thanks, Jerry
Have you cleaned the unit good and made sure that there is nothing crossing the grid wires? It sounds as if it is cutting off and resetting for some reason. Mine runs continuously. I take an air compressor and blow mine out every time I clean it. Also, on some models, you have to hold the on button down for several seconds to reset it after cleaning. Hope this helps.
Jul 03, 2009 | Ionic Pro FULL-SIZE Air Purifier
No clean air smell/crackling & static
I usually take a can of compressed air and blow as much of the dust I can off the wire and all surrounding internal areas as I can. This along with a thorough cleaning of the blades should eliminate the crackling noise. Of course, make sure the device is unplugged before performing any cleaning.
Not sure about the smell though. Mine has started to smell a little strange and I haven't figured out how to fix that problem.
Oct 01, 2008 | Ionic Pro TURBO Air Purifier
Ionic Pro 901P2RIP04 Air Purifier Logo
7,972 people viewed this question
Top Ionic Pro Air Purifiers Experts
senbukan
Pop Schlepp
Level 1 Expert
Tom Chichester
Are you an Ionic Pro Air Purifier Expert? Answer questions, earn points and help others
