Question about Nokia 1600 Cellular Phone
Low volume on Nokia 1600 phone
How is the volume controlled on the Nokia 1600? The old one I owned had a visible volume control that could be adjusted on the screen. My new Nokia 1600 does not appear to have this feature.
  • dkwilson4 Jan 16, 2009
    that helped, thanks.
    Problem Solver:
  • 4 Answers
Sometimes the volume is in a funny place. did you try going to menu then settings then audio/ringtones then volume? I hope this is helpful
Posted on Jan 15, 2009
Need unlock code nokia 1600-b imei 010767/00/816425/5
Hi you can get the unlock code for a Nokia 1600 from www.unlocking4free.com/nokia-1600 for free. all the best mate.
Sep 24, 2012 | Nokia 1600 Cellular Phone
My nokia 5310 fell down and volume control is not working.. i am not able to adjust the volume.. how can i make the volume control work.. or how can i increase or decrease the volume without using volume...
hi
either your volume button get damaged or the software gets corrupted in your phone.. change the volume button and format the phone.this willl fix your phone..
thank you
Dec 24, 2010 | Nokia 5310 Cellular Phone
My mobile hearing volum is very low what can i do?
Hi!
Do you have a button on the side off the phone for controlling the volume, or on some phone you can use the button for UP to control the Volume of your phone. While on call press on that button to increase the audio volume.
Hope this helps
Dec 10, 2010 | Nokia 3110 Cellular Phone
How do i get the Audio to work?
  1. Check the volume control located on the front or side of your computer to be sure that it is not set at the lowest level. If the problem is not resolved, proceed to Step 2.
  2. Step 2 Right-click on the "Volume Control" icon located on the Start menu taskbar and then select "Open Volume Control."
  3. Step 3 Remove all checkmarks beside "Mute" in the Master Volume and all other visible categories. If the sound problem is not solved, proceed to Step 4.
  4. Step 4 Right-click on the "Volume Control" icon and select "Adjust Audio Properties."
  5. Step 5 Go to the Volume tab and adjust the "Device Volume" by moving the slider within the range from Low to High.
  6. Step 6 Click on "Speaker Volume" under Speaker Settings and move the slider within the range from Low to High to reset the left and right speaker volume. If the sound problem is not solved, proceed to Step 7.
  7. Step 7 Go to the Hardware tab and highlight the device with the sound issue and then click "Troubleshoot." Follow the prompts until the issue is resolved.
Mar 02, 2010 | Computers & Internet
Skpe calls are low
Skype has its own volume controle try to adjust it accordingly! if it is at highest so may be your wave volume is lowered. "Double click" on the speaker icon in the task bar. It will open the volume control panel. There you can see several volume controles. Usually the second one from left is the wave control.
Hope it helps
BR
Bruce
Jan 15, 2010 | Acer Aspire One Netbook 8.9" Notebook
Can't find the hands free speaker button
In an increasingly hands-free world, the external speaker feature of cell phones has increased the usability of cell phonesmag-glass_10x10.gif in the car, public transportation and at work. The volume controls on the external speaker controls can be somewhat difficult to find and manipulate.
  1. Step 1 Make sure the speaker setting is actually on. If the speaker is turned to off, the volume you hear will be coming from the earpiece and will be very low indeed. Sometimes there is a button on a cellphone which you can simply press and hold to activate the speaker function. You will notice a difference immediately.
  2. Step 2 Check to see if you have external volume controls. On some models, there is a button or two buttons that adjust the volume of both the handset and the speaker volume. If you have these buttons, use them to adjust these controls while on calls. Remember that adjusting the speaker volume will subsequently adjust the handset volume once you've turned off the speaker mode.
  3. Step 3 Access the sound controls in your phone. If your phone does not have external speaker control, it can be accessed by adjusting the controls saved on your phone. Also, the main settings can be controlled even if you do have external controls. Phones are different, but in your menu of options, choose sound and sound controls. This should give you options for ring volume, alarm volume and handset volume.
  4. Step 4 FInd volume controls for all settings. If you wish yo have multiple settings for each function---alarm, calls and speaker---you should be able to adjust these accordingly. Search through the control options until you've found speaker controls. Choose the setting you desire and save the settings.
  5. Step 5 Using the main volume as a foundation, use the external controls (if applicable) to adjust the levels.
Nov 15, 2009 | Cell Phones
Low volume on a dsl line
I'm sorry but what kind of answer is that? I came on here to find out where the volume control was. If people know where it was they would know to adjust it and would not be asking.
Feb 25, 2009 | Panasonic KX-TG5100 Cordless Phone
Nokia 1600 - how do I increase reception volume on in coming call
while on the call use the right and left scroll button
Nov 10, 2008 | Nokia 1600 Cellular Phone
Volume control
WELL you place the call press send wait for connection and then use the up arrow to contro volume...sound simple well it took us a heck of a long time to figure this out HOPE THIS WORKS FOR YOU
Oct 31, 2007 | Nokia 6233 Cellular Phone
Unable to adjust volume control
while u r listening to call...just press right arrow key to increase the volume....
Oct 21, 2007 | Nokia 3589i
Nokia 1600 Cellular Phone Logo
683 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
