We are getting a "drum life warning" signal on our workcentre pro 765. how do we proceed?
  • 1,326 Answers
Basicly, the copier has a built in counter, that when it get's to that count. It is tring to worn you that the drum unit is almost at the end of it's life and will need to be changed soon. In time the copier will lock up and code out.
Posted on Jan 16, 2009
Drum life warning
Drums do wear out. You may find, though, that drum replacement is an expensive proposition
Jan 08, 2013 | Xerox WorkCentre Pro 635 Laser Printer
How do you replace the drum in a Xerox 765?
You can get all the necessary information to troubleshoot your printer from the given link below. this link is helpful for you in future too.
Xerox Workcentre Pro 765 Laser Troubleshooting
May 11, 2012 | Xerox WorkCentre Pro 765 Laser Printer
find the box that the drum came in. There should be directions to reset the drum light enclosed. Or go to , then look under support and drivers. Good luck !
Jan 11, 2011 | Xerox WorkCentre Pro 555 Plain Paper Laser...
I have a workcentre pro 215, this have a circle red light on, somebody could help me? thanks
That is the signal to reaplace the drum cartridge. It has a life of 18-20 thousand pages and then that light comes on meaning it needs replaced.
Mar 08, 2010 | Xerox WorkCentre PRO-215 All-In-One Laser...
I need to reset the drum count on Workcentre Pro 765, How do i do this?
I understand you have a situation to reset the drum.
I am still researching this, I forgot the process, sorry.
But If i remember, this might work.
Press and hold these buttons. Menu, 1,3
Power up the machine while holding them.
If you get a messge that says enter code.
It is either 80, 81, or 82.
You can also try to reset the mother board which will defalt all settings on the machine to factory settings. Menu, 1,3, *.
Hold buttons and power up machine, hold buttons for about 15 seconds.
If the star does not work, try the "#" instead.
Your information needs to be reentered in the mahine via the menu button, speed dials, trays sizes you are using.
You may want to print out a reports configuration first before preforming these funtions.
This machine can print out a table road map to show what available menues can be configured.
If this does not work. Then do not try to enter anything else.
It has been so long, I would have to be in front of this machine.
If you are not sure what you are doing, place a service call on this machine and let the service representative handle it for you.
If your machine has been operating pretty good, and you wish to keep it longer, pay the fee and you will have a much better machine to use.
This is a good machine if you wish to keep it longer.
Good luck.
Sep 23, 2009 | Xerox WorkCentre Pro 765 Laser Printer
Copies are very dirty from xerox c2636. Really dark cast of magenta on each copy.
1) magenta drum has already reach life span.
2)poor cleaning of magenta drum process unit.
3)recommended to replace the mageta process unit.
Sep 09, 2009 | Xerox WorkCentre Pro C2636 Color Copier
Xerox Work Center 657 Will Not Recieve, After Replacing Drum
Check to see if when he reset the fax reverted back to receive only as a default.
  1. Press [Menu] (the Up arrow key), and press [3], [1], [0], then press [1].
  2. Select the Answer Mode:
    • Press [1] to select Auto answer, then skip to step 3.
    • Press [2] to select Manual answer, the press [Stop] to return to the Standby mode.
  3. If you select the Auto answer feature, use the numeric keypad to enter the number of times (must be 2 digits, 01-10) the phone must ring before the machine answers, then press [Enter].
    NOTE: When the machine is set to Auto answer and the set number of rings occurs, the machine answers with a fax signal tone and enters the Auto Receive mode.
  4. Press [Stop] to return to the Standby mode.
Jun 30, 2009 | Xerox WorkCentre Pro 635 Laser Printer
Xerox 765
Reading your question, this is what I can mention to you.
On this machine just replace the drum and continue your work. The information should be still in memory. Print out the job number.. You can tell how much memory there is because it tells you in % on the menu.
If you do not replace the drum, you will get streaks on your copies.
Good luck.
Nov 28, 2008 | Xerox WorkCentre Pro 765 Laser Printer
J2 Error ? Xerox Pro 215
J2 means your drum needs to be replaced. The life of the drum is expired.
Mar 13, 2008 | Xerox WorkCentre PRO-215 All-In-One Laser...
Drum Life Warning Message
NOTE: Perform the following procedure to reset the Drum Cartridge counter after you replace the Drum Cartridge. Do not perform this procedure at any other time. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [2], [0], [4]. The screen will display: Change drum. Yes No Press [1], then press [Enter]. The screen will display: Completed. Press [Stop] to return to the Standby Mode. These directions were found on the Xerox website, and worked for me.
Dec 28, 2006 | Xerox WorkCentre Pro 575 Plain Paper Laser...
143 people viewed this question
