Question about Intel PRO/Wireless 2100 MiniPCI 802.11b
Slow speed tests
My Satellite M35-S359 has Intel Pro/wireless 2100 802.11b. Using Linksys router 2.4 Ghz at 54 mbs. Signal is excellent. Yet multiple speed tests result in only download speeds of 3.75 mbs at best. The Pro/wireless 2100 is rated at 11 mbs. Why the big difference? I have no problems connecting or staying connected and have even updated to most current driver for the wireless.
When I bypass the router and connect directly to cable modem, I see download speeds of 10 or more mbs.
Could this be a simple configuration problem? I'm using WEP for security? I'm only an enthusiastic home user not a computer techy by any stretch. Though I do have a new HP G60-235 laptop that sits side by side and pulls down 10-15 mbs, consistently. This leads me to believe its my Wireless card. Any advice would be greatly appreciated. I would even consider upgrading my Pro/wireless 2100 if that would help.
Thanks in advance.
Tim
Your HP G60 has an 802.11 b/g card. 802.11g has a maximum rated speed of 54 mbps, like the router. You never get the actual "rated" speed with wireless cards, this would occur only with maximum signal strength, no network protocol overhead, no security, etc. if you were to replace your current card in the Satellite with an 802.11 b/g card, you would get comparable results.
Posted on Feb 08, 2009
Slow internet speeds
sometimes if you open device manager and expand network adapters, then right-click on the wireless adapter and click properties, on the advanced tab, every manufacturer writes their drivers differently, but some have a setting that is something like compatibility and the choices are faster and more compatible (you have to choose one or the other). Only change one setting at a time, write down what you change, what it started at, and where you set it, then close the property window and test. If it makes it worse, set it back before trying another setting.
Feb 09, 2012 | D-Link AirPlus DI-524 Wireless Router
I have a linksys wrt300n wireless router and an Intel WiFi 4689(?)abgn wireless adapter. Can some one tell me why my connection speed fluctuated between 30 and 130mbps with excellent signal and how I can...
Do you this set to wap, What is the security that you are using,
if you did not set a security and it is open, anyone can be using your signal. wep can be hacked very easily.
Now, how do you know if is fluctuating, are you going by speed test
or by downloading, either way you will always get different speeds
depending on the website you are accessing, there is always speed changes to the internet depending on your ISP and the traffic that is
using it.
Feb 06, 2010 | Cisco Computers & Internet
Toshiba Satellite M35-S359. No audio. Sound
Modem chipset on systemboard is bad most likely.
Jan 04, 2010 | Toshiba Satellite M35-S359 Notebook
Weak signal
Where are you measuring the speed:
* transferring files from one computer on your network
to another computer on your network?
* using a "speed-test" web-site (http://speedtest.shaw.ca) that reports the speed?
What level of service are you paying your ISP for? "Lite"? "High-Speed"? "Extreme" ? "Nitro" ?
The "bottleneck" could be between your ISP and your router,
not between your router and your computer.
Dec 13, 2009 | D-Link AirPlus DI-524 Wireless Router
Slow or no wireless speed, connection says excellent
Your router may be toast but here are a couple of things to try:
Please remember, I'm guessing here...
Before restoring to factory defaults, make sure you can get to the config pages using the rj45 (wired) ports. Do a speed test with a wired connection at http://www.speakeasy.net/speedtest/
1. try removing all security. No WEP or WPK. Also, use no mac address filtering. See if it speeds up. Go back to http://www.speakeasy.net/speedtest/ and try speed testing the wireless portion of your router..
2. If it has automatic channel selection, this may be acting up. So manually select channels. Then do speed tests at the web site (or any speed test web site of your chosing). You may find a screaming fast channel.
3. If this fails to help, use the reset to factory default button. Try setting up the router with NO security first and do speed tests. Use automatic channel selection first, do speed tests, and if all else fails, you can try manually selecting channels again. If the router works well, you might want to set up security again and retest.
4. If all this fails, buy yourself a new wireless 802.11N - (N1) router. They are screamin' fast and have better range.
Apr 07, 2009 | Linksys Wireless-G WRT54G Router
Replacing M35-S359 motherboard with one from S320?
If the M35-S320 case is OK and the M35-S359 screen is OK and will fit the M35-S320 then I would swap the LCD screen lid and inverter over to the M35-S320 including the hard drive from the M35-S359.
It would be less work and with luck it might boot up, if not you might be able to do a system repair, worst case, you will need to reinstall Windows. Plus you have a spare drive from the M35-S320 which you can use as an external hard drive with an USB hard drive adapter case.
Jan 29, 2009 | Toshiba Satellite M35-S320 Notebook
How to set up the wireless-G 2.4 ghz 54mbps LINKSYS
I have moved and lost my CD to my Cisco "Linksys" wireless-G model WRT54GS please tell me how I can download the disk from somewhere???
Joyce
Jul 11, 2008 | Linksys Wireless-G Broadband Router
Linksys WUSB300N adapter not detecting wireless links
I am confused, you are using 2 routers, or you using their dsl modem/router? or your original??
Dec 29, 2007 | Intel PRO/Wireless 2200BG 802.11g/b
Intel PRO/Wireless 2100 MiniPCI 802.11b Logo
274 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
