Question about HP LaserJet 1200 Printer
Printing problem I have an HP laserjet 1200 series. I changed the toner cartridge and now the print on the right side of the page looks like it is dragging up. Illegibel and missing portions.
    Novelist:
  • HP Expert
  • 297 Answers
That is usually an indication the fuser sleeve is worn out or is torn on that side. Start to print a full page and then open the front when the paper is halfway printed, remove the print cartridge and look at the print on the page. If it is good before going into the fuser then you will need to replace the fuser, which is expensive for that model. It is not available from HP any longer, but some places still sell it.
Part Number is:
RG9-1493-060CN
Posted on Jan 16, 2009
Hp laserjet 2550n stopped prining in color, why?
Check your print driver settings. And if you are printing from any of the microsoft office applications look at the page setup to see if something was changed. Click file, then right near print is the page setup.
Nov 21, 2011 | HP LaserJet 2550n Printer
HP LaserJet 4Plus - just changed the fuser and rollers - was getting smudges and shadow on the printer paper. Now getting (on the left 1/4th of the page) light areas with little or no print. The shadow...
Take the toner cartridge out of the printer. Shake it side to side. Reinstall it and print something.
See if that fixes the output.
Could also be the transfer roller.
Jun 28, 2011 | HP LaserJet 4 plus Printer
My laserjet printer started making load noises and no longer prints-the last thing printed only printed the top 3inches and then was all black, it then stopped working altogether
Use the following checklist to ensure that the print cartridge is still operable:
  • Ensure that the print cartridge is seated properly.
  • Inspect the print cartridge for remaining toner.
  • Check the expiration date stamped on the print cartridge box.
  • Check the print cartridge to see if it has been disassembled or refilled.
  • Inspect the print cartridge to see if toner is leaking through worn seals.
  • Check the surface of the photosensitive drum in the print cartridge to see if it has been damaged or scratched. Touching the drum contaminates the photosensitive surface and can cause spotting and image defects.
  • Blurred areas on printed pages indicate that the photosensitive drum in the print cartridge has been overexposed to light. Because overexposure to light causes permanent damage to the photosensitive drum, the cartridge should be replaced.
The HP LaserJet 1100 series printer cannot print to the edge of the paper, to get the image to fit into this printable area, slightly reduce the size of the image.
try this and let me know, also check the status of the toner.
mail me- raaj_k001@rediffmail.com
Jan 12, 2011 | HP LaserJet 1200 Printer
What is the replacement printer for HP Laser Jet
This document provides information about replacing the print cartridge for the HP LaserJet 1010 printer series, including life expectancy and replacement instructions. Print cartridge life expectancy The life of the print cartridge depends on the amount of toner that your print jobs require. When printing text on letter/A4-size paper at five percent coverage, the print cartridge lasts an average of 2,000 pages. This assumes that you set the print density to three and disable EconoMode. (These are the default settings.) See Ordering supplies for information on ordering replacement print cartridges. Changing the print cartridge Follow the below instructions to change the print cartridge:
  1. Open the print cartridge door, and remove the old print cartridge. See the recycling information inside the print cartridge box. Figure 1: Removing old print cartridge c00028312.gif CAUTION: To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper.
  2. Remove the new print cartridge from the packaging, and gently shake it from side to side to distribute the toner evenly inside the cartridge. Figure 2: Gently shaking new print cartridge c00028313.gif
  3. Pull the tab until all the tape is removed from the print cartridge. Put the tab in the print cartridge box to return for recycling. Figure 3: Removing tape from print cartridge c00035442.gif
  4. Insert the print cartridge in the printer, making sure that the print cartridge is in position. Close the print cartridge door. Figure 4: Inserting new print cartridge c00028315.gif
Apr 20, 2010 | HP LaserJet 1010 Printer
Printing a large black streak of toner on rt side of page
Hello! Malik Muhammad Mehran Here... your problem solution is that you must replace the cleaning plates in the cartridge...
Mar 28, 2010 | HP LaserJet 6L Printer
HP LaserJet 1500... prints color yellow ONLY
It's possible that the toner in the cartridge is not evenly distributed. You can redistribute toner if you gently shake the cartridge from side to side, then reinstall it to see if this affects performance. Please also see this article.
You might wish to use the guided troubleshooting option available from HP support here. Or have a look at the troubleshooting section in the user manual here. Then clean the engine & calibrate the printer, as described pg. 88.
If that's no help, please see this forum post and the linked attachments within.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Sep 01, 2009 | HP LaserJet 1500L Color Printer
Images of previous page remains on the new printed page
It is either a bad drum in the toner cartridge or toner on the fuser. Try changing out the toner. If the problem remains, you'll have to get a new fuser module.
Nov 29, 2008 | HP LaserJet 1020 Printer
HP 4100DTN
Run a half test. Start printing a few pages, as it prints open the cover, remove the toner and look down at the paper. Does it have lines on the right side? If yes - replace the toner cartridge.
May 06, 2008 | HP LaserJet 4100dtn Printer
HP LaserJet 1200 Printer Logo
95 people viewed this question
Seeker5211
Seeker5211
