Question about Magellan RoadMate 6000T Bluetooth GPS Receiver
I have a Magellan 6000t locked because it needs a password.
How can it be reset if you do not remember it.
  • 5 Answers
Power unit up from a completely off state. While it's starting up, hold the Mute and Menu buttons down the entire time. It will start up, then flash. As soon as you see the flash let go of the Mute and Menu buttons. Then, as soon as the lights come on around the unit quickly press and hold the Mute and Menu buttons again. The unit will boot into the Windows CE operating system. You then double click on My Device and delete HDD3 or, if you have a SD card in the slot, cut and paste the HDD3 to the SD card. Power the unit off holding the power button down for 7-10 seconds. Take out the SD card, if you have one in, then power up the unit. It should restart likes it's fresh from the factory. I will not be held responsible for any problems or bricked units! DO THIS AT YOUR OWN RISK!
Posted on Aug 28, 2009
I was just given a Magellan 6000t unit. It was used and I don't have the CD. I did a software update but now the unit won't start. I tried a hard reset, still won't start...won't even boot up. How do I...
if you have the green or amber light on, on front of the 6000t while its plugged in to a know good charger, press and hold the power button for up to 15 seconds for a magellan 6000t. if it still wont start on there is no green or amber light on, read below.
the following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050, 5310 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
Bill
Standing Member of G.O.T.
Jan 22, 2011 | Magellan RoadMate 6000T Bluetooth GPS...
The magellan roadmate 60000 T will not come on and i can not chage it.
hi donnajenkins
Bill
Dec 15, 2010 | Magellan RoadMate 6000T Bluetooth GPS...
I need a USB driver for Vista for a Magellan Roadmate 6000T
theres no specific driver for your device or vista as long as your running xp sp2 or higher, your device drive installs automaticlly. if it doesnt, there could be a few reasons why.
make sure the battery is fully charged and using a known good usb cable and assuming there is no problems with the gps (like its been formated) turn the 6000t on. (do not connect the usb cable yet)
(for people that bought one of these and cant start it, you must hold the power button for about 15 seconds)
once you enter the agreement page click ok, then connect your 6000t to your pc and wait until
it tells you, your devise is not installed.
bill
Nov 04, 2009 | Magellan RoadMate 800 GPS Receiver
I have a Magellan Roadmate 6000t and I Love it. I
if you have the 6000 NA (north America) version, you can get a map update HERE and get the latest maps.
if you have the Europe version, go HERE
i recommend you also get the update for your unit if you haven't already.
bill
Oct 08, 2009 | Magellan RoadMate 6000T Bluetooth GPS...
Need instruction manual for 6000t gps
Go to Magellan site and download manual.
Mar 02, 2009 | Magellan GPS
Need driver for magellan 6000t
try this site ww.gpshelp.org that's all you need .
good luck!!!
Dec 24, 2008 | Magellan RoadMate 6000T Bluetooth GPS...
Roadmate 760 Password Reset
Dark,
Although it has been some time now since I've worked on these, I beLIEve if you plug the unit into your computer you can explore the files and there should be a file called password or pwd or.. something along those lines.. all you have to do is delete the file and it will work. It was surprisingly easy I remember that much. If this doesn't work, play/look around with the files in the unit, and as a precaution I would copy the file over to your computer prior to deleting just in case.
-Daniel
Oct 02, 2008 | Magellan Roadmate 760 GPS Receiver
Needs password
if you got computer software with this unit you might want to reinstall it and reset the password. otherwise you might want to do a hard reset which clears the password and storage memory.
that should help
Jun 12, 2008 | Magellan RoadMate 800 GPS Receiver
Blue tooth device pairing code
open bluetooth and search for new device,when you find new device you can configure it so as no code is required and pair auto
Oct 18, 2007 | Magellan RoadMate 6000T Bluetooth GPS...
GPS Logo
406 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
