Question about HP Pavilion dv6000z Notebook
Battery not charging
Hi...when i connect the adapter to my laptop to charge it the light, that indicates that its charging, isn't turned on and it's not charging..I've tired other outlets to see if that the problem and no..help!!! thank you
  • 98 Answers
The problem might be with your power adapter or with your computer battery. If you have two adapters, try the other one, same with batteries.
Posted on Jan 15, 2009
So I bought a HP Pavilion tx2510us about 5 years ago and it served me well for the time being, but about a month ago I was using my laptop and I noticed that the battery icon showed it wasn't being...
You might check your device manager to see if there are any clues there before trying a new battery. Also, check your Power Options settings and see if there is a conflict.
Mar 18, 2013 | Computers & Internet
My hp laptop don't turn on even the charger is
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Mar 02, 2013 | Computers & Internet
Suddenly won't turn on no charge light indicator
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's power socket.If the power/battery LED light flashes and in a certain position this LED lightstays firm, then the power socket is either faulty or it has a dry solder jointwhere it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Jun 25, 2012 | ASUS G71G-A2 PC Notebook
Advent modena m200 will not turn on or charge.
Connect the AC power adapter to the laptop and confirm that the AC power indicator is on (I wish you stated the brand of laptop). If the AC power indicator is not on, try and get a working AC power adapter for your laptop and connect it to your laptop.
With the AC power adapter connected, you can power on your laptop. If the laptop powers on from the OS you can see if the Battery is charging or not.
If the laptop does not power with the AC power adapter connected, then the power port of the laptop is bad.
However, if all these are okay and the battery still does not charge, the battery is faulty and will need to be replaced.
May 15, 2012 | Advent Computers & Internet
Laptop battery is not charging
Hi, this information represents a basic troubleshooting guideline. Refer to your user guide for specific charging and connection instructions. Manuals may be available online in the Support Web site of HP.
Remove the battery from the computer.
Confirm the battery contacts are free of any foreign material that may prevent charging.
Reinsert the battery into the computer.
Verify that the AC adapter cord is properly connected and plugged directly into a known working AC power outlet.
NOTE: If the battery charges correctly when the AC adapter is plugged directly into an AC power outlet, but not when plugged into a power strip or surge protector, the problem is with the power strip or surge protector and not the computer battery or AC adapter.
Verify the correct AC adapter is being used.
Ensure the AC adapter box power light is on. This will be an illuminated green light.
If the AC adapter power light is not on, the AC adapter and power cord will need to be replaced.
Verify the charging indicator is illuminated on the computer.
If the issue still exists, install a different compatible HP battery, if available.
NOTE: If a replacement battery charges and operates correctly, the problem is with the first battery.
If neither the original nor a replacement battery charges, service may be required for the computer.
Dec 21, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
I have a Dell Inspirion 1525. I have a fairly new after market replacement battery which I have only had now for 4 months. I am using Vista. As soon as I unplug, computer shuts down. I go to power settings...
The adapter is working correctly. The battery is either slow to charge or in need of replacement.
It's possible your battery isn't charging at all so to test this boot into bios -> battery status and watch it run overnight.
Sep 09, 2010 | Dell Inspiron 1525 Notebook
Battery indicator?
Hi there.
Sounds like the battery could be faulty.
The diagnostic procedures from the Dell User Guide are as follows:
Total Power Failure When Using a Battery
If an AC adapter is not connected to your computer, the computer's power source
is a battery. If the battery indicator flashes amber or is a steady amber, the
battery needs to be charged. If the battery is flashing green and amber, the
battery may be defective. To troubleshoot this problem, use the following
procedure.
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking
for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer
operates normally when using AC power, go to step 7. If the computer does not
boot when using the AC adapter, see the previous subsection, "Total Power
Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online
System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Yes. Your computer may be in a hot environment. Charging the battery in this
condition may affect the life span of the battery. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still
flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in
the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the
computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective.
Good luck
Jun 01, 2009 | Dell Latitude D600 Notebook
When I plug in my ac adapter into my computer to charge it the green light turns off and won't charge my computer
procedure.
for signs of power.
No. Go to step 7.
Yes. Go to step 9.
No. Go to step 7.
flashing amber?
computer.
good luck
Apr 05, 2009 | Dell Inspiron 6000 Notebook
LAPTOP charging light is not blinking eventhough connected thru c
it could actually be the AC adapter. I've seen a lot of those short out before. If there's a lighting indicator on the power supply check to see if it's lit. If there is none try a new AC adapter. If the AC adapter doesnt solve the problem then its most likely the motherboard.
Mar 25, 2009 | Dell Inspiron 6000 Notebook
"Plugged in, not charging", Toshiba Satellite A135 S4527, under Windows Vista Home Premium
It sounds like the power socket on the laptop is faulty and needs replacing or resoldering. To check this, power up the latop with the power adapter, wriggle the plug in the power socket and check if the battery charge indicator flicks on and off indicating charging and not charging. If it indicator flicks on and off then you have a faulty power socket.
This can be repaired but required the laptop to be completely dismantled to access the power connector.
Feb 18, 2009 | Toshiba Satellite Pro M300-S1002X Notebook
HP Pavilion dv6000z Notebook Logo
83 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
