Question about HP LaserJet 4600dn Color Printer
Keep getting 10.00.03 supplies error, have tried turning the machine off and on several times.
  • Scott Schoemann
    Scott Schoemann Apr 20, 2016
    A supplies error typically indicates a bad or empty toner ctg... check your owners manual as to which one, if you do not have one, you can download one directly from HP.
    Novelist:
  • HP Expert
  • 297 Answers
10.00.03 - The printer cannot read or write to the yellow print cartridge memory tag.
Solution:
Turn the printer off and then back on again.
If error returns, remove all print cartridges and turn off the printer.
Cold reset the printer:
Turn on the printer.
Watch the control panel.
When the memory starts counting, press and hold the green (Select) button.
Continue holding the green check button until the Ready, Data, and Attention lights flash once, and then stay on steady.
Release the check button when the Ready, Data, and Attention light are on steady.
The control panel will display SELECT LANGUAGE.
Press (Down Arrow) button once. The control panel will display COLD RESET.
Press (Select). The printer will perform a cold reset and then continue its power-on sequence.
Wait for the printer prompt to install each print cartridge.
This should return the machine to operating condition. If you still get the error, replace the yellow print cartridge.
Posted on Jan 16, 2009
Trying to thread bobbin and viewed manual several times. singer model 7258. screen first flashes C3 and then ][. cannot find troublr shooting codes in manual.
Why do I keep getting a C3 error (accompanied by lots of beeps) when I turn on my machine?The C3 error as well as the beeping when you turn on your machine indicates the foot control plug is not fully pushed into the sewing machine. Turn off your sewing machine and push the foot contol plug into the machine fully. Turn your sewing machine back on.
Oct 22, 2017 | Singer Sewing Machines
Failed to finish wash, managed to get it to drain slightly but drum wont turn when spin applied
Not sure if this will work on your machine but try turningthe water supply off for the machine then starting cycle again, if you do not want to do that you will have to keep setting it to spin unril it works. Please note that this second method may need to be done several times before the machine is emptied.
Jan 13, 2016 | Washing Machines
I have a HP C6100 All in One error Oxc18a0206 ink failure
Remove all supplies, switch off the machine remove power & usb cable wait couple of minutes.. Power on the machine install the supplies as per appears on screen, check for the error.. For tech guys:
Remove CMOS battery from the formatter, wait for 15 mts, with out battery check for the error. Once error disappears, add CMOS battery...
Jan 04, 2012 | HP PhotoSmart Office Equipment & Supplies
Our Canon jx210p fax keeps saying "chk printer
CHK PRINTER 5100 / SEE MANUAL
Cause Action Movement of the Holder is blocked. Clear the paper jam or foreign object that is preventing the Holder from moving, then turn off the machine and turn it back on again. There may be an obstruction that is not allowing the Holder mechanism to move. Check for any obstruction (paper clip, small object, etc.) and also that the protective tape are removed from the FINE Cartridge. Check also for a paper jam and clear the jam if necessary . Then press [Stop/Reset] and start again. The FINE Cartridge may be defective. Press [Stop/Reset]. Reinstall the FINE Cartridge (see Prepare the Machine ) and start again.In either case, if the error does not clear, try unplugging the fax. Wait several minutes, then plug it back in. Also, try replacing the FINE Cartridge with a new one. An error requiring servicing might have occurred. Turn off the machine, and unplug the power cord of the machine from the power supply. After a while, plug the power cord of the machine back in and turn on the machine. If the same error occurs, contact the service center.
Jul 26, 2011 | Canon FAX JX210P All-In-One Inkjet Printer
Map storage error
This means that there is an error with the data on the CF card..Try reloading the maps another time..
Jul 25, 2008 | Garmin StreetPilot 2610 GPS Receiver
My machine is giving me an error 88 and keeps flashing fast when I turn it on.
I had that problem when the machine was not threaded correctly. I now floss the thread back and forth through the tension area everty time I thread the machine, to make sure the thread is in the right place.
Feb 15, 2007 | Singer CE-200 Quantum Futura Computerized...
HP LaserJet 4600dn Color Printer Logo
4,203 people viewed this question
Seeker5211
Seeker5211
