Question about BenQ MP610 Multimedia Projector
I cannot ger the projector to project the image on the laptop. I have held down the Fn Key and F8 to no avail
I not sure how to connect the projector to a lap top. I have connected a cord from the rgb in connector to my dell laptop but it will not project the image. I held down the fn key and the f8 key but it still does not work. same issue - DELL laptop, BenQ projector. The weird thing is that they were working fine together for months! Now they don't :(
  • 3 Answers
Possible bent pins on the cable.
possible video card death in the computer.
but, most likely one of two things can remedy your problem :
- 1 - try to reselect the source on your projector, so that it is detecting the port where your computer is plugged in. if that fails to solve the problem.........
- 2 - right-click on the desktop, and select "properties". then select "displays", then try the "advanced" tab, and mess around in there. can't tell for sure what options you will be facing at this point, since i don't know what graphics card is in your computer, nor do i know how that card is interfacing with your computer.
good luck, and i hope i was able to give you some help!!!!
(funny thing is, i was on here trying to solve a projector issue i am having, and saw your question pop up on the screen, and figured i might be able to help).
Posted on Jan 16, 2009
I have a Dell laptop ready to go with my first Power Point presentation. I check the projector out from the library and there are no instructions. I googled instructions and tried the advice: Push Fn and...
Look for the F-key with a square/icon of a laptop. Press FN+This button until you see your screen display show that it will be using your LCD + the output on your computer. Remember you need to hook both the VGA or HDMI out to the projecter as well as the USB cable.
Mar 03, 2011 | InFocus In2102 Projector
I can't get a picture when I hook my projector up to my laptop.
HELLO,
If your LCD or DLP projector displays no image, this could be a variety of problems. First, check that the projector has power. On the top of the LCD or DLP projector should be some lights. With power, those lights will be on. If it has power, check to make sure that the projector lamp is firing. If so, go to the source. Make sure that it is connected with a VGA cable or USB cable to your computer, or with an RGB cable, S-Video cable or DVI connection to your VCR/DVD Player. From a laptop computer, the VGA cable should be connected to the VGA out connection, and into the VGA in connection on the projector. Are both ends tight?
If everything has checked out so far, the solution probably lies with the external monitor port. Check this by holding the Fn key on the keyboard, then press the F7 key. (On some computers, the key might be F5 or F3. Try these if F7 doesn't work) Each time you press the Fn / F7 combination, you will cycle your display through the following settings:
* Press Fn / F7 once: The laptop screen only
* Press Fn / F7 twice: The projector port only
* Press Fn / F7 three times: Both the laptop and projector port
* Wait a few seconds after each time you press the key combination to let the LCD or DLP projector refresh. Nine times out of ten this will result in seeing your projected image.
Hope this helpout....
Jun 17, 2010 | HP Digital Projector Vp6110 Multimedia...
First time using infocus 1x projector with this laptop - installed drivers but there is no start up screen on the projector and will not display laptop image.
You have to tell the computer you hooked up an additional external monitor. Lower left on the keyboard you will see a "FN" key. Across the top, your F keys...look for an icon that looks like a monitor. Usually F5, F7 or F8. Hold down the FN key and select the F5 etc key which is the command to display the image through the external port. Doing this once displays image through the projector and laptop. Twice displays image to projector only and three times returns to display only on laptop again.
Jun 19, 2010 | InFocus LP640 Projector Multimedia...
No signal
are you sending the signal to the projector. FN+CRT/LCD button key simultaneously. if you do this 3x you will get the following. no image at projector image at laptop scree, image at projector and laptop screen, image at projector no image at laptop scree,
Jun 02, 2010 | Acer X1160 DLP Data Projector, 2,000 ANSI,...
TravelMate 3270-6569 (LX.TH706.051) PC Notebook: My acer travelmate 3270 is connected to a sony dat...
Try holding down the Function key (Fn), then pressing F5. Wait a few seconds. On most laptop, each press of the F5 key will toggle between laptop display only, projector only and Dual (same image on both - my favorite).
You'll probably see a little Monitor-shaped icon on the F5 key. It's possible it's another function key - on Dells it's usually F8.
Aug 02, 2017 | Acer TravelMate 3270-6569 Notebook
DLP Projector connection to Laptop
you need to go to te control pannel and go to display settings then manually select the external monitor then hit apply it will open on your projector
Nov 02, 2009 | Office Equipment & Supplies
Epson Powerlite 710 viewing issue
the fn + f8 should tally between the 2 or 3 different connections for it
Jul 20, 2009 | Epson ELPLP10S Projector Lamp for...
Won't project; can't find signal
Make sure that your computer was turned on first (don't ask me why). Then hold down the Fn key while pressing F8. Hope that helps.
Aug 28, 2008 | Dell 3200MP Multimedia Projector
Power Point Presentation Using Sanyo Pro Xtra X Multiverse Projector
Don't forget to select the Fn key and F4 on HP laptops. It could also be the Fn key and F8 depending on the laptop brand. It is the apple key and the F7 key on a Mac notebook. On Laptops this will toggle the video to the aux port where the monitor cable connects to the projector. There are 3 modes. video on the laptop screen, video on the laptop and projector, or video to the projector only.
Master Rod
Mar 11, 2008 | Sanyo PLC XU35 Multimedia Projector
connect the projector to your laptop and restart the computer in that way it would recognize the presence of your projector... ;)
Nov 18, 2007 | Office Equipment & Supplies
BenQ MP610 Multimedia Projector Logo
229 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
