Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
M1522 Locks Up Periodically
Locks up (maybe after long idle) and no response to keys. Computer says it is not ready. Have to power cycle it to get it working again. Otherwise, it works great!
  • 4 more comments
  • kattle Feb 02, 2009
    Mine had just started doing this. Sometimes it gets stuck while recycling / rebooting.
  • Anonymous Feb 10, 2009
    Same here, locks up, can't printer fax or nothing until power is turned on/off
  • Anonymous Feb 16, 2009
    Machine freezes after long idle. After turning off then on, or even unpluging, it remains frozen.
  • Anonymous Mar 16, 2009
    I shut down after freeze and then a blinking yellow exclamation mark appears under the control panel. Turn it off again and it's okay for a while.
  • Anonymous Apr 22, 2009
    m1522 Locks up
  • Anonymous May 12, 2009
    Locks up here to after awhile, need to reboot
I had exactly the same problem. Downloaded new firmware and installed it to the printer. Freezeing seems to be gone.
Posted on Jul 07, 2009
  • 286 Answers
There are many threads on the 'net about this issue. Many people find that even after updating the firmware they still have the problem. HP has issues a service bulletin on this model which means if it's not over 2 years old or so you can get the machine replaced or repaired by them or one of their service centres at no change.
However, if your unit is too old you can remove the left side (screw and hook at back and one hook on the bottom), remove the "formatter" (main) board, preheat an oven to 375F, remove all the stickers and tape from the board and bake it for 10 minutes. Some people recommend removing the battery that is soldered on the board before baking but others say you don't have to. I personally would recommend removing it. Make sure you put it back on the in the correct polarity. I've heard from various sites that there is a 90% success rate of solving this problem using this method. Let the board cool well after removing it from the oven.
Posted on Apr 06, 2011
Why my 1999 toyota 4runner Ltd remote locks but cannot unlock
Is this programming guide doesn't work your remote may be bad or batteries are weak or your body computer could be faulty. The body computer controls the remote.
1. Start with the following conditions: you are in the vehicle
a. Key is out of the ignition
b. Drive door is open ( all other doors are closed)
c. Driver door is unlocked (other door locks don't matter)
2. Insert the key into the ignition (don't turn it) and pull it out.
3. Perform these steps within 40 seconds:
a. Cycle the power locks 5 times. Use an even pace and try
to go relatively fast.
b. Close, then open the drivers door.
4. Perform these steps within 40 seconds:
a. Cycle the power locks 5 times (same as before).
b. Turn the ignition to ON then back to OFF.
c. Turn the ignition to ON then back to OFF.
d. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should cycle (automatically)
indicating successful entry into programming mode. Return to step 1
if the locks do not cycle at this point.
6. Perform these steps within 40 seconds:
a. Press the LOCK and UNLOCK buttons on the transmitter
simultaneously for 1 second.
b. Immediately after letting go of the lock and unlock buttons,
press the lock button by itself and hold for 2 seconds.
Within 3 seconds, the door locks should cycle ( LOCK then
UNLOCK) once-- indicating successful programming. If
the door locks don't cycle, or cycle twice. Repeat steps
6a and 6b--this remote has not been accepted.
c. Repeat steps 6a and 6b for EACH transmitter that will
operate the vehicle. Including any old transmitters.
7. Close the driver door.
Mar 02, 2015 | Toyota 4Runner Base/Sr5/Ltd 1999-2002 F....
Immobilizer light will not go off when key inserted, Lock smith said my computer was not responding, Toyota wants to replace computer but that's 1200 bucks and I want to make sure that this will fix the...
YOU MUST HAVE MASTER KEY:
1. Start with key out of ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Insert key into the ignition (Do NOT Turn) and Pull key out.
3. Perform these steps within 40 seconds.
A. Using the power lock switch on the drivers door, perform 5 lock/unlock cycles
starting with lock. Use an even pace and try to go about one cycle per second.
(1Cycle = 1 lock and 1 unlock).
B. Close, then open drivers door.
4. Perform these steps within 40 seconds.
B. Insert the key in the ignition cylinder.
C. Turn the ignition to ON (Do NOT Start) then back to OFF.
D. Remove the key from the ignition.
5. Within 3 seconds the power door locks should cycle automatically indicating successful
entry into programming mode. Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds.
A. Press the lock and unlock buttons on the remote simultaneously for 1 second.
B. Immediately after letting go of the lock and unlock buttons, press the lock button by
itself and hold for 2 seconds. Within 3 seconds, the door locks should cycle once
indicating successful programming. If the door locks do not cycle, or cycle twice.
repeat steps A and B in step 6 as your remote has not been accepted.
C. Repeat steps A and B in step 6 for each new remote.
7. Close drivers door.
Sep 18, 2013 | 2001 Toyota Land Cruiser
My 2006 lincoln navigator windows, mirror or door locks won't work
I would guess the problem would be located with the drivers door harness. All of these items are controlled from the same place, remove door panel and check harness connectors for tightness and water damage.
Apr 10, 2013 | 2006 Lincoln Navigator
My M1522 turns off after printing once. It has
it could be a power failure on the formatter board
Try doing a hard or reset or nvram:
1. Turn the printer off
2. Hold down the down arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
if this does not work contact hp, 1800-334-5144. If within 2 years from the purchase date ask for a case number to have the printer serviced under a service note.
Al
Eliteprintersolutions@gmail.com
Jun 17, 2010 | HP LaserJet M1522nf Multifunction Printer...
Lost remote and like to program new remote. HELP. 2000 prado vx.
1. Start with the following conditions: you are in the vehicle a. Key is out of the ignition
3. Perform these steps within 40 seconds: a. Cycle the power locks 5 times. Use an even pace and try
4. Perform these steps within 40 seconds: a. Cycle the power locks 5 times (same as before).
6. Perform these steps within 40 seconds: a. Press the LOCK and UNLOCK buttons on the transmitter
Good luck and hope this helps.
Nov 04, 2009 | 2000 Toyota Land Cruiser
How do i program a keyless remote?
Close all the doors. Unlock the power locks . Cycle the ignition key to the run position 8 times. On the 8th time leave it in the run position. The locks will cycle down and up,this means it's in the program mode. press one of the buttons on the remote ,the locks will cycle.If you have more remotes press the buttons and the locks will cycle again. Turn the key of the locks will cycle again and should be programmed. Good luck
Jul 30, 2009 | Ford Explorer Sport Cars & Trucks
No power anywhere
ON AN OLDER CAR MAYBE NOT HAVE UR BATTERY CHECKED ALONG WITH CHARGING SYSTEM CHECK GROUND AND POWER CABLES FROM BATTERY,ALT,AND STARTER FOR CORROSION,LOOSE CONNECTIONS HAVE EXP THIS A FEW TIMES EASY FIX START THERE ITS A DO IT UR SELF THING AND CHEAP
Jul 10, 2009 | 1994 Acura Legend
Trying to program a remote, but it doesn't work.  i followed the instructions turned the key from off to on 8 times and left it at on, but the locks did nothing. can you help?
WHAT FOLLOWS IS THE CORRECT PROCEDURE, REMEMBER YOU MUST COMPLETE THE 8 KEY CYCLES IN LESS THAN 10 SECONDS, IF YOU DO IT RIGHT THE POWER LOCKS WILL GO UP AND DOWN TO INDICATE IT IS READY FOR PROGRAMMING.
1. Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in
RUN. Door locks will cycle to confirm programming mode.
2. Within 20 seconds press any button on first keyless remote. Door locks will cycle
to confirm programming.
3. Within 20 seconds, press any button on second keyless remote. Door locks will
cycle again to confirm programming.
4. Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
Jul 08, 2009 | 2002 Ford Taurus
CAr idles fast - sucks up gas and will shut off periodically.
If it has a high idle I would say that the iac (idle air control) valve is bad and needs replaced. It should be located on the throttle body.
Mar 23, 2009 | 1994 Cadillac DeVille
1997 Pontiac Ventura power door locks cycle on and off
the door actuator needs to be replaced / please rate my response thank you very much
Jan 09, 2009 | 2005 Chevrolet Silverado
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
1,117 people viewed this question
Ben Johnson
